how to know the value of parameter pass from report to subreport [message #667715] |
Sun, 01 May 2011 11:45  |
any method to know what parameter's value is passed to the subreport?
I have a table and in a column of detail band, I add one more table as subreport.
the main report dataset is SingleServerOverload and the subreport dataset is HelpdeskTicket.
In the HelpdeskTicket, the query has three parameter like following:
select
TICKETID,
CREATIONDATE,
DESCRIPTION,
STATUS
from SR
where
(LOCATE(?, classificationid) > 0 )
and CREATIONDATE > ?
and CREATIONDATE < ?
and in the subreport table, Dataset parameter Binding, I define the following
param_1:row["DATE"]
PARAM_2:ROW["helpdeskStartdate"]
PARAM_3:ROW["helpdeskEnddate"]
then in the subreport dataset HelpDeskTicket beforeOpen event, I want to know
what value is passed to the subreport parameter, so I write
Packages.java.lang.System.out.println(row["classificationID"].value);
Packages.java.lang.System.out.println(row["helpdeskStartdate"].value);
Packages.java.lang.System.out.println(row["helpdeskEnddate"].value);
try {
Packages.java.lang.System.out.println(param_1);
}catch(ex){Packages.java.lang.System.out.println("catch println(param_1)");}
try{
Packages.java.lang.System.out.println(params["param_1"]);
}catch(ex1){
Packages.java.lang.System.out.println("catch println(params[\"param_1\"])");
but the first three println cannot show the value of parameter, and the later
two println show exception and go to catch statement.
I try to modify to
Packages.java.lang.System.out.println(row["classificationID");
Packages.java.lang.System.out.println(row["helpdeskStartdate"]);
Packages.java.lang.System.out.println(row["helpdeskEnddate"]);
but still cannot show the value, in eclipsec.exe, it show the address instead of the value of parameter.
So any method to know what parameter's value is passed to the subreport?
(because my subreport seems cannot run properly)
thanks in advance.
Re: how to know the value of parameter pass from report to subreport [message #667931 is a reply to message #667715] |
Mon, 02 May 2011 15:14   |
Yes use the inputParams["parameter"] syntax. Look at the attached
example. Specifically the beforeOpen of the inner scripted dataset.
<report xmlns="http://www.eclipse.org/birt/2005/design" version="3.2.21"
id="1">
<property name="comments">Copyright (c) 2006 <<Your Company
Name here>></property>
<property name="createdBy">Eclipse BIRT Designer Version
2.5.2.v20100208 Build <2.5.2.v20100210-0630></property>
<property name="units">in</property>
<method name="beforeFactory"><![CDATA[myArray = [];
ctr=0;
rctr=0;]]></method>
<property name="layoutPreference">auto layout</property>
<data-sources>
<script-data-source name="Data Source" id="4"/>
</data-sources>
<data-sets>
<script-data-set name="outer" id="5">
<list-property name="resultSetHints">
<structure>
<property name="position">1</property>
<property name="name">c1</property>
<property name="dataType">integer</property>
</structure>
</list-property>
<list-property name="columnHints">
<structure>
<property name="columnName">c1</property>
</structure>
</list-property>
<structure name="cachedMetaData">
<list-property name="resultSet">
<structure>
</structure>
</list-property>
</structure>
<property name="dataSource">Data Source</property>
<method name="open"><![CDATA[i=0;]]></method>
<method name="fetch"><![CDATA[if (i++ >10)
return false;
else {
row.c1=i;
return true;
}]]></method>
</script-data-set>
<script-data-set name="inner" id="6">
<structure>
<property name="name">c2</property>
</structure>
</list-property>
<structure>
<property name="columnName">c2</property>
</structure>
</list-property>
<list-property name="parameters">
<structure>
<property name="name">startval</property>
<expression name="defaultValue">1</expression>
<property name="isInput">true</property>
</structure>
</list-property>
<structure>
</structure>
</list-property>
</structure>
<method name="open"><![CDATA[j =
inputParams["startval"];]]></method>
<method name="fetch"><![CDATA[if (j ++ >=6)
return false;
else {
row.c2=j;
return true;
}]]></method>
</script-data-set>
