Java Compile problem [message #666439] |
Wed, 20 April 2011 09:28  |
Hello all, I'm trying to learn how to use eclipse.
I've installed the Europa version along with the IBM Java SDK. I've written a Java application via the Eclipse editor
and now I want to compile it. I;ve created a project. Eclipse can "see" the path to the javac compiler, but I'm unable to
get my program compiled, I have build automatic set ON
I've tried the RUN button, and every other combination.
I keep getting messages such as "unable to launch"
(what ever that means) ..no previous launches
there's another message about missing "pages" (I think)
any suggestions would be most appreciated.
GUy
Re: Java Compile problem [message #666453 is a reply to message #666439] |
Wed, 20 April 2011 09:34   |
On 2011.04.20 7:28, Guy wrote:
> Hello all, I'm trying to learn how to use eclipse. I've installed the
> the path to the javac compiler, but I'm unable to get my program
> Thanks
> GUy
If you're just starting out, why not install modern Eclipse. Europa was
followed by Ganymeade, Galileo and Helios. Indigo is about to be
released. Europa works, but most of the community is eager to support
much later releases in this forum.
Second, use only a Sun JDK unless there's some reason you must use another.
I'd suggest taking a look at
http://www.javahotchocolate.com/tutorials/eclipse-summary.ht ml, then
doing a couple of tutorials athttp://www.vogella.de/eclipse.htm
And come back here when you get stuck.
Best of luck.
Re: Java Compile problem [message #755761 is a reply to message #666790] |
Wed, 09 November 2011 09:07  |
I am also trying to do some SNA development using CPIC but can't find the right version of Europa in which is contained the appropriate jars.
Could you point me in the right direction please?
Alastair
FUDForum. Page generated in 0.09751 seconds
