Home » Eclipse Projects » Buckminster dev » Problem building rcp product with buckminster
Problem building rcp product with buckminster [message #667685] Sun, 01 May 2011 06:34 Go to next message
maybe u can help me:
I have the following problem after executing create.product.zip:
[ant] Cannot complete the install because one or more required items could not be found.
[ant] Software being installed: xy (xy)
[ant] Missing requirement: tooling.osgi.bundle.default 1.0.0 requires 'org.eclipse.equinox.p2.eclipse.type bundle 0.0.0' but it could not be found
[ant] Cannot satisfy dependency:
[ant] From: xy (xy)
[ant] To: tooling.osgi.bundle.default [1.0.0]
I think the error message is clear: He misses the requirement "org.eclipse.equinox.p2.eclipse.type". However, where i can find this requirement??
Thank you.
Lukas L.
Re: Problem building rcp product with buckminster [message #667755 is a reply to message #667685] Mon, 02 May 2011 01:44 Go to previous messageGo to next message
Ok, i found the problem ...
For any purpose the corresponding product feature was deleted from my .product configuration file. As a consequence of this the .product configuration file was empty and led to this error.
Lukas L.
Re: Problem building rcp product with buckminster [message #667756 is a reply to message #667755] Mon, 02 May 2011 02:06 Go to previous messageGo to next message
Hi Lukas,
For future discussions I think it's better if you use our newsgroup
http://www.eclipse.org/forums/eclipse.tools.buckminster as this list is primarily for discussions around development of
Buckminster itself. Chances are you'll get much better answers there.
Thomas Hallgren
> Best regards,
> Lukas L.
Re: [buckminster-dev] Problem building rcp product with buckminster [message #667758 is a reply to message #667756] Mon, 02 May 2011 02:21 Go to previous message
Hi Thomas,
Okay, thank you for the information.
Lukas L.
Am 02.05.2011 08:06, schrieb Thomas Hallgren:
> Hi Lukas,
> is primarily for discussions around development of Buckminster itself.
> Regards,
> Thomas Hallgren
>> Best regards,
>> Lukas L.
> _______________________________________________
> buckminster-dev mailing list
> buckminster-dev@eclipse.org
> https://dev.eclipse.org/mailman/listinfo/buckminster-dev
Previous Topic:[buckminster-dev] Buckminster+Hudson Problem resolving directories in target definition
Next Topic:Buckminster code-base has moved to Git
Current Time: Sun Jul 20 14:39:38 EDT 2025
Powered by FUDForum. Page generated in 0.25869 seconds
