Home » Eclipse Projects » Virgo » trouble with snaps filtering
trouble with snaps filtering [message #667947] Mon, 02 May 2011 18:09 Go to next message
Using Virgo 3.0.0.M03 and a freshly built copy of snaps. I'm having some trouble getting snaps to work they way I feel they should. Long post, so please bear with me! Here are the relevant configs...
Host bundle web.xml
<web-app id="WebApp_ID" version="2.4"
	xmlns="http://java.sun.com/xml/ns/j2ee" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
	xsi:schemaLocation="http://java.sun.com/xml/ns/j2ee http://java.sun.com/xml/ns/j2ee/web-app_2_4.xsd">
	<display-name>Root Servlet</display-name>
	<context-param>
		<param-name>contextConfigLocation</param-name>
		<param-value>
			/META-INF/security.xml
			/META-INF/osgi.xml
	    </param-value>
	</context-param>
       <!-- NOTE: my securityFilter config has a filter chain map with
                           <security:filter-chain pattern="/authenticate/**"	filters="none" />
	<filter>
		<filter-name>securityFilter</filter-name>
		<filter-class>org.springframework.web.filter.DelegatingFilterProxy</filter-class>
	</filter>
	<filter-mapping>
		<url-pattern>/*</url-pattern>
	</filter-mapping>
	<filter>
		<filter-name>snaps-host-filter</filter-name>
		<filter-class>org.eclipse.virgo.snaps.core.SnapHostFilter</filter-class>
	</filter>
	<filter-mapping>
	</filter-mapping>
	<context-param>
		<param-name>contextClass</param-name>
		<param-value>org.eclipse.virgo.web.dm.ServerOsgiBundleXmlWebApplicationContext</param-value>
	</context-param>
	<listener>
		<listener-class>org.springframework.web.context.ContextLoaderListener</listener-class>
	</listener>
	<welcome-file-list>
		<welcome-file>index.jsp</welcome-file>
	</welcome-file-list>
</web-app>
Relevant pieces of host template.mf
Manifest-Version: 1.0
Bundle-ManifestVersion: 2
Bundle-Name: Root Servlet
Excluded-Exports: *
Web-ContextPath: /
Import-Bundle: org.eclipse.virgo.web.dm
Import-Package: org.eclipse.virgo.snaps.core"
snap's web.xml
	<context-param>
		<param-value>
			/META-INF/osgi.xml
	    </param-value>
	</context-param>
	<filter>
	</filter>
	<filter-mapping>
	</filter-mapping>
	<context-param>
	</context-param>
	<listener>
	</listener>
	<welcome-file-list>
</web-app>
relevant pieces of snap's template.mf
Bundle-Name: Username / Password Login Servlet
Excluded-Exports: *
Snap-Host: org.example.web.web-rootservlet
Snap-ContextPath: /authenticate
The snap and host find each other correctly when loaded into Virgo. Now, I would expect that when I navigate to http://localhost:8080/authenticate/ the following should occur:
  1. Host's securityFilter should examine request, match against /authenticate/** and thus apply no security filters.
  2. Host's snaps filter should run and delegate further request processing to snap at /authenticate
  3. Snap's securityFilter handles request
  4. Snap uses index.jsp of snap (as it's a welcome-file) to serve up content.
The actual sequence of events is really confusing to me. Here's the (commented) log of what happens when I make the request to http://localhost:8080/authenticate/
//First few lines are the host's security filter running. Good so far.
DEBUG org.springframework.security.web.FilterChainProxy:193 Converted URL to lowercase, from: '/authenticate/'; to: '/authenticate/'
DEBUG org.springframework.security.web.FilterChainProxy:200 Candidate is: '/authenticate/'; pattern is /authenticate/**; matched=true
DEBUG org.springframework.security.web.FilterChainProxy:158 /authenticate/ has an empty filter list
//Next bunch of lines is Snap handling. Maps the request to the static resource servlet, which seems wrong to me.
INFO  org.eclipse.virgo.snaps.core.OsgiSnapRegistry:66 Snap 'org.eclipse.virgo.snaps.core.internal.webapp.WebAppSnap@72cae19' found for context path '/authenticate'
INFO  org.eclipse.virgo.snaps.core.internal.webapp.container.StandardVirtualContainerRequestDispatcher:71 Servicing request 'null'
INFO  org.eclipse.virgo.snaps.core.internal.webapp.url.ExtensionUrlPattern:38 Path '/authenticate/' does not match pattern 'jsp'
INFO  org.eclipse.virgo.snaps.core.internal.webapp.url.DefaultUrlPattern:44   Path '/authenticate/' matches pattern '/'
INFO  org.eclipse.virgo.snaps.core.internal.webapp.url.UrlPatternMatcher:75   Matched path '/authenticate/' with mapping '__resource-servlet'
INFO  org.eclipse.virgo.snaps.core.internal.webapp.url.DefaultUrlPattern:62   Translated path '/authenticate' to '/'
INFO  org.eclipse.virgo.snaps.core.internal.webapp.url.PathUrlPattern:38      Path '/authenticate/' matches pattern '/authenticate'
//Host's security filter running again for unknown reason
//Snaps again, this time trying to serve up a static resource from the snap at /authenticate/
INFO  org.eclipse.virgo.snaps.core.internal.webapp.StaticResourceServlet:63   Resource / found
If, however, I request http://localhost:8080/authenticate/index.jsp, then things work differently:
//Host's security filter again. Good so far.
