Home » Archived » Buckminster » "Cannot open launch config from" when trying to run junit(Can not run junit in buckminster from hudson)
"Cannot open launch config from" when trying to run junit [message #665755] Fri, 15 April 2011 14:09 Go to next message
I have been trying for the last few days to get the junit command to work on my RCP project that is successfully being built by buckminster on my Hudson server. The error code I get is "Cannot open launch config from /com.ats.tests_1.0.0-osgi.bundle/AllTests.launch" . I know that the command wants the plug-in name that the launch file is in. I have tried just about everything I can think of for the plug in name. Originally I went with the actual name as seen in eclipse "junit '-l' '/com.ats.tests/AllTests.launch' since then I have tried the following and many others:
 junit '-l' '/com.ats.tests_1.0.0-osgi.bundle/AllTests.launch' (matches the name in the buckminster output folder)
junit '-l' '/com.ats.tests:osgi.bundle$1.0.0/AllTests.launch'  (seen in the info output in the console log)
junit '-l' '/com.ats.tests-feature/AllTests.launch'  (suggested in another thread)
junit '-l' '/com.ats.tests-osgi.bundle/AllTests.launch'  (because it looks like this plugin isn't a feature it's a osgi bundle)
The rest of my setup looks like this:
importtargetdefinition -A '${WORKSPACE}/com.ats.rdac.build.tests.site/rcpd.target'
import '${WORKSPACE}/com.ats.rdac.build.tests.site/site.cquery'
build
perform -D target.os=win32 -D target.ws=win32 -D target.arch=x86 com.ats.rdac.build.tests.site#create.product.zip
junit -l "/com.ats.tests-osgi.bundle/AllTests.launch"
The entire log:
Updating svn://dev1/buckminster/trunk
At revision 5713
no change for svn://dev1/buckminster/trunk since the previous build
[workspace] $ java -Dbuckminster.output.root=c:\hudson\jobs\RDACTests\workspace\buckminster.output -Dbuckminster.temp.root=c:\hudson\jobs\RDACTests\workspace\buckminster.temp -Xmx512m -jar C:\buckTest\buckminster\plugins\org.eclipse.equinox.launcher_1.1.1.R36x_v20101122_1400.jar -application org.eclipse.buckminster.cmdline.headless -data c:\hudson\jobs\RDACTests\workspace --loglevel info -S c:\hudson\jobs\RDACTests\workspace\commands.txt
INFO:  importtargetdefinition '-A' '/c:/hudson/jobs/RDACTests/workspace//com.ats.rdac.build.tests.site/rcpd.target'
INFO:  import '/c:/hudson/jobs/RDACTests/workspace//com.ats.rdac.build.tests.site/site.cquery'
INFO:  Import complete.
INFO:  build
INFO:  perform '-D' 'target.os=win32' '-D' 'target.ws=win32' '-D' 'target.arch=x86' 'com.ats.rdac.build.tests.site#create.product.zip'
INFO:  [start org.apache.log4j:osgi.bundle$1.2.12#eclipse.build]
INFO:  [end org.apache.log4j:osgi.bundle$1.2.12#eclipse.build]
INFO:  [start net.refractions.udig.libs:osgi.bundle$1.2.1.qualifier#eclipse.build]
INFO:  [end net.refractions.udig.libs:osgi.bundle$1.2.1.qualifier#eclipse.build]
INFO:  [start net.refractions.udig.core:osgi.bundle$1.2.0.qualifier#eclipse.build]
INFO:  [end net.refractions.udig.core:osgi.bundle$1.2.0.qualifier#eclipse.build]
INFO:  [start net.refractions.udig.ui:osgi.bundle$1.2.0.qualifier#eclipse.build]
INFO:  [end net.refractions.udig.ui:osgi.bundle$1.2.0.qualifier#eclipse.build]
INFO:  [start net.refractions.udig.catalog:osgi.bundle$1.2.0.qualifier#eclipse.build]
INFO:  [end net.refractions.udig.catalog:osgi.bundle$1.2.0.qualifier#eclipse.build]
INFO:  [start com.ipsysi.exceptions:osgi.bundle$1.0.0#eclipse.build]
