Home » Eclipse Projects » DTP » Sybase "create procedure" scripts
Sybase "create procedure" scripts [message #667977] Tue, 03 May 2011 04:09 Go to next message
When using Sybase, a typical SQL script/file to create a stored procedure looks like:
IF EXISTS (SELECT 1 FROM sysobjects WHERE name = 'ProcName' AND TYPE = 'P')
    DROP PROCEDURE ProcName
go
CREATE PROCEDURE ProcName
AS
BEGIN
.... content
END
go
GRANT EXECUTE ON ProcName TO PUBLIC
go
If I enter something like the above in an SQL file in Eclipse and execute it using the DTP (Ctrl-Alt-X), it doesn't work. I get various "Error occurred when executing last statement(s). Do you want to continue?" error messages, and the SQL code is not executed on the database. Even more, the "Status" window doesn't show any useful error message.
Test case:
/* test */
if exists (select 1 from sysobjects where name = 'ProcName' and type = 'P')
    drop procedure ProcName
go
create procedure ProcName
as
begin
	select 1
end
go
grant execute on ProcName to public
go
go
In the "Status" window all this shows is:
Group Execution
/* test */
as
begin
	select 1
end
Elapsed Time:  0 hr, 0 min, 0 sec, 23 ms.
and after Ctrl-Alt-X this, the ProcName procedure *does not exist* in the database.
How can typical Sybase DDL scripts like this be handled in DTP?
Kind regards, Maarten
Re: Sybase "create procedure" scripts [message #667982 is a reply to message #667977] Tue, 03 May 2011 04:24 Go to previous messageGo to next message
Note that if I select the "individual" statements that make up this script in turn and run them with Alt-C, it works, even if I include the "go" in the text selection...
Also, a similar script that only uses DML, eg:
    select 1
go
select 2
go
go
select 3
go
works correctly:
1> if exists (select 1 from sysobjects where name = 'ProcName' and type = 'P')
2>     select 1
3> go
4> select 2
5> go
 2
(1 row affected)
1> select 1 from sysobjects where name = 'ProcName' and type = 'P'
2> go
(0 rows affected)
1> select 3
2> go
 3
(1 row affected)
 3
(1 row affected)
1> Elapsed Time:  0 hr, 0 min, 0 sec, 4 ms.
2> go
So this really seems to be related to DDL statements only.
Re: Sybase "create procedure" scripts [message #671379 is a reply to message #667977] Tue, 17 May 2011 12:48 Go to previous message
Maarten, unfortunately we no longer have any Sybase database experts left on the DTP team.
Can anybody from Sybase perhaps offer some help?
--Fitz
Previous Topic:BadParseException in mysql db
Next Topic:SQL Editor keywords
Current Time: Sun Jul 20 23:18:25 EDT 2025
Powered by FUDForum. Page generated in 0.07700 seconds