DEBUG org.springframework.security.web.FilterChainProxy:193 Converted URL to lowercase, from: '/authenticate/index.jsp'; to: '/authenticate/index.jsp'
DEBUG org.springframework.security.web.FilterChainProxy:200 Candidate is: '/authenticate/index.jsp'; pattern is /authenticate/**; matched=true
DEBUG org.springframework.security.web.FilterChainProxy:158 /authenticate/index.jsp has an empty filter list
//Snaps maps the request to jsp servlet, which is correct.
INFO org.eclipse.virgo.snaps.core.internal.webapp.url.ExtensionUrlPattern:36 Path '/authenticate/index.jsp' matches pattern 'jsp'
INFO org.eclipse.virgo.snaps.core.internal.webapp.url.UrlPatternMatcher:75   Matched path '/authenticate/index.jsp' with mapping '__jsp-servlet'
INFO org.eclipse.virgo.snaps.core.internal.webapp.url.ExtensionUrlPattern:47 Did not translate path '/authenticate/index.jsp'
INFO org.eclipse.virgo.snaps.core.internal.webapp.url.PathUrlPattern:38      Path '/authenticate/index.jsp' matches pattern '/authenticate'
So my questions are
  1. Why is my snap's filter never handling the requests?
  2. Why is my host's securityFilter handling each request twice?
  3. What's the rationale behind snaps's default-web.xml?
  4. Is the "Servicing request 'null' " log statement normal?
  5. What am I doing wrong!?? Smile
Help?
[Updated on: Mon, 02 May 2011 18:11] by Moderator
Re: trouble with snaps filtering [message #668022 is a reply to message #667947] Tue, 03 May 2011 08:38 Go to previous messageGo to next message
Hello Eric,
There is two things wrong in config. Obviously this is lack of documentation on our side.
1. Snap should not have a root.webapp context defined. Because snap is re-using host's servlet context there will be contention for the WebApplicationContext.ROOT_WEB_APPLICATION_CONTEXT_ATTRIBUTE servlet context attribute key.
2. you need to configure Security filter to be scoped to your snap.
See here for hints on how to do it:
http://forum.springsource.org/showthread.php?t=78513
Hope this helps.
Dmitry
Re: trouble with snaps filtering [message #668260 is a reply to message #668022] Wed, 04 May 2011 13:49 Go to previous messageGo to next message
Thanks, Dmitry. That pointed me in the right direction. After a full day of nearly melting my brain, it's finally working as expected! In case anyone else comes along with the same issue, here are my working configs:
host web.xml
	<display-name>Root Web Context</display-name>
	<filter>
	</filter>
	<filter-mapping>
	</filter-mapping>
	<filter>
	</filter>
	<filter-mapping>
		<dispatcher>REQUEST</dispatcher>
        	<dispatcher>INCLUDE</dispatcher>
        	<dispatcher>FORWARD</dispatcher>
	</filter-mapping>
	<context-param>
		<param-value>
			/META-INF/osgi.xml
	    </param-value>
	</context-param>
	<context-param>
	</context-param>
	<listener>
	</listener>
	<welcome-file-list>
</web-app>
snap web.xml
	<filter>
		<filter-name>securityFilters</filter-name>
		<init-param>
			<param-name>contextAttribute</param-name>
			<param-value>org.springframework.web.servlet.FrameworkServlet.CONTEXT.authentication-snap</param-value>
		</init-param>
	</filter>
	<filter-mapping>
	</filter-mapping>
	<servlet>
		<servlet-name>authentication-snap</servlet-name>
		<servlet-class>org.springframework.web.servlet.DispatcherServlet</servlet-class>
		<load-on-startup>2</load-on-startup>
	    <init-param>
	    </init-param>
	    <init-param>
			<param-value>
				/META-INF/osgi.xml
		    </param-value>
	    </init-param>
	</servlet>
</web-app>
Re: trouble with snaps filtering [message #675960 is a reply to message #668260] Thu, 02 June 2011 03:11 Go to previous message
I have a problem with virgo snaps and spring-security
Can you share me your host web.xml, securit-context.xml and snap web.xml, securit-context.xml
My problem is when my request match security pattern, it always show
No snap for context path /websnap
but when I remove security filter, it work fine
Thank you
Previous Topic:Virgo 3.0.0.M05 available
Next Topic:Cannot add Virgo Server
Current Time: Wed Jul 23 06:51:49 EDT 2025
Powered by FUDForum. Page generated in 0.07331 seconds
