Home » Eclipse Projects » Eclipse Platform » How to change the view from Projects to Working Sets programmatically?
icon4.gif  How to change the view from Projects to Working Sets programmatically? [message #666097] Tue, 19 April 2011 02:43 Go to next message
Hi all,
I want to change the view of the user from projects to working sets programmatically. This way some of the extra projects I create for my plug-in will not be directly visible to the user.
Is this possible?
If yes, can someone point me the related API for doing this.
Re: How to change the view from Projects to Working Sets programmatically? [message #666175 is a reply to message #666097] Tue, 19 April 2011 07:58 Go to previous messageGo to next message
You might be able to use
org.eclipse.ui.IWorkbenchPage.setWorkingSets(IWorkingSet[])
PW
Paul Webster
http://wiki.eclipse.org/Platform_Expression_Framework
http://help.eclipse.org/helios/index.jsp?topic=/org.eclipse. platform.doc.isv/guide/workbench.htm
Re: How to change the view from Projects to Working Sets programmatically? [message #666274 is a reply to message #666175] Tue, 19 April 2011 13:17 Go to previous messageGo to next message
Hi Paul,
Thanks for the suggestion. I tried using it, however for some reason it does not change the current view.
What I mean is the following: as you know the default view in Eclipse is that you see all the projects (even if the working sets exist, it is not the default view).This can be changed from the package explorer by hitting the down arrow (on the top right of package explorer) and then selecting Top Level Elements => Working Sets. This lets you to select the working sets you want to make visible and also changes the view.
What I need is to make this switch programmatically. In other words, I want to:
1- Detect whether the current view is working sets or projects.
2- If it is projects, change it to working sets.
3- If it is working sets, change it is projects (not need it, just to learn).
4- If a particular workspace (the one I created), is not visible (i.e., the user removed it), make it visible again.
How can I (or can I) do these?
Thanks, best regards,
Re: How to change the view from Projects to Working Sets programmatically? [message #666547 is a reply to message #666097] Wed, 20 April 2011 16:37 Go to previous messageGo to next message
> Is this possible?
You might want to rethink why you need those projects. I wouldn't want
the view settings changed on me as a user.
Nitin Dahyabhai
Eclipse WTP Source Editing and JSDT
IBM Rational
Re: How to change the view from Projects to Working Sets programmatically? [message #666548 is a reply to message #666547] Wed, 20 April 2011 16:55 Go to previous messageGo to next message
Hi Nitin,
This will be first prompted to the user (as a question, at the beginning) with the explanation of the extra projects and suggestion that changing the view to working sets would be better for him/her. Then if (s)he clicks okay, I want to change the view.
I have to have these projects. And my current users don't really care that much that these projects are created. However, some of them told me that the extra projects confuse them in the package explorer view. That is why I am trying to resolve this.
Re: How to change the view from Projects to Working Sets programmatically? [message #667727 is a reply to message #666548] Sun, 01 May 2011 14:50 Go to previous message
It's not API, but there is ProjectExplorer.setRootMode(), I'm not sure there is any actual API for this. You might want to file an enhancement request for that.
Previous Topic:Manipulating Working Sets - beginner's questions
Next Topic:problem while creating a jar file
Current Time: Sat Jul 26 20:29:33 EDT 2025
Powered by FUDForum. Page generated in 0.03841 seconds