INFO:  [end com.ipsysi.exceptions:osgi.bundle$1.0.0#eclipse.build]
INFO:  [start com.ipsysi.shapefilecontroller:osgi.bundle$1.0.0#eclipse.build]
INFO:  [end com.ipsysi.shapefilecontroller:osgi.bundle$1.0.0#eclipse.build]
INFO:  [start com.ipsysi.database:osgi.bundle$1.0.0#eclipse.build]
INFO:  [end com.ipsysi.database:osgi.bundle$1.0.0#eclipse.build]
INFO:  [start net.refractions.udig.project:osgi.bundle$1.2.1.qualifier#eclipse.build]
INFO:  [end net.refractions.udig.project:osgi.bundle$1.2.1.qualifier#eclipse.build]
INFO:  [start net.refractions.udig.style:osgi.bundle$1.2.0.qualifier#eclipse.build]
INFO:  [end net.refractions.udig.style:osgi.bundle$1.2.0.qualifier#eclipse.build]
INFO:  [start net.refractions.udig.style.sld:osgi.bundle$1.2.0.qualifier#eclipse.build]
INFO:  [end net.refractions.udig.style.sld:osgi.bundle$1.2.0.qualifier#eclipse.build]
INFO:  [start net.refractions.udig.catalog.ui:osgi.bundle$1.2.0.qualifier#eclipse.build]
INFO:  [end net.refractions.udig.catalog.ui:osgi.bundle$1.2.0.qualifier#eclipse.build]
INFO:  [start net.refractions.udig.project.edit:osgi.bundle$1.2.0.qualifier#eclipse.build]
INFO:  [end net.refractions.udig.project.edit:osgi.bundle$1.2.0.qualifier#eclipse.build]
INFO:  [start com.lowagie.itext:osgi.bundle$2.1.7#eclipse.build]
INFO:  [end com.lowagie.itext:osgi.bundle$2.1.7#eclipse.build]
INFO:  [start net.refractions.udig.project.ui:osgi.bundle$1.2.0.qualifier#eclipse.build]
INFO:  [end net.refractions.udig.project.ui:osgi.bundle$1.2.0.qualifier#eclipse.build]
INFO:  [start net.refractions.udig.catalog.shp:osgi.bundle$1.2.0.qualifier#eclipse.build]
INFO:  [end net.refractions.udig.catalog.shp:osgi.bundle$1.2.0.qualifier#eclipse.build]
INFO:  [start net.refractions.udig.catalog.rasterings:osgi.bundle$1.2.0.qualifier#eclipse.build]
INFO:  [end net.refractions.udig.catalog.rasterings:osgi.bundle$1.2.0.qualifier#eclipse.build]
INFO:  [start com.ipsysi.rdac.ui:osgi.bundle$1.0.0#eclipse.build]
INFO:  [end com.ipsysi.rdac.ui:osgi.bundle$1.0.0#eclipse.build]
INFO:  [start com.ipsysi.importtodatabasetool:osgi.bundle$1.0.0#eclipse.build]
INFO:  [end com.ipsysi.importtodatabasetool:osgi.bundle$1.0.0#eclipse.build]
INFO:  [start com.ipsysi.sldeditor:osgi.bundle$1.0.0#eclipse.build]
INFO:  [end com.ipsysi.sldeditor:osgi.bundle$1.0.0#eclipse.build]
INFO:  [start com.ipsysi.rdacengine2.interface:osgi.bundle$1.0.0#eclipse.build]
INFO:  [end com.ipsysi.rdacengine2.interface:osgi.bundle$1.0.0#eclipse.build]
INFO:  [start com.ipsysi.utils:osgi.bundle$1.0.0#eclipse.build]
INFO:  [end com.ipsysi.utils:osgi.bundle$1.0.0#eclipse.build]
INFO:  [start com.ipsysi.rdacengine2:osgi.bundle$1.0.0#eclipse.build]
INFO:  [end com.ipsysi.rdacengine2:osgi.bundle$1.0.0#eclipse.build]
INFO:  [start com.ipsysi.database.creationwizard:osgi.bundle$1.0.0#eclipse.build]
INFO:  [end com.ipsysi.database.creationwizard:osgi.bundle$1.0.0#eclipse.build]
INFO:  [start net.refractions.udig.mapgraphic:osgi.bundle$1.2.0.qualifier#eclipse.build]
INFO:  [end net.refractions.udig.mapgraphic:osgi.bundle$1.2.0.qualifier#eclipse.build]
INFO:  [start net.refractions.udig.browser:osgi.bundle$1.2.0.qualifier#eclipse.build]
INFO:  [end net.refractions.udig.browser:osgi.bundle$1.2.0.qualifier#eclipse.build]
INFO:  [start net.refractions.udig.catalog.geotiff:osgi.bundle$1.2.0.qualifier#eclipse.build]
INFO:  [end net.refractions.udig.catalog.geotiff:osgi.bundle$1.2.0.qualifier#eclipse.build]
