Home » Newcomers » Newcomers » Java Compile problem(Unable to compile my java program within eclipse(Europa))
Java Compile problem [message #666439] Wed, 20 April 2011 09:28 Go to next message
Hello all, I'm trying to learn how to use eclipse.
I've installed the Europa version along with the IBM Java SDK. I've written a Java application via the Eclipse editor
and now I want to compile it. I;ve created a project. Eclipse can "see" the path to the javac compiler, but I'm unable to
get my program compiled, I have build automatic set ON
I've tried the RUN button, and every other combination.
I keep getting messages such as "unable to launch"
(what ever that means) ..no previous launches
there's another message about missing "pages" (I think)
any suggestions would be most appreciated.
GUy
Re: Java Compile problem [message #666453 is a reply to message #666439] Wed, 20 April 2011 09:34 Go to previous messageGo to next message
On 2011.04.20 7:28, Guy wrote:
> Hello all, I'm trying to learn how to use eclipse. I've installed the
> the path to the javac compiler, but I'm unable to get my program
> Thanks
> GUy
If you're just starting out, why not install modern Eclipse. Europa was
followed by Ganymeade, Galileo and Helios. Indigo is about to be
released. Europa works, but most of the community is eager to support
much later releases in this forum.
Second, use only a Sun JDK unless there's some reason you must use another.
I'd suggest taking a look at
http://www.javahotchocolate.com/tutorials/eclipse-summary.ht ml, then
doing a couple of tutorials athttp://www.vogella.de/eclipse.htm
And come back here when you get stuck.
Best of luck.
Re: Java Compile problem [message #666569 is a reply to message #666453] Thu, 21 April 2011 00:26 Go to previous messageGo to next message
I use IBM JDK everyday, it should not be a problem. Plus Eclipse has its
own compiler so it does not matter if it can see javac or not.
I suspect you need to create a launch configuration, or invoke Run from
the context menu (Right click in the java editor and select run).
Re: Java Compile problem [message #666790 is a reply to message #666453] Fri, 22 April 2011 11:28 Go to previous messageGo to next message
Hi Russell & Deepak thanks for your suggestions and
comments.
The Europa version of Eclipse came with the IBM Communications Server 6.4; the system also came with a
JRE, and Java 1.6, and a set of IBM CPI-C API's for Java.
(The reason it was acquired). Unfortunately I really don't
have the time to download and install the latest and greatest version of Eclipse. Since Europa does work,
I'm just trying to learn how to get it compile my source code, and list the output of the compiler. Deepak, I'm very happy that you work with the IBM SDK w/o any problems.
However, that's not the case for me.
However I'll keep "fiddlin'" with it ..
Guy
Re: Java Compile problem [message #755761 is a reply to message #666790] Wed, 09 November 2011 09:07 Go to previous message
I am also trying to do some SNA development using CPIC but can't find the right version of Europa in which is contained the appropriate jars.
Could you point me in the right direction please?
Alastair
Previous Topic:The specified JRE installation does not exist
Next Topic:how do i open a page from search result in new tab?
Current Time: Sun Jul 27 15:27:13 EDT 2025
Powered by FUDForum. Page generated in 0.37446 seconds
