Dependency Problem? [message #667667] |
Sat, 30 April 2011 17:58  |
I have a problem with dependencies on my Web Application.
So, I made an Dynamic Web Application which uses bundles on virgo.
This application provides rest services thanks to Jersey. This services uses bundles on virgo.
This application works perfectly on Linux.
I tried to use it on Windows 7 with the same virgo server and the same .WAR (copy/past/clean/run)
I always get an error saying that it doesn't find a class from a bundle which is in virgo (repository/usr). There is no compile error.
If a comment the line which uses this bundle, no error.
Have you an idea about this problem? Did i forget a step?
[Updated on: Sat, 30 April 2011 18:05] by Moderator
FUDForum. Page generated in 0.03944 seconds