INFO:  [start com.ipsysi.rdacengine.raster:osgi.bundle$1.0.0.qualifier#eclipse.build]
INFO:  [end com.ipsysi.rdacengine.raster:osgi.bundle$1.0.0.qualifier#eclipse.build]
INFO:  [start net.refractions.udig.catalog.imageio:osgi.bundle$1.2.0.qualifier#eclipse.build]
INFO:  [end net.refractions.udig.catalog.imageio:osgi.bundle$1.2.0.qualifier#eclipse.build]
INFO:  [start com.ipsysi.analysis:osgi.bundle$1.0.0#eclipse.build]
INFO:  [end com.ipsysi.analysis:osgi.bundle$1.0.0#eclipse.build]
INFO:  [start com.ipsysi.patcher.message:osgi.bundle$1.0.0#eclipse.build]
INFO:  [end com.ipsysi.patcher.message:osgi.bundle$1.0.0#eclipse.build]
INFO:  [start com.ipsysi.patcher.utils:osgi.bundle$1.0.0#eclipse.build]
INFO:  [end com.ipsysi.patcher.utils:osgi.bundle$1.0.0#eclipse.build]
INFO:  [start com.ipsysi.patcher:osgi.bundle$1.0.0#eclipse.build]
INFO:  [end com.ipsysi.patcher:osgi.bundle$1.0.0#eclipse.build]
INFO:  [start com.ipsysi.geotifftovectorimporttool:osgi.bundle$1.0.1#eclipse.build]
INFO:  [end com.ipsysi.geotifftovectorimporttool:osgi.bundle$1.0.1#eclipse.build]
INFO:  [start com.ipsysi.imagegeoreferencing:osgi.bundle$1.0.0#eclipse.build]
INFO:  [end com.ipsysi.imagegeoreferencing:osgi.bundle$1.0.0#eclipse.build]
INFO:  [start com.ipsysi.gpsmessages:osgi.bundle$1.0.0.qualifier#eclipse.build]
INFO:  [end com.ipsysi.gpsmessages:osgi.bundle$1.0.0.qualifier#eclipse.build]
INFO:  [start com.ipsysi.gps.shared:osgi.bundle$1.0.0.qualifier#eclipse.build]
INFO:  [end com.ipsysi.gps.shared:osgi.bundle$1.0.0.qualifier#eclipse.build]
INFO:  [start com.ipsysi.dis:osgi.bundle$1.0.0.qualifier#eclipse.build]
INFO:  [end com.ipsysi.dis:osgi.bundle$1.0.0.qualifier#eclipse.build]
INFO:  [start com.ipsysi.entityreceiver:osgi.bundle$1.0.0.qualifier#eclipse.build]
INFO:  [end com.ipsysi.entityreceiver:osgi.bundle$1.0.0.qualifier#eclipse.build]
INFO:  [start com.ipsysi.datautilities:osgi.bundle$1.0.0#eclipse.build]
INFO:  [end com.ipsysi.datautilities:osgi.bundle$1.0.0#eclipse.build]
INFO:  [start com.ipsysi.RDACAPP:osgi.bundle$1.0.0#eclipse.build]
INFO:  [end com.ipsysi.RDACAPP:osgi.bundle$1.0.0#eclipse.build]
INFO:  [start com.ipsysi.RDACAPP:osgi.bundle$1.0.0#bundle.jar]
INFO:  [end com.ipsysi.RDACAPP:osgi.bundle$1.0.0#bundle.jar]
INFO:  [start com.ipsysi.kml:osgi.bundle$1.0.0.qualifier#eclipse.build]
INFO:  [end com.ipsysi.kml:osgi.bundle$1.0.0.qualifier#eclipse.build]
INFO:  [start com.ipsysi.export:osgi.bundle$1.0.0#eclipse.build]
INFO:  [end com.ipsysi.export:osgi.bundle$1.0.0#eclipse.build]
INFO:  [start com.ats.cpof.export:osgi.bundle$1.0.0.qualifier#eclipse.build]
INFO:  [end com.ats.cpof.export:osgi.bundle$1.0.0.qualifier#eclipse.build]
INFO:  [start com.ats.cpof.export:osgi.bundle$1.0.0.qualifier#bundle.jar]
INFO:  [end com.ats.cpof.export:osgi.bundle$1.0.0.qualifier#bundle.jar]
INFO:  [start com.ats.rifts.messages:osgi.bundle$1.0.0.qualifier#eclipse.build]
INFO:  [end com.ats.rifts.messages:osgi.bundle$1.0.0.qualifier#eclipse.build]
INFO:  [start com.ats.geoservermanager:osgi.bundle$1.0.0.qualifier#eclipse.build]
INFO:  [end com.ats.geoservermanager:osgi.bundle$1.0.0.qualifier#eclipse.build]
INFO:  [start com.ats.geoservermanager:osgi.bundle$1.0.0.qualifier#bundle.jar]
INFO:  [end com.ats.geoservermanager:osgi.bundle$1.0.0.qualifier#bundle.jar]
INFO:  [start com.ats.geoservermanager.utils:osgi.bundle$1.0.0.qualifier#eclipse.build]
INFO:  [end com.ats.geoservermanager.utils:osgi.bundle$1.0.0.qualifier#eclipse.build]