</data-sets>
<styles>
<style name="table-header" id="37">
<property name="backgroundColor">#6078BF</property>
<property name="fontFamily">"Arial"</property>
<property name="fontSize">small</property>
<property name="fontWeight">bold</property>
<property name="color">#FFFFFF</property>
<property name="paddingTop">0px</property>
<property name="paddingLeft">0px</property>
<property name="paddingBottom">0px</property>
<property name="paddingRight">0px</property>
</style>
<style name="table-footer" id="38">
</style>
<style name="table-detail" id="39">
<property name="backgroundColor">#E6ECFF</property>
<property name="fontSize">x-small</property>
<property name="color">#000080</property>
</style>
<style name="table-group-header-1" id="40">
<property name="backgroundColor">#809FFF</property>
</style>
<style name="table-group-footer-1" id="41">
</style>
<style name="special-header" id="42">
<property name="fontSize">medium</property>
</style>
<style name="crosstab-detail" id="43">
</style>
<style name="crosstab-header" id="44">
</style>
</styles>
<page-setup>
<simple-master-page name="Simple MasterPage" id="2">
<property name="topMargin">1in</property>
<property name="leftMargin">1.25in</property>
<property name="bottomMargin">1in</property>
<property name="rightMargin">1.25in</property>
<page-footer>
<text id="3">
<property name="contentType">html</property>
<text-property
name="content"><![CDATA[<value-of>new Date()</value-of>]]></text-property>
</text>
</page-footer>
</simple-master-page>
</page-setup>
<body>
<table id="55">
<property name="width">100%</property>
<property name="dataSet">outer</property>
<list-property name="boundDataColumns">
<structure>
<expression
name="expression">dataSetRow["c1"]</expression>
</structure>
<structure>
<property name="name">Column Binding</property>
<expression name="expression">var rtn =myArray[rctr];
rctr++;
rtn;</expression>
</structure>
</list-property>
<property name="pageBreakInterval">50</property>
<column id="77"/>
<column id="78"/>
<column id="82"/>
<header>
<row id="56">
<cell id="57">
<label id="58">
<text-property name="text">c1</text-property>
</label>
</cell>
<cell id="59"/>
<cell id="79">
<label id="83">
<text-property
name="text">combination</text-property>
</label>
</cell>
</row>
</header>
<detail>
<row id="60">
<cell id="61">
<data id="62">
<property name="resultSetColumn">c1</property>
</data>
</cell>
<cell id="63">
<table id="64">
<property name="dataSet">inner</property>
<list-property name="paramBindings">
<structure>
<property
name="paramName">startval</property>
<expression
name="expression">row["c1"]</expression>
</structure>
</list-property>
<structure>
<expression
name="expression">myArray[ctr] = dataSetRow["c2"]*row._outer["c1"];
ctr++;
dataSetRow["c2"];</expression>
<property
</structure>
<structure>
Binding</property>
<expression
name="expression">row._outer[row.__rownum]</expression>
<property
name="dataType">string</property>
</structure>
</list-property>
<property
<column id="73"/>
<header>
<row id="65">
<cell id="66">
<label id="67">
<text-property
name="text">c2</text-property>
</label>
</cell>
</row>
</header>
<detail>
<row id="68">
<cell id="69">
<data id="70">
<property
name="resultSetColumn">c2</property>
</data>
</cell>
</row>
</detail>
<footer>
<row id="71">
<cell id="72"/>
</row>
</footer>
</table>
</cell>
<cell id="80">
<data id="84">
<property name="resultSetColumn">Column
Binding</property>
</data>
</cell>
</row>
</detail>
<footer>
<row id="74">
<cell id="75"/>
<cell id="76"/>
<cell id="81"/>
</row>
</footer>
</table>
</body>
</report>
Jason
> subreport.
> select TICKETID,
> CREATIONDATE,
> DESCRIPTION,
> STATUS
> from SR where (LOCATE(?, classificationid) > 0 )
> following
> param_1:row["DATE"]
> know
> Packages.java.lang.System.out.println(row["classificationID "].value);
> Packages.java.lang.System.out.println(row["helpdeskStartdate "].value);
> try {
> try{
> }catch(ex1){
> later
> I try to modify to
> Packages.java.lang.System.out.println(row["classificationID ");
> Packages.java.lang.System.out.println(row["helpdeskStartdate "]);
> thanks in advance.
