Home » Eclipse Projects » JFace » TreeViewer with checkboxes
TreeViewer with checkboxes [message #556327] Tue, 31 August 2010 15:31 Go to next message
My problem is TreeViewer, i have been created LabelProvider and ContentProvider. I get some correct data on my treeviewer. I have been initialized my Treeviewer like this TreeViewer(SWT.CHECK);
This way i can get checkboxes on my treeviewer rows.
But i want to show checkboxes only parent rows, like this
 _
I_I Parent
      Child
      Child
       _
      I_I Parent
            Child
            Child
I hope that u guys get what i wanted to do and you can help me with this.
Kokkonen
Re: TreeViewer with checkboxes [message #556605 is a reply to message #556327] Thu, 02 September 2010 01:08 Go to previous messageGo to next message
Kokkonen,
To my knowledge, the native Tree control (and by extension TreeViewer
and CheckboxTreeViewer) does not support this.
You may want to take a look at the Nebula Grid control and see if it
does what you need.
http://www.eclipse.org/nebula/widgets/grid/grid.php
FYI, the Grid control is supported on the eclipse.technology.nebula
newsgroup.
Matthew
On 08/31/2010 01:31 PM, juho.kokkonen@rivakka.net wrote:
> Hi
> _ I_I Parent
> Child
> Child
> _
> I_I Parent
> Child
> Child
> Kokkonen
Re: TreeViewer with checkboxes [message #556618 is a reply to message #556327] Thu, 02 September 2010 02:56 Go to previous messageGo to next message
Here is an old thread on a similar question and a possible solution --> http://dev.eclipse.org/newslists/news.eclipse.platform.swt/m sg26898.html
Re: TreeViewer with checkboxes [message #558073 is a reply to message #556327] Fri, 10 September 2010 02:30 Go to previous messageGo to next message
Ok it seems that i have to play with images.
Well i try this image fake solution and it works, BUT now i have only one image and it is checked or unchecked image.
Problem is that i want to put at least two images on same row.
I try to put TreeViewerColumns but when i open nodes only first column was indented, so when i open nodes first column get's under second column and disappears.
Anykind of solutions for this problem is welcome!!
Kokkonen
Re: TreeViewer with checkboxes [message #665917 is a reply to message #556327] Mon, 18 April 2011 03:25 Go to previous messageGo to next message
Tree tree = new Tree(parent,SWT.CHECK);
TreeViewer treeViewer = new TreeViewer(tree);
Re: TreeViewer with checkboxes [message #665921 is a reply to message #558073] Mon, 18 April 2011 03:55 Go to previous message
Hey Kokkonen,
I've never done this for trees, but I would try to subscribe to paint events and then draw the images into the first row. If that is an option for you, have a look at this link: http://www.eclipse.org/articles/article.php?file=Article-Cus tomDrawingTableAndTreeItems/index.html
HTH
Carsten ;o)
Previous Topic:TreeViewer and DataBinding
Next Topic:selectionChanged listener not getting called when view is minimized
Current Time: Sat Jul 26 05:38:59 EDT 2025
Powered by FUDForum. Page generated in 0.04570 seconds
