Home » Modeling » M2T (model-to-text transformation) » [Acceleo] Generation templates not working with run-time meta-models and dynamic instances
[Acceleo] Generation templates not working with run-time meta-models and dynamic instances [message #667521] Fri, 29 April 2011 06:42 Go to next message
Hi all,
I have created a dynamic instance model, based on the following meta-model:
module _'MyEcoreModel.ecore'
package myEcoreModel : myEcoreModel = 'http://nl.example.metamodel'
	class SomeClass
		attribute name : String[?] { ordered };
The contents of the instance model is as follows:
<?xml version="1.0" encoding="ASCII"?>
<myEcoreModel:SomeClass
	xmi:version="2.0"
	xmlns:myEcoreModel="http://nl.example.metamodel"
	xsi:schemaLocation="http://nl.example.metamodel ../../model/MyEcoreModel.ecore"
	name="someName"
Next, I have create an Acceleo template to generate some text from the dynamic instance model:
[comment encoding = UTF-8 /]
[module generate('http://nl.example.metamodel')/]
[template public generate(a : SomeClass)]
	[comment @main /]
	[file ('output.txt', false, 'UTF-8')]
	[a.name/]
	[/file]
[/template]
Problem:
The Java class generated from the main generator module, Generate.java contains a compile error in the following code fragment:
	 * This can be used to update the resource set's package registry with all needed EPackages.
	 * @param resourceSet
	 *            The resource set which registry has to be updated.
	 * @generated
	public void registerPackages(ResourceSet resourceSet) {
        super.registerPackages(resourceSet);
        if (!isInWorkspace(org.eclipse.emf.ecore.impl.EPackageImpl.class)) {
            resourceSet.getPackageRegistry().put(org.eclipse.emf.ecore.impl.EPackageImpl.eINSTANCE.getNsURI(), org.eclipse.emf.ecore.impl.EPackageImpl.eINSTANCE);
        // TODO If you need additional package registrations, do them here. The following line is an example for UML.
        // resourceSet.getPackageRegistry().put(UMLPackage.eNS_URI, UMLPackage.eINSTANCE);
The compile error is located on line 291, the line starting with: resourceSet..... and contains the following message:
Multiple markers at this line
	- eINSTANCE cannot be resolved or is not
	 a field
	 a field
Current environment: Eclipse Indigo M6a
Note: i've tested generation using the same meta-model, instance model and generation templates in a Eclipse Helios R2 distribution and experienced no problems there.
Is there something I am doing wrong or is this related to the following bug: https://bugs.eclipse.org/bugs/show_bug.cgi?id=337011?
Kind regards,
Niels Brouwers.
[Updated on: Fri, 29 April 2011 06:42] by Moderator
Re: [Acceleo] Generation templates not working with run-time meta-models and dynamic instances [message #667526 is a reply to message #667521] Fri, 29 April 2011 07:42 Go to previous messageGo to next message
Hi Niels,
The problem has been fixed after M6 (I think the fix is available in M6a). It was related to those bugs:
- https://bugs.eclipse.org/bugs/show_bug.cgi?id=340814
- https://bugs.eclipse.org/bugs/show_bug.cgi?id=340086
The bug that you are linking was for another problem with dynamic metamodels. The fix for this bug will be available in Acceleo 3.1.0 M7 next week.
You may fix it by changing "@generated" in the comment to "@generated NOT" and then remove/change the line.
Stephane Begaudeau, Obeo
Twitter: @sbegaudeau
Acceleo wiki: http://wiki.eclipse.org/Acceleo
Blogs: http://stephanebegaudeau.tumblr.com & http://sbegaudeau.tumblr.com
Re: [Acceleo] Generation templates not working with run-time meta-models and dynamic instances [message #667537 is a reply to message #667526] Fri, 29 April 2011 08:29 Go to previous messageGo to next message
Hi Stephane,
I had already tried that, so I was confused why you suggested the same work-around. First, removing the errornous line did not result in any errors while running the generator, nor did it result in any output.
So, I looked further. The solution was to convert the project containing the meta-model into a plugin project and add this project as dependency to the generator project. This solved the problem. Strange why it did not produce any error somewhere. I've checked the console, problems and error log views.
I would like to suggest to report an error if, for some reason, the meta-model could not be found.
Stephane, thanx for your help!
Kind regards,
Niels Brouwers.
Re: [Acceleo] Generation templates not working with run-time meta-models and dynamic instances [message #667544 is a reply to message #667537] Fri, 29 April 2011 09:15 Go to previous messageGo to next message
Hi Niels,
That specific line should not exist, because EPackageImpl.eINSTANCE does not exist. I have also added an error if we do not generate anything because we have a problem.
Re: [Acceleo] Generation templates not working with run-time meta-models and dynamic instances [message #667734 is a reply to message #667544] Sun, 01 May 2011 16:30 Go to previous message
Hi Stephane,
oke, thanxs for the support.
Kind regards,
Niels Brouwers.
Previous Topic:T2T
Next Topic:[Acceleo] use of macro / let(loop)
Current Time: Fri Jul 18 17:28:36 EDT 2025
Powered by FUDForum. Page generated in 0.06694 seconds
