Re: Doing a jdk5 build with jdk6, best practises? [message #667283 is a reply to message #667219] |
Wed, 27 April 2011 16:58  |
On 2011-04-27 15:58:53 +0200, Thomas Kratz said:
> Hi I'm just getting my head into building with buckminster. I need to
> build jdk5 compliant (old Mac users...) but due to a strange bug with
> jdk5 (I could google someone having the same one) buckminster fails to
> resolve a local resource with jdk5. so I switched buckminster to run on
> jdk6 and everything builds fine now. But I didn't find any hints on how
> to make the jdk6 buckminster do a jdk5 compliant build. Can someone
> give me pointers what would be the best way to do that ? I think I need
> to perform an install of the jre, but how do I set the compiler options
> Any help will be appreciated, as always :)
> Regards Thomas
Hi Thomas,
you can enable the project specific compiler settings for this project
and set the 'Compiler compliance level' to 1.5 (open Context Menu of
the Project -> Properties -> Java Compiler). Buckminster will then use
these settings as well.
-Matthias
FUDForum. Page generated in 0.03411 seconds
