Home » Archived » M2M (model-to-model transformation) » Problem with hyphens in attributes
Problem with hyphens in attributes [message #666181] Tue, 19 April 2011 08:25 Go to next message
Hi all,
In an ECORE model, I can declare an attribute with a name including the hyphen, for example:
name-of-attribute: EString
. However, it turns out that we cannot indicate that attribute in an ATL rule. More precisely, the statement:
name-of-attribute<- a.name
will raise an error. Except changing the attribute's name, do you guys have any other solution? Thanks in advance!
Re: Problem with hyphens in attributes [message #666242 is a reply to message #666181] Tue, 19 April 2011 10:44 Go to previous messageGo to next message
I believe this breaks the parsing of the ATL file so you don't have much choice. You can use an imperative block tho :
do{
t.refSetValue('name-of-attribute',a.name);
Re: Problem with hyphens in attributes [message #666263 is a reply to message #666181] Tue, 19 April 2011 12:21 Go to previous messageGo to next message
Many thanks to your help Smile
Re: Problem with hyphens in attributes [message #666270 is a reply to message #666242] Tue, 19 April 2011 12:30 Go to previous message
> do{
ATL might want to adopt the OCL 2.3 syntax of underescore prefixed
string for awkward identifiers.
_'name-of-attribute'
Ed Willink
Previous Topic:OclType and oclAsType issues
Next Topic:[ATL] Format of output model
Current Time: Sun Jul 27 07:32:46 EDT 2025
Powered by FUDForum. Page generated in 0.04405 seconds