INFO:  [start com.ats.geoservermanager.utils:osgi.bundle$1.0.0.qualifier#bundle.jar]
INFO:  [end com.ats.geoservermanager.utils:osgi.bundle$1.0.0.qualifier#bundle.jar]
INFO:  [start net.refractions.udig.catalog.wms:osgi.bundle$1.2.0.qualifier#eclipse.build]
INFO:  [end net.refractions.udig.catalog.wms:osgi.bundle$1.2.0.qualifier#eclipse.build]
INFO:  [start net.refractions.udig.catalog.wfs:osgi.bundle$1.2.0.qualifier#eclipse.build]
INFO:  [end net.refractions.udig.catalog.wfs:osgi.bundle$1.2.0.qualifier#eclipse.build]
INFO:  [start com.ats.kmlbridge:osgi.bundle$1.0.0.qualifier#eclipse.build]
INFO:  [end com.ats.kmlbridge:osgi.bundle$1.0.0.qualifier#eclipse.build]
INFO:  [start com.ats.rifts.client:osgi.bundle$1.0.0.qualifier#eclipse.build]
INFO:  [end com.ats.rifts.client:osgi.bundle$1.0.0.qualifier#eclipse.build]
INFO:  [start com.ats.rifts.client:osgi.bundle$1.0.0.qualifier#bundle.jar]
INFO:  [end com.ats.rifts.client:osgi.bundle$1.0.0.qualifier#bundle.jar]
INFO:  [start com.ats.rifts.messages:osgi.bundle$1.0.0.qualifier#bundle.jar]
INFO:  [end com.ats.rifts.messages:osgi.bundle$1.0.0.qualifier#bundle.jar]
INFO:  [start com.ipsysi.activemap:osgi.bundle$1.0.0#eclipse.build]
INFO:  [end com.ipsysi.activemap:osgi.bundle$1.0.0#eclipse.build]
INFO:  [start com.ipsysi.activemap:osgi.bundle$1.0.0#bundle.jar]
INFO:  [end com.ipsysi.activemap:osgi.bundle$1.0.0#bundle.jar]
INFO:  [start com.ipsysi.analysis:osgi.bundle$1.0.0#bundle.jar]
INFO:  [end com.ipsysi.analysis:osgi.bundle$1.0.0#bundle.jar]
INFO:  [start com.ipsysi.catalog:osgi.bundle$1.0.0#eclipse.build]
INFO:  [end com.ipsysi.catalog:osgi.bundle$1.0.0#eclipse.build]
INFO:  [start com.ipsysi.catalog:osgi.bundle$1.0.0#bundle.jar]
INFO:  [end com.ipsysi.catalog:osgi.bundle$1.0.0#bundle.jar]
INFO:  [start com.ipsysi.catalog.kml:osgi.bundle$1.0.0#eclipse.build]
INFO:  [end com.ipsysi.catalog.kml:osgi.bundle$1.0.0#eclipse.build]
INFO:  [start com.ipsysi.catalog.kml:osgi.bundle$1.0.0#bundle.jar]
INFO:  [end com.ipsysi.catalog.kml:osgi.bundle$1.0.0#bundle.jar]
INFO:  [start com.ipsysi.convert:osgi.bundle$1.0.0.qualifier#eclipse.build]
INFO:  [end com.ipsysi.convert:osgi.bundle$1.0.0.qualifier#eclipse.build]
INFO:  [start com.ipsysi.convert:osgi.bundle$1.0.0.qualifier#bundle.jar]
INFO:  [end com.ipsysi.convert:osgi.bundle$1.0.0.qualifier#bundle.jar]
INFO:  [start com.ipsysi.database:osgi.bundle$1.0.0#bundle.jar]
INFO:  [end com.ipsysi.database:osgi.bundle$1.0.0#bundle.jar]
INFO:  [start com.ipsysi.database.creationwizard:osgi.bundle$1.0.0#bundle.jar]
INFO:  [end com.ipsysi.database.creationwizard:osgi.bundle$1.0.0#bundle.jar]
INFO:  [start com.ipsysi.database.editor:osgi.bundle$1.0.0#eclipse.build]
INFO:  [end com.ipsysi.database.editor:osgi.bundle$1.0.0#eclipse.build]
INFO:  [start com.ipsysi.database.editor:osgi.bundle$1.0.0#bundle.jar]
INFO:  [end com.ipsysi.database.editor:osgi.bundle$1.0.0#bundle.jar]
INFO:  [start com.ipsysi.database.export:osgi.bundle$1.0.0#eclipse.build]
INFO:  [end com.ipsysi.database.export:osgi.bundle$1.0.0#eclipse.build]
INFO:  [start com.ipsysi.database.export:osgi.bundle$1.0.0#bundle.jar]
INFO:  [end com.ipsysi.database.export:osgi.bundle$1.0.0#bundle.jar]
INFO:  [start com.ipsysi.database.importer:osgi.bundle$1.0.0#eclipse.build]
INFO:  [end com.ipsysi.database.importer:osgi.bundle$1.0.0#eclipse.build]
INFO:  [start com.ipsysi.database.importer:osgi.bundle$1.0.0#bundle.jar]
INFO:  [end com.ipsysi.database.importer:osgi.bundle$1.0.0#bundle.jar]
