Home » Language IDEs » ServerTools (WTP) » IWAB0523E Error moving resource: ...... Could not read from source when writing file
icon4.gif  IWAB0523E Error moving resource: ...... Could not read from source when writing file [message #666427] Wed, 20 April 2011 08:50 Go to next message
Hi Guys;
I have been getting a strange error when I try to create a webservice client.
here is the exception I get...
IWAB0523E Error moving resource: Could not read from source when writing file 'C:\Users\aydin.toprak\workspace\PP\src\mc_style\functions\soap\sap\document\sap_com\ZMM_read_sas_data.java'
    org.eclipse.core.internal.resources.ResourceException(C:/Users/aydin.toprak/workspace/PP/src/mc_style/functions/soap/sap/document/sap_com/ZMM_read_sas_data.java)[271]: java.io.IOException: Cannot create a file when that file already exists
    at java.io.FileInputStream.readBytes(Native Method)
    at java.io.FileInputStream.read(Unknown Source)
    at org.eclipse.core.internal.utils.FileUtil.transferStreams(FileUtil.java:231)
    at org.eclipse.core.internal.localstore.FileSystemResourceManager.write(FileSystemResourceManager.java:1001)
    at org.eclipse.core.internal.resources.File.internalSetContents(File.java:325)
    at org.eclipse.core.internal.resources.File.setContents(File.java:364)
    at org.eclipse.core.internal.resources.File.setContents(File.java:468)
    at org.eclipse.wst.command.internal.env.common.FileResourceUtils.makeFile(FileResourceUtils.java:709)
    at org.eclipse.wst.command.internal.env.common.FileResourceUtils.createFileAtLocation(FileResourceUtils.java:770)
    at org.eclipse.jst.ws.internal.axis.consumption.core.command.WSDL2JavaCommand.moveGeneratedFiles(WSDL2JavaCommand.java:327)
    at org.eclipse.jst.ws.internal.axis.consumption.core.command.WSDL2JavaCommand.execute(WSDL2JavaCommand.java:250)
    at org.eclipse.jst.ws.internal.axis.consumption.ui.task.ClientCodeGenOperation$ClientWSModifyOperation.execute(ClientCodeGenOperation.java:102)
    at org.eclipse.jst.ws.internal.axis.consumption.ui.task.ClientCodeGenOperation.execute(ClientCodeGenOperation.java:64)
    at org.eclipse.wst.command.internal.env.core.fragment.CommandFragmentEngine.runCommand(CommandFragmentEngine.java:419)
    at org.eclipse.wst.command.internal.env.core.fragment.CommandFragmentEngine.visitTop(CommandFragmentEngine.java:359)
    at org.eclipse.wst.command.internal.env.core.fragment.CommandFragmentEngine.moveForwardToNextStop(CommandFragmentEngine.java:254)
    at org.eclipse.wst.command.internal.env.ui.widgets.SimpleCommandEngineManager$6.run(SimpleCommandEngineManager.java:294)
    at org.eclipse.jface.operation.ModalContext.runInCurrentThread(ModalContext.java:464)
    at org.eclipse.jface.operation.ModalContext.run(ModalContext.java:372)
    at org.eclipse.jface.wizard.WizardDialog.run(WizardDialog.java:1008)
    at org.eclipse.wst.command.internal.env.ui.widgets.SimpleCommandEngineManager.runForwardToNextStop(SimpleCommandEngineManager.java:264)
    at org.eclipse.wst.command.internal.env.ui.widgets.WizardPageManager.runForwardToNextStop(WizardPageManager.java:91)
    at org.eclipse.wst.command.internal.env.ui.widgets.WizardPageManager.performFinish(WizardPageManager.java:262)
    at org.eclipse.wst.command.internal.env.ui.widgets.DynamicWizard.performFinish(DynamicWizard.java:382)
    at org.eclipse.jface.wizard.WizardDialog.finishPressed(WizardDialog.java:811)
    at org.eclipse.jface.wizard.WizardDialog.buttonPressed(WizardDialog.java:430)
    at org.eclipse.jface.dialogs.Dialog$2.widgetSelected(Dialog.java:624)
    at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:234)
    at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
    at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4066)
    at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3657)
    at org.eclipse.jface.window.Window.runEventLoop(Window.java:825)
    at org.eclipse.jface.window.Window.open(Window.java:801)
    at org.eclipse.ui.internal.handlers.WizardHandler$New.executeHandler(WizardHandler.java:254)
    at org.eclipse.ui.internal.handlers.WizardHandler.execute(WizardHandler.java:274)
    at org.eclipse.ui.internal.handlers.HandlerProxy.execute(HandlerProxy.java:293)
    at org.eclipse.core.commands.Command.executeWithChecks(Command.java:476)
    at org.eclipse.core.commands.ParameterizedCommand.executeWithChecks(ParameterizedCommand.java:508)
    at org.eclipse.ui.internal.handlers.HandlerService.executeCommand(HandlerService.java:169)
    at org.eclipse.ui.internal.handlers.SlaveHandlerService.executeCommand(SlaveHandlerService.java:241)
    at org.eclipse.ui.internal.actions.CommandAction.runWithEvent(CommandAction.java:157)
    at org.eclipse.jface.action.ActionContributionItem.handleWidgetSelection(ActionContributionItem.java:584)
    at org.eclipse.jface.action.ActionContributionItem.access$2(ActionContributionItem.java:501)
    at org.eclipse.jface.action.ActionContributionItem$5.handleEvent(ActionContributionItem.java:411)
    at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2640)
    at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2604)
    at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2438)
    at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:671)
    at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:664)
    at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:115)
    at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:369)
    at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:620)
    at org.eclipse.equinox.launcher.Main.basicRun(Main.java:575)
    at org.eclipse.equinox.launcher.Main.run(Main.java:1408)
What might couse this ?
Any ideas ?
My environment as follows
Version: Helios Service Release 2
Build id: 20110218-0911
I have tried this on Galileo version but get exacty same error ...
Thank you
Re: IWAB0523E Error moving resource: ...... Could not read from source when writing file [message #669563 is a reply to message #666427] Tue, 10 May 2011 14:19 Go to previous message
I suggest you file a bug report with more information about what you were attempting.
Previous Topic:File paths in static web project
Next Topic:JSDT calling Java from Javascript - How to set Java Classpath for Rhino?
Current Time: Sun Aug 31 16:47:23 EDT 2025
Powered by FUDForum. Page generated in 0.02947 seconds
