Problem with dependencies for Ada 2005 Code Generation add-in [message #667834] |
Mon, 02 May 2011 08:08  |
Hi all,
I have faced the following issue when trying to add the Ada 2005 Code Generation add-in into a vanilla Papyrus-1.12.3 installation (Linux, 32bit, latest "official" 1.6.0_24 Java):
Cannot connect to keystore.
This trust engine is read only.
Cannot complete the install because one or more required items could not be found.
Software currently installed: ADA 2005 code generator for Papyrus 1.0.1.200911231214 (com.adacore.uml2ada2005_feature.feature.group 1.0.1.200911231214)
Missing requirement: com.adacore.uml2ada2005 1.0.1.200911231214 (com.adacore.uml2ada2005 1.0.1.200911231214) requires 'bundle com.cea.papyrus.integration.acceleo 1.2.0' but it could not be found
Cannot satisfy dependency:
From: ADA 2005 code generator for Papyrus 1.0.1.200911231214 (com.adacore.uml2ada2005_feature.feature.group 1.0.1.200911231214)
To: com.adacore.uml2ada2005 [1.0.1.200911231214]
I think, that keystore is not a problem here. I have also both the CDT Gallileo and the Acceleo update site configured, as suggested on the Add-ins donwload site. I would expect, that if the dependencies are possible to satisfy, the update manager would just pick them.
I was also trying to install manually the "Acceleo integration plugin for Papyrus" plugin in, but this fails with the another missing dependency:
Software currently installed: Acceleo integration plugin for Papyrus 1.2.0 (com.cea.papyrus.integration.acceleo.feature.group 1.2.0)
Missing requirement: Acceleo integration inside Papyrus 1.2.0 (com.cea.papyrus.integration.acceleo 1.2.0) requires 'bundle fr.obeo.acceleo.chain 0.0.0' but it could not be found
From: Acceleo integration plugin for Papyrus 1.2.0 (com.cea.papyrus.integration.acceleo.feature.group 1.2.0)
To: com.cea.papyrus.integration.acceleo [1.2.0]
Am I missing something?
Thanks in advance! Piotr.
Re: Problem with dependencies for Ada 2005 Code Generation add-in [message #757697 is a reply to message #667834] |
Mon, 21 November 2011 04:41  |
Piotr Trojanek wrote on Mon, 02 May 2011 08:08Hi all,
I have the same problem. I have been trying to install it in Eclipse Galileo and Indigo, but in both of them, i get the same message.
is Ada 2005 code generation still working now? How can i resolve this problem to install it?
Thanks!
FUDForum. Page generated in 0.08852 seconds
