Home » Eclipse Projects » Linux Tools Project » Problem with Oprofile Plugin using Consolehelper(Eclipse Helios with Linux Tools 0.7)
Problem with Oprofile Plugin using Consolehelper [message #667350] Thu, 28 April 2011 05:20 Go to next message
I have installed Linux Tools on Eclipse 3.6.2 but have a problem with the Oprofile Plugin. I use Kubuntu 10.10 and installed the Consolehelper and run successfully the install script. When i start Oprofile in Eclipse i get a Message Box telling me the password i entered is wrong but i never get a Box where i can enter it!
Anyone who can help me?
Re: Problem with Oprofile Plugin using Consolehelper [message #667427 is a reply to message #667350] Thu, 28 April 2011 12:06 Go to previous message
Hi Tobias,
Could you provide a screenshot of that message box? Could you provide me with the precise steps you did? For example, how did you install consolehelper? Did you run install.sh as provided with the Eclipse oprofile plug-in? I'm not sure if it supposed to be working with Kubuntu 10.10 and consolehelper. Could you try install-noconsolehelper.sh instead? Does that work? Have a look at this bug, before you do that, though:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=342880
Let us know how it goes. Thanks!
Severin
Previous Topic:Using encrypted partition
Next Topic:Adding shared library like gtkmm
Current Time: Sat Jul 19 03:05:46 EDT 2025
Powered by FUDForum. Page generated in 0.05262 seconds