INFO:  [start com.ipsysi.datautilities:osgi.bundle$1.0.0#bundle.jar]
INFO:  [end com.ipsysi.datautilities:osgi.bundle$1.0.0#bundle.jar]
INFO:  [start com.ipsysi.dis:osgi.bundle$1.0.0.qualifier#bundle.jar]
INFO:  [end com.ipsysi.dis:osgi.bundle$1.0.0.qualifier#bundle.jar]
INFO:  [start com.ipsysi.entityreceiver:osgi.bundle$1.0.0.qualifier#bundle.jar]
INFO:  [end com.ipsysi.entityreceiver:osgi.bundle$1.0.0.qualifier#bundle.jar]
INFO:  [start com.ipsysi.exceptions:osgi.bundle$1.0.0#bundle.jar]
INFO:  [end com.ipsysi.exceptions:osgi.bundle$1.0.0#bundle.jar]
INFO:  [start com.ipsysi.export:osgi.bundle$1.0.0#bundle.jar]
INFO:  [end com.ipsysi.export:osgi.bundle$1.0.0#bundle.jar]
INFO:  [start com.ipsysi.geotifftovectorimporttool:osgi.bundle$1.0.1#bundle.jar]
INFO:  [end com.ipsysi.geotifftovectorimporttool:osgi.bundle$1.0.1#bundle.jar]
INFO:  [start com.ats.kmlbridge:osgi.bundle$1.0.0.qualifier#bundle.jar]
INFO:  [end com.ats.kmlbridge:osgi.bundle$1.0.0.qualifier#bundle.jar]
INFO:  [start com.ipsysi.geovideo:osgi.bundle$1.0.0#eclipse.build]
INFO:  [end com.ipsysi.geovideo:osgi.bundle$1.0.0#eclipse.build]
INFO:  [start com.ipsysi.geovideo:osgi.bundle$1.0.0#bundle.jar]
INFO:  [end com.ipsysi.geovideo:osgi.bundle$1.0.0#bundle.jar]
INFO:  [start com.ipsysi.gps.shared:osgi.bundle$1.0.0.qualifier#bundle.jar]
INFO:  [end com.ipsysi.gps.shared:osgi.bundle$1.0.0.qualifier#bundle.jar]
INFO:  [start com.ipsysi.gpsmessages:osgi.bundle$1.0.0.qualifier#bundle.jar]
INFO:  [end com.ipsysi.gpsmessages:osgi.bundle$1.0.0.qualifier#bundle.jar]
INFO:  [start com.ipsysi.hiddenlayernotifier:osgi.bundle$1.0.0#eclipse.build]
INFO:  [end com.ipsysi.hiddenlayernotifier:osgi.bundle$1.0.0#eclipse.build]
INFO:  [start com.ipsysi.hiddenlayernotifier:osgi.bundle$1.0.0#bundle.jar]
INFO:  [end com.ipsysi.hiddenlayernotifier:osgi.bundle$1.0.0#bundle.jar]
INFO:  [start com.ipsysi.imagegeoreferencing:osgi.bundle$1.0.0#bundle.jar]
INFO:  [end com.ipsysi.imagegeoreferencing:osgi.bundle$1.0.0#bundle.jar]
INFO:  [start com.ipsysi.importer:osgi.bundle$1.0.0#eclipse.build]
INFO:  [end com.ipsysi.importer:osgi.bundle$1.0.0#eclipse.build]
INFO:  [start com.ipsysi.importer:osgi.bundle$1.0.0#bundle.jar]
INFO:  [end com.ipsysi.importer:osgi.bundle$1.0.0#bundle.jar]
INFO:  [start com.ipsysi.importtodatabasetool:osgi.bundle$1.0.0#bundle.jar]
INFO:  [end com.ipsysi.importtodatabasetool:osgi.bundle$1.0.0#bundle.jar]
INFO:  [start com.ipsysi.incidentreportingtool:osgi.bundle$1.0.0.qualifier#eclipse.build]
INFO:  [end com.ipsysi.incidentreportingtool:osgi.bundle$1.0.0.qualifier#eclipse.build]
INFO:  [start com.ipsysi.incidentreportingtool:osgi.bundle$1.0.0.qualifier#bundle.jar]
INFO:  [end com.ipsysi.incidentreportingtool:osgi.bundle$1.0.0.qualifier#bundle.jar]
INFO:  [start com.ipsysi.kml:osgi.bundle$1.0.0.qualifier#bundle.jar]
INFO:  [end com.ipsysi.kml:osgi.bundle$1.0.0.qualifier#bundle.jar]
INFO:  [start com.ipsysi.linkedmaps:osgi.bundle$1.0.0#eclipse.build]
INFO:  [end com.ipsysi.linkedmaps:osgi.bundle$1.0.0#eclipse.build]
INFO:  [start com.ipsysi.linkedmaps:osgi.bundle$1.0.0#bundle.jar]
INFO:  [end com.ipsysi.linkedmaps:osgi.bundle$1.0.0#bundle.jar]
INFO:  [start com.ipsysi.mockitowrapper:osgi.bundle$1.0.0#eclipse.build]
INFO:  [end com.ipsysi.mockitowrapper:osgi.bundle$1.0.0#eclipse.build]
INFO:  [start com.ipsysi.mockitowrapper:osgi.bundle$1.0.0#bundle.jar]
INFO:  [end com.ipsysi.mockitowrapper:osgi.bundle$1.0.0#bundle.jar]
