Home » Modeling » EMF » Custom XML handler
Custom XML handler [message #666539] Wed, 20 April 2011 15:23 Go to next message
I want to use a custom XML handler for my EMF models that extends the XML handler from EMF.
Currently my approach is basically the following:
a) let my generated ExampleResourceImpl extend from my class XMLResourceImpl2 instead of the EMF class XMLResourceImpl. My class XMLResourceImpl2 looks like this:
public class XMLResourceImpl2 extends XMLResourceImpl {
	public XMLResourceImpl2(URI uri) { super(uri); }
	protected XMLLoad createXMLLoad() {
		return new XMLLoadImpl2(createXMLHelper());
b) let class XMLLoadImpl2 then return the desired handler MyXMLHandler, which extends the EMF SAXXMLHandler:
public class XMLLoadImpl2 extends XMLLoadImpl {
	public XMLLoadImpl2(XMLHelper helper) { super(helper); }
	protected DefaultHandler makeDefaultHandler() {
		return new MyXMLHandler(helper);
Is this approach correct or should I doing it completely different to replace the XML handler?
If that is the suggested way, I'm wondering if I can somehow configure in the ecore or genmodel that I want to use a custom base class for the resource handling.
The only option that comes close to that is the "Resource Type" property in the genmodel which is available on the package element.
But here I can only select between NONE, BASIC, XML and XMI, but I cannot specify a concrete implementation base class.
So if there is no way to configure that in the ecore/genmodel, I assume I need to
1) select XML as resource type
2) generate my models
3) in the generated XYResourceImpl classes change "extends XMLResourceImpl" to "extends XMLResourceImpl" and remove the @generated tag attached to the class header
Is that also the correct approach?
Best regards
Jens
Re: Custom XML handler [message #666639 is a reply to message #666539] Thu, 21 April 2011 08:16 Go to previous message
Jens,
Comments below.
Jens Keller wrote:
> @Override
> @Override
That's the way.
> assume I need to
These look identical to me...
It sounds okay.
> Best regards
> Jens
Previous Topic:TableViewer binding
Next Topic:Optimize menu entries
Current Time: Fri Jul 18 07:45:00 EDT 2025
Powered by FUDForum. Page generated in 0.04734 seconds
