Home » Eclipse Projects » EGit / JGit » Commit takes too long time
Commit takes too long time [message #667791] Mon, 02 May 2011 05:04 Go to next message
I have a project with about 20000 files.
When i do a commit, i stay stuck on the "calulating changes in selected repositories" window fore more than 5 minutes before having the comit panel where i can check the file i want in my commit.
Even if i select the directory where my modified files are before Commit, Egit scan the whole 20000 files ...
I try to make a "assume unmodifed" on some big directories where files are never modified, but it dosen't seems to speed up the commit ...
do i forget some thing ? have anyone an idea to speed up my commits ?
thank's
Re: Commit takes too long time [message #667838 is a reply to message #667791] Mon, 02 May 2011 08:23 Go to previous messageGo to next message
- Which EGit version are you using on which platform ?
- I tried on Mac OSX on 2.5 GHz Intel Core i5 using EGit 0.12 with linux kernel repo (>30k files) and EGit takes 2-3 sec to bring up the commit dialog, so something must be different in your case
- is this a public repo ?
- does the repo contain a lot of large files ?
Re: Commit takes too long time [message #667988 is a reply to message #667791] Tue, 03 May 2011 04:59 Go to previous messageGo to next message
Egit 0.11.3
on windows 7 (not my choice Sad ) with intel core i7
i commit on my local repo
the repo contains 20000 small files
Re: Commit takes too long time [message #670821 is a reply to message #667791] Sun, 15 May 2011 14:31 Go to previous messageGo to next message
> thank's
Such a slow commit is a bug. It will always check all your files, but
it shouldn't take more than a few seconds unless you actually changed
a very large number of files.
-- robin
Re: Commit takes too long time [message #676010 is a reply to message #667988] Thu, 02 June 2011 07:27 Go to previous messageGo to next message
Sylvain PRAS wrote on Tue, 03 May 2011 04:59
Egit 0.11.3
0.11 was very slow. Try a recent build and you should find it much faster.
Re: Commit takes too long time [message #684480 is a reply to message #676010] Wed, 15 June 2011 12:24 Go to previous messageGo to next message
With the 0.12.1 this is much faster yes.
But it always takes about 1 minute and an half.
Re: Commit takes too long time [message #767983 is a reply to message #667791] Mon, 19 December 2011 05:09 Go to previous messageGo to next message
I come back on this old topic, because it still disturb me and my work... i found that too long to commit on big projects.
But i found a workaround with use of GIT GUI. (http://code.google.com/p/msysgit/)
When i open my repository with GIT GUI, it propose me to compress the repository. I accept, compressing take few minutes, then when i come back in Eclipse, commit with Egit takes seconds when it was taking minutes...
Why doesn't Egit make this compression ?
Re: Commit takes too long time [message #768226 is a reply to message #767983] Mon, 19 December 2011 14:43 Go to previous message
We are on the way to implement git gc in JGit [1] when this is ready we can integrate it into EGit.
Until then you need to use native git's gc [2] to collect garbage and compact the repository.
[1] http://egit.eclipse.org/r/#change,4705
[2] http://schacon.github.com/git/git-gc.html
and http://alblue.bandlem.com/2011/11/git-tip-of-week-gc-and-pruning-this.html
Previous Topic:Clone, share... and next, question marks decorators ?
Next Topic:Will EGit support automatic stash when doing a checkout?
Current Time: Mon Jul 21 02:41:58 EDT 2025
Powered by FUDForum. Page generated in 0.07742 seconds
