Home » Eclipse Projects » Plugin Development Environment (PDE) » create contextual menu in eclipse
create contextual menu in eclipse [message #666117] Tue, 19 April 2011 04:16 Go to next message
I search an tutorial about creation contextual menu in eclipse.
so we need how to use the extension point org.eclipse.ui.popupmenu.
thinks for your help.
Re: create contextual menu in eclipse [message #666415 is a reply to message #666117] Wed, 20 April 2011 07:43 Go to previous messageGo to next message
Hi George!
I was looking for the same thing a week ago and i ound the following article:
http://www.eclipse.org/articles/article.php?file=Article-act ion-contribution/index.html
For further searching, i suggest you should search for "eclipse context menu contribution".
Greetings
Re: create contextual menu in eclipse [message #666420 is a reply to message #666117] Wed, 20 April 2011 08:13 Go to previous messageGo to next message
think you for your help.It exactely what i search.But when i download the the file "action_contribution_examples.zip" which contains the complete source code for all the examples in this article i show the menu but the contextual menu no.
Re: create contextual menu in eclipse [message #666423 is a reply to message #666117] Wed, 20 April 2011 08:22 Go to previous message
On 2011-04-19 10:16, George wrote:
> Hello,
If you start freshly I strongly recommend to use commands combined with
the org.eclipse.ui.menus extension point instead. A good tutorial can be
found here:
http://www.vogella.de/articles/EclipseCommands/article.html
You will find that it also describes context menus.
HTH & Greetings from Bremen,
Daniel Krügler
Previous Topic:How to set default compiler compliance level inside plugin
Next Topic:How to develop an TextEditor that is capable to lock lines for MDSD?
Current Time: Sat Jul 19 01:15:21 EDT 2025
Powered by FUDForum. Page generated in 0.24314 seconds
