SySML Requirement Diagram creation problem [message #667819] |
Mon, 02 May 2011 06:45  |
Hi all,
I've problems with the Papyrus Model Wizard in Papyrus 0.7.2 and Eclipse 3.6.2.
When I select the option to create a SySML model and then select the Requirement Diagram the wizard doesn't create the model.
Is there a way to solve this?
For reference, the stack trace of the problem should be the following:
java.lang.NoClassDefFoundError: Could not initialize class org.eclipse.papyrus.sysml.requirements.RequirementsPackage
at sun.misc.Unsafe.ensureClassInitialized(Native Method)
at sun.reflect.UnsafeFieldAccessorFactory.newFieldAccessor(UnsafeFieldAccessorFactory.java:25)
at sun.reflect.ReflectionFactory.newFieldAccessor(ReflectionFactory.java:122)
at java.lang.reflect.Field.acquireFieldAccessor(Field.java:918)
at java.lang.reflect.Field.getFieldAccessor(Field.java:899)
at java.lang.reflect.Field.get(Field.java:358)
at org.eclipse.emf.ecore.plugin.RegistryReader$EPackageDescriptor.getEPackage(RegistryReader.java:274)
at org.eclipse.emf.ecore.impl.EPackageRegistryImpl.getEPackage(EPackageRegistryImpl.java:133)
at org.eclipse.uml2.uml.util.UMLUtil.getEPackage(UMLUtil.java:8789)
at org.eclipse.uml2.uml.internal.operations.ProfileOperations.getDefinition(ProfileOperations.java:306)
at org.eclipse.uml2.uml.internal.impl.ProfileImpl.getDefinition(ProfileImpl.java:488)
at org.eclipse.uml2.uml.internal.operations.PackageOperations.applyProfile(PackageOperations.java:524)
at org.eclipse.uml2.uml.internal.impl.PackageImpl.applyProfile(PackageImpl.java:1059)
at org.eclipse.papyrus.umlutils.PackageUtil.applyProfile(PackageUtil.java:97)
at org.eclipse.papyrus.sysml.diagram.common.commands.CreateSysMLModelCommand.initializeModel(CreateSysMLModelCommand.java:56)
at org.eclipse.papyrus.core.extension.commands.ModelCreationCommandBase$2.doExecuteWithResult(ModelCreationCommandBase.java:74)
at org.eclipse.gmf.runtime.emf.commands.core.command.AbstractTransactionalCommand.doExecute(AbstractTransactionalCommand.java:247)
at org.eclipse.emf.workspace.AbstractEMFOperation.execute(AbstractEMFOperation.java:150)
at org.eclipse.core.commands.operations.DefaultOperationHistory.execute(DefaultOperationHistory.java:511)
at org.eclipse.papyrus.core.extension.commands.ModelCreationCommandBase.runAsTransaction(ModelCreationCommandBase.java:80)
at org.eclipse.papyrus.core.extension.commands.ModelCreationCommandBase$1.doExecute(ModelCreationCommandBase.java:47)
at org.eclipse.emf.transaction.RecordingCommand.execute(RecordingCommand.java:135)
at org.eclipse.emf.workspace.EMFCommandOperation.doExecute(EMFCommandOperation.java:119)
at org.eclipse.emf.workspace.impl.WorkspaceCommandStackImpl.doExecute(WorkspaceCommandStackImpl.java:208)
at org.eclipse.emf.transaction.impl.AbstractTransactionalCommandStack.execute(AbstractTransactionalCommandStack.java:165)
at org.eclipse.emf.transaction.impl.AbstractTransactionalCommandStack.execute(AbstractTransactionalCommandStack.java:219)
at org.eclipse.papyrus.core.extension.commands.ModelCreationCommandBase.createModel(ModelCreationCommandBase.java:50)
at org.eclipse.papyrus.wizards.SelectDiagramCategoryPage.initDomainModel(SelectDiagramCategoryPage.java:131)
at org.eclipse.papyrus.wizards.CreateModelWizard.performFinish(CreateModelWizard.java:128)
at org.eclipse.jface.wizard.WizardDialog.finishPressed(WizardDialog.java:811)
at org.eclipse.jface.wizard.WizardDialog.buttonPressed(WizardDialog.java:430)
at org.eclipse.jface.dialogs.Dialog$2.widgetSelected(Dialog.java:624)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:234)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1258)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:3540)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3161)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:825)
at org.eclipse.jface.window.Window.open(Window.java:801)
at org.eclipse.ui.internal.handlers.WizardHandler$New.executeHandler(WizardHandler.java:254)
at org.eclipse.ui.internal.handlers.WizardHandler.execute(WizardHandler.java:274)
at org.eclipse.ui.internal.handlers.HandlerProxy.execute(HandlerProxy.java:293)
at org.eclipse.core.commands.Command.executeWithChecks(Command.java:476)
at org.eclipse.core.commands.ParameterizedCommand.executeWithChecks(ParameterizedCommand.java:508)
at org.eclipse.ui.internal.handlers.HandlerService.executeCommand(HandlerService.java:169)
at org.eclipse.ui.internal.handlers.SlaveHandlerService.executeCommand(SlaveHandlerService.java:241)
at org.eclipse.ui.internal.actions.CommandAction.runWithEvent(CommandAction.java:157)
at org.eclipse.jface.action.ActionContributionItem.handleWidgetSelection(ActionContributionItem.java:584)
at org.eclipse.jface.action.ActionContributionItem.access$2(ActionContributionItem.java:501)
at org.eclipse.jface.action.ActionContributionItem$5.handleEvent(ActionContributionItem.java:411)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2640)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2604)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2438)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:671)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:664)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:115)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:369)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:620)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:575)
at org.eclipse.equinox.launcher.Main.run(Main.java:1408)
at org.eclipse.equinox.launcher.Main.main(Main.java:1384)
FUDForum. Page generated in 0.04192 seconds
