Home » Eclipse Projects » Eclipse Platform » SOLVED: Problems installing plugins(Problems installing plugins into Eclipse v3.5.2)
SOLVED: Problems installing plugins [message #531456] Wed, 05 May 2010 00:44 Go to next message
I have installed the base Eclipse SDK package on Ubuntu 10.04 with no language IDE's present.
Now when I try to install language IDE's (eg. PHP and Aptana Studio v2) I get the following error:
!ENTRY org.eclipse.equinox.p2.updatesite 4 0 2010-05-05 04:53:32.737
!MESSAGE Error reading feature http://download.eclipse.org/tptp/updates/features/org.eclips e.tptp.test_4.3.0.v200610310100--4hNDDhHNFUEMEM.jar.
!ENTRY org.eclipse.equinox.p2.engine 4 4 2010-05-05 05:19:03.164
!MESSAGE An error occurred while installing the items
!SUBENTRY 1 org.eclipse.equinox.p2.engine 4 0 2010-05-05 05:19:03.165
!MESSAGE session context was:(profile=PlatformProfile, phase=org.eclipse.equinox.internal.provisional.p2.engine.pha ses.Install, operand=null --> [R]org.eclipse.cvs 1.0.400.v201002111343, action=org.eclipse.equinox.internal.p2.touchpoint.eclipse.ac tions.InstallBundleAction).
!SUBENTRY 1 org.eclipse.equinox.p2.touchpoint.eclipse 4 0 2010-05-05 05:19:03.165
!MESSAGE The artifact file for osgi.bundle,org.eclipse.cvs,1.0.400.v201002111343 was not found.
Any ideas why this might be happening?
Thanks In Advance
Andrew Jones
[Updated on: Wed, 05 May 2010 07:16] by Moderator
Re: Problems installing plugins [message #531475 is a reply to message #531456] Wed, 05 May 2010 03:48 Go to previous messageGo to next message
You have to install the eclipse-pde, jdt and plugin-cvs packages before installing subversive. If you installed eclipse from the SoftwareCentre, it has not included all of these packages. If you use synaptic and search you will see these missing packages and can install from there.
HTH
Alan
Re: Problems installing plugins [message #531523 is a reply to message #531475] Wed, 05 May 2010 06:20 Go to previous messageGo to next message
Hi Alan, thanks for the response. I installed via Synaptic, and yes when I search Synaptic again those packages are not marked as installed. Will install now and let you know how I get on.
Odd though that they were'nt installed as dependencies?
Andrew
Re: Problems installing plugins [message #531538 is a reply to message #531475] Wed, 05 May 2010 07:15 Go to previous messageGo to next message
Hi Alan, just letting you know that all is well and working as expected now.
Thanks again.
Andrew
Re: SOLVED: Problems installing plugins [message #532357 is a reply to message #531456] Sat, 08 May 2010 15:48 Go to previous messageGo to next message
Just wanted to say "Thanks" to Alan. Got Eclipse through the Ubuntu Software Center and had the same problem as above.
This may be the wrong place to ask but does anyone know why PDE isn't included with the Eclipse package installed by the USC?
Re: SOLVED: Problems installing plugins [message #666562 is a reply to message #532357] Wed, 20 April 2011 21:38 Go to previous messageGo to next message
I have the same issue. Unfortunately I don't know what synaptic is yet so I have more work to do to get eclipse to work with android sdk pluggins. Too bad it just doesn't work. I've tried the first ecliplse download. Then did the classic as per developer.android.com/eclipse-adt.html#installing
I bought a book, but all its links are outdated. A list of where to go to get the software to develop hello world for Android would be great. One without bugs.
Re: SOLVED: Problems installing plugins [message #666564 is a reply to message #666562] Wed, 20 April 2011 22:30 Go to previous message
Ahh; System Administrator Synaptic Package Manager then search for eclipse and it sellected everything needed. Much better than http://developer.android.com/ instructions to download from www.eclipse.org/downloads.
Package manager found cvs, jdt, and pde. Trying to find these packages within the downloaded eclipse didn't work. Under Help Install Software sellecting all available sites, the only cvs I found was for Buckminster. jdt returned nothing and you needed to look under Java Development Tools. Then it said that some of my selections were already installed. Probably because I was missing mainly the cvs...
Using Synaptic Package Manager under ubuntu was much simpler. Thanks for the clues.
Previous Topic:Console view causes null pointer exception
Next Topic:Problem with running as configurations on Eclipse HELIOS
Current Time: Sat Jul 26 01:17:19 EDT 2025
Powered by FUDForum. Page generated in 0.08348 seconds
