Home » Eclipse Projects » WindowBuilder » Property editor
Property editor [message #667896] Mon, 02 May 2011 12:17 Go to next message
i am searching the implementation of String editor(property editor).where i can find?
Re: Property editor [message #667903 is a reply to message #667896] Mon, 02 May 2011 13:37 Go to previous messageGo to next message
org.eclipse.wb.internal.core.model.property.editor.string.St ringPropertyEditor in plugin org.eclipse.wb.core
[Updated on: Mon, 02 May 2011 13:37] by Moderator
Re: Property editor [message #668002 is a reply to message #667903] Tue, 03 May 2011 06:21 Go to previous messageGo to next message
in property tab we have a string editor to enter string property.I like to add control on input string.For example we accept the string that her length equal 4.
thinks for your help
[Updated on: Tue, 03 May 2011 09:29] by Moderator
Re: Property editor [message #668109 is a reply to message #668002] Tue, 03 May 2011 14:48 Go to previous message
You will need to provide your own property editor.
See org.eclipse.wb.internal.core.model.property.editor.IntegerPr opertyEditor as example. Its setEditorText() tries to parse String into Integer and show exception in other case. You can do the same.
You will need to register your property editor with ID, see for example how org.eclipse.wb.internal.core.model.property.editor.StringLis tPropertyEditor is registered in plugin.xml
	<extension point="org.eclipse.wb.core.propertyEditors">
		<configurableEditor id="stringList"
			class="org.eclipse.wb.internal.core.model.property.editor.StringListPropertyEditor"/>
	</extension>
...and used later in wbp-component.xml file
	<property id="setType(java.lang.String)">
		<editor id="stringList">
			<parameter-list name="strings">submit</parameter-list>
			<parameter-list name="strings">reset</parameter-list>
			<parameter-list name="strings">button</parameter-list>
		</editor>
	</property>
Previous Topic:SwingDesigner and custom components on the palette
Next Topic:String editor
Current Time: Sun Nov 09 06:57:48 EST 2025
Powered by FUDForum. Page generated in 0.03274 seconds
