Home » Eclipse Projects » WindowBuilder » WindowBuilder on Eclipse 4.1
WindowBuilder on Eclipse 4.1 [message #666966] Mon, 25 April 2011 03:11 Go to next message
Just for information I've just tested WindowBuilder builds for 3.7 on
the lastest 4.1 I-Build and it works like a charme.
Tom
Re: WindowBuilder on Eclipse 4.1 [message #667134 is a reply to message #666966] Tue, 26 April 2011 20:29 Go to previous messageGo to next message
Thanks for the update. I guess the compatibility layer is pretty good.
Re: WindowBuilder on Eclipse 4.1 [message #667227 is a reply to message #667134] Wed, 27 April 2011 09:54 Go to previous messageGo to next message
Yeah - I found one minor problem which i filed
https://bugs.eclipse.org/bugs/show_bug.cgi?id=343725 for.
Tom
Am 27.04.11 02:29, schrieb Eric Clayberg:
Re: WindowBuilder on Eclipse 4.1 [message #730837 is a reply to message #667227] Thu, 29 September 2011 06:31 Go to previous messageGo to next message
how to download the windows builder menu option for eclipse RCP 4.1 on E4 platform
Parvez Ahmad Hakim
www.abobjects.com
Re: WindowBuilder on Eclipse 4.1 [message #730839 is a reply to message #730837] Thu, 29 September 2011 06:38 Go to previous messageGo to next message
Today I was working on new IDE, in that mercularian one thing that did'nt worked was push gave some strange errors.Checked their bug list, that bug remained fixed by www.javaforge.com but still see that.
I get error when i try to push my changes.
Details :
Internal error Today I was working on new IDE, in that mercularian one thing that did'nt worked was push gave some strange errors.Checked their bug list, that bug remained fixed by www.javaforge.com but still see that.
It seems that jforge has not uploaded the changes. So where can i find Mercularian eclipse with windows binaries for Eclipse 4.1
Parvez Ahmad Hakim
Srinagar Kashmir
www.abobjects.com
Re: WindowBuilder on Eclipse 4.1 [message #730892 is a reply to message #730837] Thu, 29 September 2011 09:22 Go to previous messageGo to next message
Parvez Ahmad Hakim wrote on Thu, 29 September 2011 06:31
I would suggest installing the build for Eclipse 3.7.
Re: WindowBuilder on Eclipse 4.1 [message #731173 is a reply to message #730892] Fri, 30 September 2011 03:47 Go to previous messageGo to next message
Thanks Eric, that worked.
For the window below provides update site links:
http://www.eclipse.org/windowbuilder/download.php
Does some one know why mercularian does not work on eclipse 4
I get below error
3004: Unexpected error occurred.
org.eclipse.e4.core.di.InjectionException: java.lang.ClassCastException: org.eclipse.e4.ui.workbench.modeling.ExpressionContext cannot be cast to org.eclipse.core.expressions.EvaluationContext
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:63)
at org.eclipse.e4.core.internal.di.InjectorImpl.invokeUsingClass(InjectorImpl.java:226)
at org.eclipse.e4.core.internal.di.InjectorImpl.invoke(InjectorImpl.java:207)
at org.eclipse.e4.core.contexts.ContextInjectionFactory.invoke(ContextInjectionFactory.java:123)
at org.eclipse.e4.core.commands.internal.HandlerServiceImpl.executeHandler(HandlerServiceImpl.java:142)
at org.eclipse.e4.ui.workbench.renderers.swt.HandledContributionItem.executeItem(HandledContributionItem.java:704)
at org.eclipse.e4.ui.workbench.renderers.swt.HandledContributionItem.handleWidgetSelection(HandledContributionItem.java:609)
at org.eclipse.e4.ui.workbench.renderers.swt.HandledContributionItem.access$6(HandledContributionItem.java:593)
at org.eclipse.e4.ui.workbench.renderers.swt.HandledContributionItem$3.handleEvent(HandledContributionItem.java:552)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4165)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3754)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:969)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:885)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:87)
at org.eclipse.ui.internal.Workbench$3.run(Workbench.java:539)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:519)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:123)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:344)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:622)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:577)
at org.eclipse.equinox.launcher.Main.run(Main.java:1410)
Caused by: java.lang.ClassCastException: org.eclipse.e4.ui.workbench.modeling.ExpressionContext cannot be cast to org.eclipse.core.expressions.EvaluationContext
at com.vectrace.MercurialEclipse.menu.RootHandler.execute(RootHandler.java:50)
at org.eclipse.ui.internal.handlers.HandlerProxy.execute(HandlerProxy.java:293)
at org.eclipse.ui.internal.handlers.E4HandlerProxy.execute(E4HandlerProxy.java:68)
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:56)
... 33 more
Re: WindowBuilder on Eclipse 4.1 [message #731330 is a reply to message #731173] Fri, 30 September 2011 12:48 Go to previous messageGo to next message
Parvez Ahmad Hakim wrote on Fri, 30 September 2011 03:47
I have no idea. That question would seem to be off topic for this forum. You should try the e4 Forum.
Re: WindowBuilder on Eclipse 4.1 [message #731341 is a reply to message #731173] Fri, 30 September 2011 12:59 Go to previous messageGo to next message
Well it looks like mercularian is blindly casting to EvaluationContext
and Eclipse 4 handlers are passed not an EvaluationContext.
It looks like Mercurial is relying on an implementation detail of the
3.x world. You should file a bug against Mercurial so that they can fix
their code.
Tom
Am 30.09.11 09:47, schrieb Parvez Ahmad Hakim:
> I get below error
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:84)
> at
> at
> at
> org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
> at
> at
> at
> at
> at
> org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149)
> at
> at
> org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)
> at
> at
> at
> at
> at
> at
> ... 33 more
Re: WindowBuilder on Eclipse 4.1 [message #731342 is a reply to message #731341] Fri, 30 September 2011 13:00 Go to previous message
Feel free to give them my e-mail address if they have any question.
Tom
Am 30.09.11 18:59, schrieb Tom Schindl:
> their code.
> Tom
>> I get below error
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
>> at
>> at
>> at
>> at
>> ... 33 more
Re: WindowBuilder on Eclipse 4.1 [message #731343 is a reply to message #731173] Fri, 30 September 2011 12:48 Go to previous message
I have no idea. That question would seem to be off topic for this forum. You should try the http://www.eclipse.org/forums/index.php/f/12/.
Re: WindowBuilder on Eclipse 4.1 [message #731344 is a reply to message #731173] Fri, 30 September 2011 12:59 Go to previous message
their code.
Tom
> I get below error
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 33 more
Re: WindowBuilder on Eclipse 4.1 [message #731345 is a reply to message #731341] Fri, 30 September 2011 13:00 Go to previous message
Tom
> their code.
> Tom
>> I get below error
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> ... 33 more
Previous Topic:Zipped Update Site has external dependencies?
Next Topic:RTL support in WindowBuilder
Current Time: Sat Jul 26 01:10:18 EDT 2025
Powered by FUDForum. Page generated in 0.05871 seconds
