setting up eclipse [message #666955] |
Mon, 25 April 2011 00:48  |
hi,
I have windows 7, 64 bit. I downloaded the appropriate eclipse version for php and also downloaded the JRE that is needed...
But when I click on the eclipse.exe file it says that the JRE is not found on my machine...?
I am not sure how to fix this. Any suggestions?
please let me know if you need any additional info to help help
thank you,
Re: setting up eclipse [message #667066 is a reply to message #666996] |
Mon, 25 April 2011 16:19  |
On 4/25/11 8:23 AM, Russell Bateman wrote:
> On 2011.04.24 22:48, rebm@optonline.net wrote:
>> hi,
>> thank you,
> http://wiki.eclipse.org/Eclipse.ini
Also make sure that you downloaded matching versions of Eclipse and the
JRE/JDK: they must be either both 32-bit or both 64-bit - can't
mix-and-match the "bit-ness."
Eric
FUDForum. Page generated in 0.10070 seconds