INFO:  [start com.ipsysi.patcher:osgi.bundle$1.0.0#bundle.jar]
INFO:  [end com.ipsysi.patcher:osgi.bundle$1.0.0#bundle.jar]
INFO:  [start com.ipsysi.patcher.message:osgi.bundle$1.0.0#bundle.jar]
INFO:  [end com.ipsysi.patcher.message:osgi.bundle$1.0.0#bundle.jar]
INFO:  [start com.ipsysi.patcher.utils:osgi.bundle$1.0.0#bundle.jar]
INFO:  [end com.ipsysi.patcher.utils:osgi.bundle$1.0.0#bundle.jar]
INFO:  [start com.ipsysi.project:osgi.bundle$1.0.0#eclipse.build]
INFO:  [end com.ipsysi.project:osgi.bundle$1.0.0#eclipse.build]
INFO:  [start com.ipsysi.project:osgi.bundle$1.0.0#bundle.jar]
INFO:  [end com.ipsysi.project:osgi.bundle$1.0.0#bundle.jar]
INFO:  [start com.ipsysi.rdac.ui:osgi.bundle$1.0.0#bundle.jar]
INFO:  [end com.ipsysi.rdac.ui:osgi.bundle$1.0.0#bundle.jar]
INFO:  [start com.ipsysi.rdacengine.operations:osgi.bundle$1.0.0#eclipse.build]
INFO:  [end com.ipsysi.rdacengine.operations:osgi.bundle$1.0.0#eclipse.build]
INFO:  [start com.ipsysi.rdacengine.operations:osgi.bundle$1.0.0#bundle.jar]
INFO:  [end com.ipsysi.rdacengine.operations:osgi.bundle$1.0.0#bundle.jar]
INFO:  [start com.ipsysi.rdacengine.raster:osgi.bundle$1.0.0.qualifier#bundle.jar]
INFO:  [end com.ipsysi.rdacengine.raster:osgi.bundle$1.0.0.qualifier#bundle.jar]
INFO:  [start com.ipsysi.rdacengine.tools:osgi.bundle$1.0.0#eclipse.build]
INFO:  [end com.ipsysi.rdacengine.tools:osgi.bundle$1.0.0#eclipse.build]
INFO:  [start com.ipsysi.rdacengine.tools:osgi.bundle$1.0.0#bundle.jar]
INFO:  [end com.ipsysi.rdacengine.tools:osgi.bundle$1.0.0#bundle.jar]
INFO:  [start com.ipsysi.rdacengine2:osgi.bundle$1.0.0#bundle.jar]
INFO:  [end com.ipsysi.rdacengine2:osgi.bundle$1.0.0#bundle.jar]
INFO:  [start com.ipsysi.rdacengine2.interface:osgi.bundle$1.0.0#bundle.jar]
INFO:  [end com.ipsysi.rdacengine2.interface:osgi.bundle$1.0.0#bundle.jar]
INFO:  [start com.ipsysi.shapefilecontroller:osgi.bundle$1.0.0#bundle.jar]
INFO:  [end com.ipsysi.shapefilecontroller:osgi.bundle$1.0.0#bundle.jar]
INFO:  [start com.ipsysi.sldeditor:osgi.bundle$1.0.0#bundle.jar]
INFO:  [end com.ipsysi.sldeditor:osgi.bundle$1.0.0#bundle.jar]
INFO:  [start com.ipsysi.utils:osgi.bundle$1.0.0#bundle.jar]
INFO:  [end com.ipsysi.utils:osgi.bundle$1.0.0#bundle.jar]
INFO:  [start net.refractions.udig:osgi.bundle$1.2.1.qualifier#eclipse.build]
INFO:  [end net.refractions.udig:osgi.bundle$1.2.1.qualifier#eclipse.build]
INFO:  [start net.refractions.udig:osgi.bundle$1.2.1.qualifier#bundle.jar]
INFO:  [end net.refractions.udig:osgi.bundle$1.2.1.qualifier#bundle.jar]
INFO:  [start net.refractions.udig.browser:osgi.bundle$1.2.0.qualifier#bundle.jar]
INFO:  [end net.refractions.udig.browser:osgi.bundle$1.2.0.qualifier#bundle.jar]
INFO:  [start net.refractions.udig.catalog:osgi.bundle$1.2.0.qualifier#bundle.jar]
INFO:  [end net.refractions.udig.catalog:osgi.bundle$1.2.0.qualifier#bundle.jar]
INFO:  [start net.refractions.udig.catalog.arcgrid:osgi.bundle$1.2.0.qualifier#eclipse.build]
INFO:  [end net.refractions.udig.catalog.arcgrid:osgi.bundle$1.2.0.qualifier#eclipse.build]
INFO:  [start net.refractions.udig.catalog.arcgrid:osgi.bundle$1.2.0.qualifier#bundle.jar]
INFO:  [end net.refractions.udig.catalog.arcgrid:osgi.bundle$1.2.0.qualifier#bundle.jar]
INFO:  [start net.refractions.udig.catalog.arcsde:osgi.bundle$1.2.0.qualifier#eclipse.build]
INFO:  [end net.refractions.udig.catalog.arcsde:osgi.bundle$1.2.0.qualifier#eclipse.build]
INFO:  [start net.refractions.udig.catalog.arcsde:osgi.bundle$1.2.0.qualifier#bundle.jar]
