Home » Eclipse Projects » Eclipse Platform » Concurrency contract of UI services (Eclipse 3.6.1)
Concurrency contract of UI services (Eclipse 3.6.1) [message #666163] Tue, 19 April 2011 07:25 Go to next message
We recently observed in our RCP program that ones in a while we get the
log entry from org.eclipse.ui.internal.services.WorkbenchServiceRegistry
due to the invocation of the loadFromRegistry method:
"Factory already exists for xxxx"
It turned out that this happened, when two different Eclipse jobs
(non-UI Jobs) accessed getSite().getService() from two different views
attempting to get the corresponding service class xxxx at the same time.
We tried to find out whether this was a violation of a user-contract to
work this way with the UI services API, but we could not find a clear
contract in regard to concurrency issues, in particular neither
getSite() nor getService() did provide corresponding constraints. I
might have simply overlooked it, so apologize if this has happened. But
if there is no concurrency contract, this should either be stated
clearly somewhere or the service API would probably expected to be
thread-safe.
I would appreciate any comments before I decide to open a bug report for
this.
Thanks & Greetings from Bremen,
Daniel Krügler
Re: Concurrency contract of UI services (Eclipse 3.6.1) [message #666176 is a reply to message #666163] Tue, 19 April 2011 08:04 Go to previous messageGo to next message
The UI services must all be accessed on the UI thread, unless otherwise
specified. With a few minor exceptions, almost all of our functionality
accessed through parts or the window are not protected against
multi-threaded access (as they're all UI related).
We do sometimes make a case for specific pieces of the workbench to be
thread-safe, like if you were using WorkbenchServiceRegistry to load
non-UI related services. Although there would probably be implications
for IServiceLocator as well.
PW
Paul Webster
http://wiki.eclipse.org/Platform_Expression_Framework
http://help.eclipse.org/helios/index.jsp?topic=/org.eclipse. platform.doc.isv/guide/workbench.htm
Re: Concurrency contract of UI services (Eclipse 3.6.1) [message #666184 is a reply to message #666176] Tue, 19 April 2011 08:18 Go to previous messageGo to next message
> specified.
Where can this contract be found? I searched for it, but I could not
find it. Just the fact, that it is named UI services is not convincing
to me.
Don't you think that this should be documented? Please note that I'm not
asking for a IMenuService or any Eclipse-provided service to be
accessible from all threads, I'm asking whether my own services provided
via the UI services extension point to be thread-safe. My implementation
*within* the create-method of the AbstractServiceFactory *is*
thread-safe, so the limiting factor is the extension point infra
structure. I studied the contract of AbstractServiceFactory,
IServiceWithSources, IServiceLocator, and IDisposable, as well as the
description of the org.eclipse.ui.services extension point and no
constraints about concurrency is provided. If the intention is, that
getService must be called from within the UI thread, that should be
documented.
How can I load non-UI related services from the WorkbenchServiceRegistry?
Thanks for your quick reply,
- Daniel
Re: Concurrency contract of UI services (Eclipse 3.6.1) [message #666214 is a reply to message #666184] Tue, 19 April 2011 09:18 Go to previous message
> to me.
It's not specified in the javadoc, it's the way the system works. It's
a hard requirement on the system (as in your break it, the system won't
work correctly). When bugs come up about this, we will issue the
statement in bug (they only work in the UI thread unless otherwise
specified). It is our policy (that would be the Platform UI team).
We have a bug about that.
Technically you can't as the closest you can get is
PlatformUI.getWorkbench() ... which is also bound to the UI thread.
PW
Paul Webster
Previous Topic:Target platform not being set
Next Topic:JVM terminated.Exit code=-2147483647
Current Time: Sat Jul 19 00:07:27 EDT 2025
Powered by FUDForum. Page generated in 0.33087 seconds