Re: how to know the value of parameter pass from report to subreport [message #668096 is a reply to message #667967] |
Tue, 03 May 2011 13:42  |
You can reference it with inputParams["innerdatasetparametername"]
Here is an example with 2.2.1
Jason
<report xmlns="http://www.eclipse.org/birt/2005/design" version="3.2.15"
id="1">
2.2.1.r221_v20070924 Build <2.2.0.v20070924-1550></property>
<method name="initialize"><![CDATA[importPackage( Packages.java.util );
importPackage( Packages.java.lang );
var outerMap = new Hashtable();
var innerMap = new Hashtable();
for ( i=0; i<10; i++ ){
var mystring = "Outerrow_" + i;
var myinnerstring = "Innerrow_" + i;
outerMap.put(i, mystring);
innerMap.put( mystring, myinnerstring );
reportContext.setPersistentGlobalVariable("outerMap", outerMap);
reportContext.setPersistentGlobalVariable("innerMap", innerMap);]]></method>
<data-sources>
</data-sources>
<data-sets>
<structure>
<property name="position">0</property>
<property name="name">outtercol</property>
<property name="dataType">string</property>
</structure>
</list-property>
<structure>
<property name="columnName">outtercol</property>
</structure>
</list-property>
<structure>
</structure>
</list-property>
</structure>
<method name="open"><![CDATA[hMap =
reportContext.getPersistentGlobalVariable("outerMap");
iter = hMap.entrySet().iterator();]]></method>
<method name="fetch"><![CDATA[if( iter.hasNext() ){
myObject = iter.next();
row["outtercol"] = myObject.getValue().toString();
return true;
}else{
return false;
}]]></method>
</script-data-set>
<structure>
<property name="name">innercol</property>
</structure>
</list-property>
<structure>
<property name="columnName">innercol</property>
</structure>
</list-property>
<structure>
</structure>
</list-property>
</structure>
<structure>
<property name="name">innerparm</property>
<expression name="defaultValue">testkey</expression>
<property name="isOutput">true</property>
</structure>
</list-property>
<method name="open"><![CDATA[i = 0;
jj = inputParams["innerparm"];]]></method>
<method name="fetch"><![CDATA[iMap =
reportContext.getPersistentGlobalVariable("innerMap");
inObj = iMap.get(jj);
if( i > 0 )return false;
if( inObj != null ){
row["innercol"] = inObj.toString();
i++
return true;]]></method>
</script-data-set>
</data-sets>
<styles>
<style name="detail" id="54">
<property name="backgroundColor">#BACAE2</property>
</style>
<style name="headerfooter" id="55">
<property name="backgroundColor">#004080</property>
</style>
<style name="groupheader" id="56">
<property name="backgroundColor">#0080FF</property>
</style>
</styles>
<page-setup>
<page-footer>
<text id="3">
<text-property
</text>
</page-footer>
</page-setup>
<body>
<table name="myoutertable" id="7">
<structure>
<expression
name="expression">dataSetRow["outtercol"]</expression>
</structure>
</list-property>
<column id="16"/>
<column id="20"/>
<header>
<row id="8">
<property name="style">headerfooter</property>
<cell id="9">
<label id="10">
<text-property
name="text">OuterDSCol</text-property>
</label>
</cell>
<cell id="17"/>
</row>
</header>
<detail>
<row id="11">
<property name="style">detail</property>
<cell id="12">
<data id="13">
<property
name="resultSetColumn">outtercol</property>
</data>
</cell>
<cell id="18">
<table name="innertable" id="21">
<structure>
<property
name="paramName">innerparm</property>
<expression
name="expression">row["outtercol"]</expression>
</structure>
</list-property>
<structure>
<property
<expression
name="expression">dataSetRow["innercol"]</expression>
<property
</structure>
<structure>
Binding</property>
<expression
<property
name="dataType">any</property>
</structure>
</list-property>
<expression
name="bookmark">"innertableforrow"+row._outer[row.__rownum] </expression>
<column id="59"/>
<column id="30"/>
<header>
<row id="22">
<cell id="57"/>
<cell id="23">
<label id="24">
<text-property
name="text">InnerDataSetCol</text-property>
</label>
</cell>
</row>
</header>
<detail>
<row id="25">
<property
name="style">groupheader</property>
<cell id="58">
<data id="60">
<property
name="resultSetColumn">Column Binding</property>
</data>
</cell>
<cell id="26">
<data id="27">
<property
name="resultSetColumn">innercol</property>
</data>
</cell>
</row>
</detail>
</table>
</cell>
</row>
</detail>
<footer>
<row id="14">
<cell id="15"/>
<cell id="19"/>
</row>
</footer>
</table>
</body>
</report>
On 5/3/2011 2:52 AM, tong123123@yahoo.com.hk wrote:
> thanks for the reply, but my birt version is 2.2.1, and so cannot open
> the attachment xml, could you upload a older version sample, thanks.
> My birt designer version
> Quote:
>> version="3.2.15" id="1">
FUDForum. Page generated in 0.05177 seconds