INFO:  [end net.refractions.udig.catalog.arcsde:osgi.bundle$1.2.0.qualifier#bundle.jar]
INFO:  [start net.refractions.udig.catalog.db2:osgi.bundle$1.2.0.qualifier#eclipse.build]
INFO:  [end net.refractions.udig.catalog.db2:osgi.bundle$1.2.0.qualifier#eclipse.build]
INFO:  [start net.refractions.udig.catalog.db2:osgi.bundle$1.2.0.qualifier#bundle.jar]
INFO:  [end net.refractions.udig.catalog.db2:osgi.bundle$1.2.0.qualifier#bundle.jar]
INFO:  [start net.refractions.udig.catalog.geotiff:osgi.bundle$1.2.0.qualifier#bundle.jar]
INFO:  [end net.refractions.udig.catalog.geotiff:osgi.bundle$1.2.0.qualifier#bundle.jar]
INFO:  [start net.refractions.udig.catalog.geotools:osgi.bundle$1.2.0.qualifier#eclipse.build]
INFO:  [end net.refractions.udig.catalog.geotools:osgi.bundle$1.2.0.qualifier#eclipse.build]
INFO:  [start net.refractions.udig.catalog.geotools:osgi.bundle$1.2.0.qualifier#bundle.jar]
INFO:  [end net.refractions.udig.catalog.geotools:osgi.bundle$1.2.0.qualifier#bundle.jar]
INFO:  [start net.refractions.udig.catalog.google2:osgi.bundle$1.2.0.qualifier#eclipse.build]
INFO:  [end net.refractions.udig.catalog.google2:osgi.bundle$1.2.0.qualifier#eclipse.build]
INFO:  [start net.refractions.udig.catalog.google2:osgi.bundle$1.2.0.qualifier#bundle.jar]
INFO:  [end net.refractions.udig.catalog.google2:osgi.bundle$1.2.0.qualifier#bundle.jar]
INFO:  [start net.refractions.udig.catalog.imageio:osgi.bundle$1.2.0.qualifier#bundle.jar]
INFO:  [end net.refractions.udig.catalog.imageio:osgi.bundle$1.2.0.qualifier#bundle.jar]
INFO:  [start net.refractions.udig.catalog.mysql:osgi.bundle$1.2.0.qualifier#eclipse.build]
INFO:  [end net.refractions.udig.catalog.mysql:osgi.bundle$1.2.0.qualifier#eclipse.build]
INFO:  [start net.refractions.udig.catalog.mysql:osgi.bundle$1.2.0.qualifier#bundle.jar]
INFO:  [end net.refractions.udig.catalog.mysql:osgi.bundle$1.2.0.qualifier#bundle.jar]
INFO:  [start net.refractions.udig.catalog.oracle:osgi.bundle$1.2.0.qualifier#eclipse.build]
INFO:  [end net.refractions.udig.catalog.oracle:osgi.bundle$1.2.0.qualifier#eclipse.build]
INFO:  [start net.refractions.udig.catalog.oracle:osgi.bundle$1.2.0.qualifier#bundle.jar]
INFO:  [end net.refractions.udig.catalog.oracle:osgi.bundle$1.2.0.qualifier#bundle.jar]
INFO:  [start net.refractions.udig.catalog.rasterings:osgi.bundle$1.2.0.qualifier#bundle.jar]
INFO:  [end net.refractions.udig.catalog.rasterings:osgi.bundle$1.2.0.qualifier#bundle.jar]
INFO:  [start net.refractions.udig.catalog.shp:osgi.bundle$1.2.0.qualifier#bundle.jar]
INFO:  [end net.refractions.udig.catalog.shp:osgi.bundle$1.2.0.qualifier#bundle.jar]
INFO:  [start net.refractions.udig.catalog.ui:osgi.bundle$1.2.0.qualifier#bundle.jar]
INFO:  [end net.refractions.udig.catalog.ui:osgi.bundle$1.2.0.qualifier#bundle.jar]
INFO:  [start net.refractions.udig.catalog.wfs:osgi.bundle$1.2.0.qualifier#bundle.jar]
INFO:  [end net.refractions.udig.catalog.wfs:osgi.bundle$1.2.0.qualifier#bundle.jar]
INFO:  [start net.refractions.udig.catalog.wms:osgi.bundle$1.2.0.qualifier#bundle.jar]
INFO:  [end net.refractions.udig.catalog.wms:osgi.bundle$1.2.0.qualifier#bundle.jar]
INFO:  [start net.refractions.udig.catalog.worldimage:osgi.bundle$1.2.0.qualifier#eclipse.build]
INFO:  [end net.refractions.udig.catalog.worldimage:osgi.bundle$1.2.0.qualifier#eclipse.build]
INFO:  [start net.refractions.udig.catalog.worldimage:osgi.bundle$1.2.0.qualifier#bundle.jar]
