Riena -> App checklist. [message #667052] |
Tue, 26 April 2011 07:58  |
Hi there,
I just discovered Riena (Yes, I spend some time under rocks :-) and it
seems to be providing a lot of the requirements out of the box for an
existing RCP app I have. Just to be sure, I would like to check with the
community on the following capabilities with Riena.
- Nebula widgets. (Grid and Datchooser I use).
- Charting in a form with SWTChart. (This is an SWT component which is
actually very nice).
- Use of editors, like a generated xtext editor to edit expressions.
(Sounds, this could be a deal breaker...)
- EMF Data binding.
- eclipse CNF. (I know, this requires eclipse.ide, but I need this to
upload and download local files in/from the app). Perhaps Riena has an
elegant alternative to deal with local files?
- Wizards?
Thanks! Christophe
Re: Riena -> App checklist. [message #667340 is a reply to message #667052] |
Thu, 28 April 2011 04:42   |
Hi Christphe,
Am 26.04.11 13:58, schrieb Christophe Bouhier:
> Hi there,
Riena already supports the CompositeTable from Nebula. All you need is to write a ridget. A Ridget is what the
controller deals with when "talking" to the widget in the View. There are already many ridgets in Riena and new ones can
be added by anyone. We can support you there when you want to implement it. Just open a bug and we give you hints on
where to start.
> - EMF Data binding.
The project redView actually uses EMF Data binding together with Riena views and controllers. So it works :-). You find
more information on this in http://ekkescorner.wordpress.com/ I am not that much of a modelling person, but if you have
issues let us know or open a bug. Riena has its own binding API (model to ridget) but uses JFace under the hood. So what
JFace can do can also be accomplished in Riena (more or less)
Not sure what that would mean. Can you embedd CNF components into a regular RCP View. If so then it shouldnt be a problem.
> - Wizards?
If you look here http://wiki.eclipse.org/Riena_Downloads_–_Installation_– _Setup#Set_up_Riena_Toolbox there is a tooling
now for the Eclipse IDE called Riena Toolbox. The Riena Toolbox contains a convient editor for the assemblies but also
wizards for creating a number of Riena projects, so that you can play with them.
> Thanks! Christophe
any more questions let us know....
christian
Re: Riena -> App checklist. [message #667486 is a reply to message #667340] |
Fri, 29 April 2011 01:09  |
Hi Christian,
Ok, sounds good. I will need to dive in the pointers you give me.
rgds Christophe
On 28-04-11 10:42, Christian Campo wrote:
> Hi Christphe,
>> Hi there,
> to write a ridget. A Ridget is what the controller deals with when
> Riena and new ones can be added by anyone. We can support you there when
> you want to implement it. Just open a bug and we give you hints on where
> to start.
>> - EMF Data binding.
> views and controllers. So it works :-). You find more information on
> modelling person, but if you have issues let us know or open a bug.
> hood. So what JFace can do can also be accomplished in Riena (more or less)
>> - Wizards?
> If you look here
> there is a tooling now for the Eclipse IDE called Riena Toolbox. The
> with them.
>> Thanks! Christophe
> christian
FUDForum. Page generated in 0.03419 seconds
