Home » Eclipse Projects » Rich Client Platform (RCP) » CRT+A / CTR+Z / CTR+Y are not caught by a keylistner in a wizard
CRT+A / CTR+Z / CTR+Y are not caught by a keylistner in a wizard [message #666447] Wed, 20 April 2011 09:40 Go to next message
I'm developping a RCP application.
My application mange undo/redo cut/copy paste in my editors/views. everything is ok.
Now, I would like to manage these actions in some of my wizards.
I have a wizard with a TreeViewer.
I've added popup menu and key listeners to manage the cut/copy/paste and the undo/redo operations.
I have a problem for the undo/redo shortcuts: they are not detected by my key listener.
Here is my code:
mComputationTreeViewer.getControl().addKeyListener(new KeyListener() {
	public void keyReleased(KeyEvent e) {}
	public void keyPressed(KeyEvent e) {
		if((e.keyCode == 'c') && (e.stateMask == SWT.CTRL)) {
                       mCopyAction.run();
                }else if((e.keyCode == 'v') && (e.stateMask == SWT.CTRL)) {
                       mPasteAction.run();
                }else if((e.keyCode == 'z') && (e.stateMask == SWT.CTRL)) {
                       // Never call, WHY ????
                       mUndoAction.run();
                }else if((e.keyCode == 'y') && (e.stateMask == SWT.CTRL)) {
                       mRedoAction.run();
If somebody has any suggestion...
Thank you.
Philippe B.
PS: I'm working on Eclipse 3.5
Re: CRT+A / CTR+Z / CTR+Y are not caught by a keylistner in a wizard [message #666458 is a reply to message #666447] Wed, 20 April 2011 09:56 Go to previous messageGo to next message
Eclipse RCP uses the keybinding system along with commands and handlers.
undo and redo are bound to commands in the dialogAndWindows context,
which means they're eaten by the keybinding system before they'll get to
your wizard.
You can activate and then deactivate handlers for the undo and redo
commands in your wizard.
PW
Paul Webster
http://wiki.eclipse.org/Platform_Expression_Framework
http://help.eclipse.org/helios/index.jsp?topic=/org.eclipse. platform.doc.isv/guide/workbench.htm
icon14.gif  Re: CRT+A / CTR+Z / CTR+Y are not caught by a keylistner in a wizard [message #666474 is a reply to message #666458] Wed, 20 April 2011 10:32 Go to previous message
Hello Paul,
Thank you for your explanation.
So i found a previous post where your explain how to activate/deactivate a handler:
http://www.eclipsezone.com/eclipse/forums/t75054.html
Here is my code in my wizard:
// Handler activation
IHandlerService service = (IHandlerService) PlatformUI.getWorkbench().getService(IHandlerService.class);
AbstractHandler handler = new AbstractHandler() {
			public Object execute(ExecutionEvent event) throws ExecutionException {
				mUndoAction.run();
				return null;
IHandlerActivation handlerActivation = service.activateHandler("org.eclipse.ui.edit.undo", handler, new ActiveShellExpression(getShell()));
// Handler deactivation
service.deactivateHdanler(handlerActivation);
handlerActivation.getHandler().dispose();
Thank you very much.
Philippe B.
Previous Topic:Start eclipse on Windows 7
Next Topic:DND with multiple Transfer Types
Current Time: Sun Aug 31 09:30:14 EDT 2025
Powered by FUDForum. Page generated in 0.03201 seconds
