Home » Eclipse Projects » Standard Widget Toolkit (SWT) » TrayIcon Redraw?
TrayIcon Redraw? [message #666412] Wed, 20 April 2011 07:24 Go to next message
I'm trying to write a little program that uses a TrayIcon. I want to change the image there when something happens.
I assign a new image to it though, and the icon doesn't update or redraw. The only way I can get it to do so is to mouse over, which defeats the whole object.
I tried disposing and instantiating a new TrayIcon, that doesn't work either.
This is on Win32 by the way.
Is this a bug? Should I be calling some extra method? (I've tried setVisible as well).
Re: TrayIcon Redraw? [message #666608 is a reply to message #666412] Thu, 21 April 2011 06:01 Go to previous messageGo to next message
There is no TrayIcon class in SWT, did you mean TrayItem?
Updating the tray item's image works fine for me on Windows XP. Here is an example snippet of TrayItem -> Snippet143.java
I tried to change the image by using this code in the above snippet, and it works fine. Does it work for you?
shell.addListener(SWT.MouseDown, new Listener() {
public void handleEvent(Event event) {
item.setImage(display.getSystemImage(SWT.ICON_ERROR));
Re: TrayIcon Redraw? [message #666609 is a reply to message #666608] Thu, 21 April 2011 06:06 Go to previous messageGo to next message
Yeah, sorry, I meant TrayItem.
In your code, you're changing it from a mouse event on the TrayItem?
Try changing it from a timer or a button press in another window. I'm on XP, and in those cases, it doesn't work.
[Updated on: Thu, 21 April 2011 06:07] by Moderator
Re: TrayIcon Redraw? [message #666612 is a reply to message #666609] Thu, 21 April 2011 06:12 Go to previous messageGo to next message
Am 21.04.11 12:06, schrieb gareth.foster@thomsonreuters.com:
> In you're code, you're changing it from a mouse event on the TrayItem?
Timer? Makes me wonder of you are not syncing with the UI-Thread.
Tom
Re: TrayIcon Redraw? [message #666621 is a reply to message #666612] Thu, 21 April 2011 06:52 Go to previous messageGo to next message
I think I just went part way to solving this by writing a stripped down test case.
Even though the timer fires and changes the value of iTest, the code doesn't get to changing the icon until I mouseover, because it's stuck in the readAndDispatch/sleep methods.
What do I need to do to kick it out of there?
class CMain {
int iTest = 1;
public void test() {
final Display display = Display.getDefault();
Tray tray = display.getSystemTray();
TrayItem trayItem = new TrayItem(tray, SWT.NONE);
trayItem.setImage(display.getSystemImage(SWT.ICON_ERROR));
Timer timer = new Timer();
timer.scheduleAtFixedRate(new TimerTask() {
public void run() {
++ iTest;
} }, 0, 60 * 1000);
while (true) {
if (!Display.getDefault().readAndDispatch())
Display.getDefault().sleep();
if(iTest % 2 == 0) {
trayItem.setImage(display.getSystemImage(SWT.ICON_INFORMATIO N));
} else {
Re: TrayIcon Redraw? [message #666626 is a reply to message #666621] Thu, 21 April 2011 07:27 Go to previous messageGo to next message
Solved it, the solution was to use wake(), as talked about half way down this page.
http://book.javanb.com/swt-the-standard-widget-toolkit/ch05l ev1sec6.html
Re: TrayIcon Redraw? [message #666630 is a reply to message #666621] Thu, 21 April 2011 07:31 Go to previous messageGo to next message
Am 21.04.11 12:52, schrieb gareth.foster@thomsonreuters.com:
> test case.
To make your test code run you'd have to invoke Display.wake() in your
TimerTask but I really don't understand why you you're not doing the
update from withing your TimerTask which makes whole lot more to me:
new TimerTask {
public void run() {
final int i = ++ iTest;
display.syncExec(new Runnable() {
public void run() {
if(i % 2 == 0) {
trayItem.setImage(
display.getSystemImage(SWT.ICON_INFORMATION));
} else {
trayItem.setImage(
Tom
Re: TrayIcon Redraw? [message #666644 is a reply to message #666630] Thu, 21 April 2011 08:40 Go to previous messageGo to next message
I tried doing the update from there, it blew up moaning about accessing SWT widgets from outside the main thread. I thought I'd read this wasn't allowed?
Re: TrayIcon Redraw? [message #666651 is a reply to message #666644] Thu, 21 April 2011 08:49 Go to previous messageGo to next message
That's why you see a display.syncExec() in there which allows you to
sync back from an thread into the UI one.
Tom
Am 21.04.11 14:40, schrieb gareth.foster@thomsonreuters.com:
> allowed?
Re: TrayIcon Redraw? [message #666652 is a reply to message #666644] Thu, 21 April 2011 08:50 Go to previous message
and one more not you can use Display#timerExec so avoid all the thread
syncing stuff.
> allowed?
Previous Topic:Remove a menu item
Next Topic:SWT on Windows XP Tablet PC Edition
Current Time: Fri Jul 18 12:57:10 EDT 2025
Powered by FUDForum. Page generated in 0.05095 seconds
