Home » Eclipse Projects » Rich Client Platform (RCP) » Adding menu item to Project Explorer's drop down menu
icon7.gif  Adding menu item to Project Explorer's drop down menu [message #666721] Thu, 21 April 2011 18:51 Go to next message
With eclipse 3.6.1, I believe I can contribute menu to project explorer view's drop down list. The extension point description for org.eclipse.ui.viewActions states that we can now use org.eclipse.ui.menus to place commands in menus and toolbars as well. So, I define a new menu contribution under org.eclipse.ui.menus extension point. I specified the location URI as popup:org.eclipse.ui.navigator.ProjectExplorer#PopupMenu?aft er=group.open, class = "" and allPopups = true. Under menu contribution, I have my menu (it's a dynamic cascading menu). I do not see my menu in the drop down for the project explorer. Am I missing something? Can someone point me to the correct procedure if I am doing it wrong?
Thanks!
Re: Adding menu item to Project Explorer's drop down menu [message #666993 is a reply to message #666721] Mon, 25 April 2011 08:01 Go to previous messageGo to next message
The view dropdown menu has a location of
menu:org.eclipse.ui.navigator.ProjectExplorer
PW
Paul Webster
http://wiki.eclipse.org/Platform_Expression_Framework
http://help.eclipse.org/helios/index.jsp?topic=/org.eclipse. platform.doc.isv/guide/workbench.htm
Re: Adding menu item to Project Explorer's drop down menu [message #667266 is a reply to message #666993] Wed, 27 April 2011 14:13 Go to previous message
Thank you very much Paul. That helps!
Previous Topic:Patching a third party bundle with fragment
Next Topic:CNF extension for export wizard and working set
Current Time: Sun Jul 27 16:21:11 EDT 2025
Powered by FUDForum. Page generated in 0.03776 seconds
