Home » Modeling » OCL » [Complete OCL] Change OCL file for validation per editor instance?
[Complete OCL] Change OCL file for validation per editor instance? [message #665859] Sun, 17 April 2011 06:43 Go to next message
Reading the excellent slides from Ed and Axel at the EclipseCon ( https://www.eclipsecon.org/submissions/2011/view_talk.php?id =2271) I stumbled upon the chapter on external Complete OCL validation for a Xtext editor.
Without digging to deep myself, I was wandering, whether it is possible to change the (Complete) OCL file that is used for validation in a generated Xtext editor per editor instance (instead of registering them in the OCL Model Registry for all instances).
A sample use case would be a statement in the edited model (e.g. in the editor generated for states.ecore in the workshop examples):
--> snip <--
module "simple.states"
validation "states.ocl"
--> snap <--
Any comments or directions are welcome.
Best regards
Joern
Re: [Complete OCL] Change OCL file for validation per editor instance? [message #665862 is a reply to message #665859] Sun, 17 April 2011 09:23 Go to previous messageGo to next message
Hi Joern
Certainly possible.
'validation' is a syntax in your grammar so you can support a Complete
OCL reference.
You then just need the generated Java validator to inoke the validation.
The CompleteOclEObjectValidator does this. You just need to parameterize
the resource.
Ed Willink
On 17/04/2011 11:43, Joern wrote:
> Xtext editor.
> --> snip <--
> --> snap <--
> Best regards
> Joern
Re: [Complete OCL] Change OCL file for validation per editor instance? [message #665876 is a reply to message #665862] Sun, 17 April 2011 15:37 Go to previous message
Joern,
also, it's always good to keep in mind that validating the objects contained in the resource(s) you're editor/editing domain is operating on is only the tip of the iceberg. As soon as you have cross-resource references and OCL constraints navigating such references, you may have to validate other resources too.
Should that be the case, you may want to check out the new OCL Impact Analyzer available since Ingido M6 in the OCL Editors and Examples feature. See org.eclipse.ocl.examples.impactanalyzer.ImpactAnalyzerFactor y for a starting point.
Best,
-- Axel
Previous Topic:Permanent violation of invariants after closing and opening the validated file
Next Topic:Property derivation using If then else
Current Time: Sat Jul 26 10:42:15 EDT 2025
Powered by FUDForum. Page generated in 0.08441 seconds
