Home » Modeling » Papyrus » Problem with dependencies for Ada 2005 Code Generation add-in
Problem with dependencies for Ada 2005 Code Generation add-in [message #667834] Mon, 02 May 2011 08:08 Go to next message
Hi all,
I have faced the following issue when trying to add the Ada 2005 Code Generation add-in into a vanilla Papyrus-1.12.3 installation (Linux, 32bit, latest "official" 1.6.0_24 Java):
  Cannot connect to keystore.
  This trust engine is read only.
  Cannot complete the install because one or more required items could not be found.
    Software currently installed: ADA 2005 code generator for Papyrus 1.0.1.200911231214 (com.adacore.uml2ada2005_feature.feature.group 1.0.1.200911231214)
    Missing requirement: com.adacore.uml2ada2005 1.0.1.200911231214 (com.adacore.uml2ada2005 1.0.1.200911231214) requires 'bundle com.cea.papyrus.integration.acceleo 1.2.0' but it could not be found
    Cannot satisfy dependency:
      From: ADA 2005 code generator for Papyrus 1.0.1.200911231214 (com.adacore.uml2ada2005_feature.feature.group 1.0.1.200911231214)
      To: com.adacore.uml2ada2005 [1.0.1.200911231214]
I think, that keystore is not a problem here. I have also both the CDT Gallileo and the Acceleo update site configured, as suggested on the Add-ins donwload site. I would expect, that if the dependencies are possible to satisfy, the update manager would just pick them.
I was also trying to install manually the "Acceleo integration plugin for Papyrus" plugin in, but this fails with the another missing dependency:
    Software currently installed: Acceleo integration plugin for Papyrus 1.2.0 (com.cea.papyrus.integration.acceleo.feature.group 1.2.0)
    Missing requirement: Acceleo integration inside Papyrus 1.2.0 (com.cea.papyrus.integration.acceleo 1.2.0) requires 'bundle fr.obeo.acceleo.chain 0.0.0' but it could not be found
      From: Acceleo integration plugin for Papyrus 1.2.0 (com.cea.papyrus.integration.acceleo.feature.group 1.2.0)
      To: com.cea.papyrus.integration.acceleo [1.2.0]
Am I missing something?
Thanks in advance! Piotr.
Re: Problem with dependencies for Ada 2005 Code Generation add-in [message #667934 is a reply to message #667834] Mon, 02 May 2011 16:03 Go to previous messageGo to next message
I have solved my own issue by manually installing the Ada 2005 Code Generator in the following items:
  1. Acceleo solution from an Acceleo update site,
  2. Acceleo required dependencies from the Papyrus Add-ins update site
  3. and finally the Ada 2005 Code Generator from the Papyrus Add-ins update site.
The code generator is working, but I am not able to apply the HiUML profile to my model as described in the "Apply_a_static_profile" section of the Papyrus User Guide Sad
The HiUML option is available to pick up, but after selecting is does not show on the list of the applied profiles.
I appreciate any ideas how to get this to work...
Thanks, Piotr.
[Updated on: Mon, 02 May 2011 16:03] by Moderator
Re: Problem with dependencies for Ada 2005 Code Generation add-in [message #673308 is a reply to message #667934] Mon, 23 May 2011 04:03 Go to previous messageGo to next message
Hum...
I will verified why this functionality was not maintained...
Patrick
Papyrus team
Re: Problem with dependencies for Ada 2005 Code Generation add-in [message #673312 is a reply to message #673308] Mon, 23 May 2011 04:14 Go to previous messageGo to next message
This plugin is not in the version papyrus MDT. I think that you taken this feature form papyrus 1.X.
If you have done a patch to connect ada, you can send us this ;D
Patrick
Papyrus team
Re: Problem with dependencies for Ada 2005 Code Generation add-in [message #757697 is a reply to message #667834] Mon, 21 November 2011 04:41 Go to previous message
Piotr Trojanek wrote on Mon, 02 May 2011 08:08
Hi all,
I have the same problem. I have been trying to install it in Eclipse Galileo and Indigo, but in both of them, i get the same message.
is Ada 2005 code generation still working now? How can i resolve this problem to install it?
Thanks!
Previous Topic:How to create a new valueType?
Next Topic:Load resuorce
Current Time: Sat Jul 26 19:12:32 EDT 2025
Powered by FUDForum. Page generated in 0.03906 seconds
