Home » Eclipse Projects » Eclipse Platform » How to build Eclipse for SPARC/Linux from source code
How to build Eclipse for SPARC/Linux from source code [message #666950] Sun, 24 April 2011 22:35 Go to next message
Hi all,
I would like to run Eclipse on SPARC T2/Linux platform. But there is no binary release of Eclipse for this platform, so I have to build it from source code.
I have downloaded eclipse-sourceBuild-srcIncluded-3.5.2.zip from Eclipse archieves. However, there is no existing support for SPARC/Linux platform within the source code. The build process failed with many errors.
How can I build Eclipse for SPARC/Linux platform (with OpenJDK 1.7 ) ?
Any suggestion will be appreciated.
Jie
Re: How to build Eclipse for SPARC/Linux from source code [message #667005 is a reply to message #666950] Mon, 25 April 2011 08:38 Go to previous message
There's no SPARC/Linux listed at
http://download.eclipse.org/eclipse/downloads/drops/R-3.6.2- 201102101200/index.php,
the closest there is SPARC/GTK2 (Solaris 10). Will that one work?
If no and you really need to include a new platform, you're going to
have to hack and compile C code first. i.e. you'll have to work through
the build errors and re-compile SWT correctly for your platform.
http://dev.eclipse.org/mhonarc/lists/eclipse-dev/msg09114.ht ml
PW
Paul Webster
http://wiki.eclipse.org/Platform_Expression_Framework
http://help.eclipse.org/helios/index.jsp?topic=/org.eclipse. platform.doc.isv/guide/workbench.htm
Previous Topic:Custom intelligent java template
Next Topic:UpdateManager Reconciling
Current Time: Sun Jul 27 13:44:06 EDT 2025
Powered by FUDForum. Page generated in 0.06382 seconds
