Home » Eclipse Projects » EclipseLink » (eclipse helios,mandriva) Schema "dbo" cannot be resolved for table "t_address"(automatic generation of tables => error near @table annotation)
(eclipse helios,mandriva) Schema "dbo" cannot be resolved for table "t_address" [message #666017] Mon, 18 April 2011 12:09 Go to next message
hello,
I'm using eclipse helios on mandriva 2010.2 with SQL Anywhere.
I created a JPA project (with an EJB project aimed at manage the JPA project on a JBOSS server but it's not really the matter now).
there are many entities and this persistence.xml :
<persistence version="2.0" xmlns="http://java.sun.com/xml/ns/persistence" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="http://java.sun.com/xml/ns/persistence http://java.sun.com/xml/ns/persistence/persistence_2_0.xsd">
	<persistence-unit name="jpa_soho_2">
		<jta-data-source>java:SybaseDB</jta-data-source>
		<class>entities.Address</class>
		<class>entities.Category</class>
		<class>entities.CreditCard</class>
		<class>entities.Customer</class>
		<class>entities.Item</class>
		<class>entities.Order</class>
		<class>entities.OrderLine</class>
		<class>entities.Product</class>
		<class>entities.ValidationException</class>
		<properties>
			<property name="eclipselink.ddl-generation" value="drop-and-create-tables"/>
			<property name="eclipselink.ddl-generation.output-mode" value="database"/>
			<property name="eclipselink.orm.validate.schema" value="false"/>
			<property name="eclipselink.target-database" value="Sybase"/>
			<property name="eclipselink.target-server" value="JBoss"/>
		</properties>
	</persistence-unit>
</persistence>
and here is the DS file (on JBOSS):
<!--  JBoss Server Configuration                                           -->
<!-- New ConnectionManager setup for Sybase ASE/ASA jConnect driver        -->
<!-- Thanks to Marc Zampetti <zampetti@aol.net>                            -->
<!-- This is a minimal example.  See the generic example for other stuff   -->
<!-- $Id: sybase-ds.xml 23720 2004-09-15 14:37:40Z loubyansky $ -->
<datasources>
  <local-tx-datasource>
    <jndi-name>jdbc/SybaseDB</jndi-name>
    <!-- Sybase jConnect URL for the database.
    NOTE: The hostname and port are made up values. The optional
          database name is provided, as well as some additinal Driver
          parameters.
    <connection-url>jdbc:sybase:Tds:localhost:2638/DB_numberOne_db?JCONNECT_VERSION=6</connection-url>
    <driver-class>com.sybase.jdbc2.jdbc.SybDataSource</driver-class>
    <user-name>olivier_DBA</user-name>
    <password>olivier</password>
    <exception-sorter-class-name>org.jboss.resource.adapter.jdbc.vendor.SybaseExceptionSorter</exception-sorter-class-name>
        <!-- sql to call when connection is created
        <new-connection-sql>some arbitrary sql</new-connection-sql>
        <!-- sql to call on an existing pooled connection when it is obtained from pool
        <check-valid-connection-sql>some arbitrary sql</check-valid-connection-sql>
      <!-- corresponding type-mapping in the standardjbosscmp-jdbc.xml (optional) -->
      <metadata>
         <type-mapping>Sybase</type-mapping>
      </metadata>
  </local-tx-datasource>
</datasources>
Eclipse allows me to create the tables from the entities, but when I do so I've got these errors near the annotation @table (of each entity) :
I really don't know how to find the answer.
can you help me?
Re: (eclipse helios,mandriva) Schema "dbo" cannot be resolved for table "t_address&qu [message #666067 is a reply to message #666017] Mon, 18 April 2011 17:04 Go to previous messageGo to next message
First try re-validating the project by right-clicking on the project and selecting "Validate". This will ensure that the validation isn't stale as sometimes the project won't be correctly validated after generating tables due to a Dali bug.
If that doesn't work, go to the project properties and override the default catalog and schema as necessary to match you DB connection (this is necessary if our built-in defaults are not able to resolve). After making these changes the project should re-validate and may resolve your issues.
Let me know if this doesn't resolve your validation issue.
Neil
Re: (eclipse helios,mandriva) Schema "dbo" cannot be resolved for table "t_address&am [message #666273 is a reply to message #666067] Tue, 19 April 2011 13:01 Go to previous messageGo to next message
hello neil,
I'm disappointed.
I do what you said( I mean validate the project), and the first time it was working.
but I made some changed and now it's no longer working.
now, the tables are finely generated, but I still have got these errors.
and in the properties the items 'override default schema' and 'override default catalog" are checkable, but the comboboxes still remain unselectables.
so I am stuck.
PS: thank you for your answer!
waiting for a new one!
icon3.gif  Re: (eclipse helios,mandriva) Schema "dbo" cannot be resolved for table "t_address&am [message #1728717 is a reply to message #666273] Wed, 06 April 2016 11:56 Go to previous message
Hi Guys,
I'm currently have exact the same problem to you.
Have you found the solution ?
Please help me !! Confused Sad
Previous Topic:NoSuchMethodError _persistence_set(Ljava/lang/String;Ljava/lang/Object;)V
Next Topic:Incorrect schema name during schema generation
Current Time: Sat Jul 26 09:39:58 EDT 2025
Powered by FUDForum. Page generated in 0.06549 seconds
