Home » Eclipse Projects » Standard Widget Toolkit (SWT) » PDF printing
PDF printing [message #667642] Sat, 30 April 2011 07:44 Go to next message
I'm unsure if this is the right place.
Please redirect me if I'm wrong.
I have an RCP application where I produce (among other things) a big PDF
file (via pdfLaTeX).
I want to add a print wizard to my app which should essentially
duplicate programmatically the print driver dialog.
I need to be able to chose (programmatically!) page range and even/odd
printing and then bypass the print driver dialog.
I had a look to PaperClips and other similar libs, but I'm unsure if
this really is the way to go.
They seem more apt to produce the pages to be passed over to the print
driver (eventually producing PDF). I have that part already done.
Ideally I would need a function saying:
boolean MyPrint(String printerName, String fileNameDotPDF, int
startPage, int endPage, int printAllEvenOdd, boolean reverseOrder);
I also googled for command-line programs that can fit the bill, but I
only found the pricey pdfprint
(http://www.verypdf.com/pdfprint/pdf-print-cmd.html); no OpenSource
alternative.
Can someone help me, please
TiA
Mauro
Re: PDF printing [message #667663 is a reply to message #667642] Sat, 30 April 2011 14:59 Go to previous messageGo to next message
> alternative.
To print pdf documents I'm using Pdf-renderer
http://java.net/projects/pdf-renderer/
With Windows the results are almost perfect, at least with a text-only
document.
Marco.
Re: PDF printing [message #668004 is a reply to message #667663] Tue, 03 May 2011 06:54 Go to previous message
You can print to a printer using the methods in the org.eclipse.swt.printing.Printer class. You can set the file name and the page range in the PrinterData.
See example snippets here --> http://eclipse.org/swt/snippets/#printing
Previous Topic:workaround: display SWT popupmenu over Swing components on GTK
Next Topic:Catastrophic crash using new Print()
Current Time: Fri Jul 25 20:32:47 EDT 2025
Powered by FUDForum. Page generated in 0.05409 seconds