INFO:  [end net.refractions.udig.catalog.worldimage:osgi.bundle$1.2.0.qualifier#bundle.jar]
INFO:  [start net.refractions.udig.context:osgi.bundle$1.2.0.qualifier#eclipse.build]
INFO:  [end net.refractions.udig.context:osgi.bundle$1.2.0.qualifier#eclipse.build]
INFO:  [start net.refractions.udig.context:osgi.bundle$1.2.0.qualifier#bundle.jar]
INFO:  [end net.refractions.udig.context:osgi.bundle$1.2.0.qualifier#bundle.jar]
INFO:  [start net.refractions.udig.core:osgi.bundle$1.2.0.qualifier#bundle.jar]
INFO:  [end net.refractions.udig.core:osgi.bundle$1.2.0.qualifier#bundle.jar]
INFO:  [start net.refractions.udig.feature.editor:osgi.bundle$1.2.0.qualifier#eclipse.build]
INFO:  [end net.refractions.udig.feature.editor:osgi.bundle$1.2.0.qualifier#eclipse.build]
INFO:  [start net.refractions.udig.feature.editor:osgi.bundle$1.2.0.qualifier#bundle.jar]
INFO:  [end net.refractions.udig.feature.editor:osgi.bundle$1.2.0.qualifier#bundle.jar]
INFO:  [start net.refractions.udig.graph:osgi.bundle$1.2.0.qualifier#eclipse.build]
INFO:  [end net.refractions.udig.graph:osgi.bundle$1.2.0.qualifier#eclipse.build]
INFO:  [start net.refractions.udig.graph:osgi.bundle$1.2.0.qualifier#bundle.jar]
INFO:  [end net.refractions.udig.graph:osgi.bundle$1.2.0.qualifier#bundle.jar]
INFO:  [start net.refractions.udig.help:osgi.bundle$1.2.0.qualifier#eclipse.build]
INFO:  [end net.refractions.udig.help:osgi.bundle$1.2.0.qualifier#eclipse.build]
INFO:  [start net.refractions.udig.help:osgi.bundle$1.2.0.qualifier#bundle.jar]
INFO:  [end net.refractions.udig.help:osgi.bundle$1.2.0.qualifier#bundle.jar]
INFO:  [start net.refractions.udig.jai:osgi.bundle$1.2.0.qualifier#eclipse.build]
INFO:  [end net.refractions.udig.jai:osgi.bundle$1.2.0.qualifier#eclipse.build]
INFO:  [start net.refractions.udig.jai:osgi.bundle$1.2.0.qualifier#bundle.jar]
INFO:  [end net.refractions.udig.jai:osgi.bundle$1.2.0.qualifier#bundle.jar]
INFO:  [start net.refractions.udig.legend:osgi.bundle$1.2.0.qualifier#eclipse.build]
INFO:  [end net.refractions.udig.legend:osgi.bundle$1.2.0.qualifier#eclipse.build]
INFO:  [start net.refractions.udig.legend:osgi.bundle$1.2.0.qualifier#bundle.jar]
INFO:  [end net.refractions.udig.legend:osgi.bundle$1.2.0.qualifier#bundle.jar]
INFO:  [start net.refractions.udig.libs:osgi.bundle$1.2.1.qualifier#create.library.jar]
INFO:  [end net.refractions.udig.libs:osgi.bundle$1.2.1.qualifier#create.library.jar]
INFO:  [start net.refractions.udig.libs:osgi.bundle$1.2.1.qualifier#bundle.jar]
INFO:  [end net.refractions.udig.libs:osgi.bundle$1.2.1.qualifier#bundle.jar]
INFO:  [start net.refractions.udig.libs.db2:osgi.bundle$1.2.0.qualifier#eclipse.build]
INFO:  [end net.refractions.udig.libs.db2:osgi.bundle$1.2.0.qualifier#eclipse.build]
INFO:  [start net.refractions.udig.libs.db2:osgi.bundle$1.2.0.qualifier#bundle.jar]
INFO:  [end net.refractions.udig.libs.db2:osgi.bundle$1.2.0.qualifier#bundle.jar]
INFO:  [start net.refractions.udig.libs.oracle:osgi.bundle$1.2.0.qualifier#eclipse.build]
INFO:  [end net.refractions.udig.libs.oracle:osgi.bundle$1.2.0.qualifier#eclipse.build]
INFO:  [start net.refractions.udig.libs.oracle:osgi.bundle$1.2.0.qualifier#bundle.jar]
INFO:  [end net.refractions.udig.libs.oracle:osgi.bundle$1.2.0.qualifier#bundle.jar]
INFO:  [start net.refractions.udig.location:osgi.bundle$1.2.0.qualifier#eclipse.build]
INFO:  [end net.refractions.udig.location:osgi.bundle$1.2.0.qualifier#eclipse.build]
INFO:  [start net.refractions.udig.location:osgi.bundle$1.2.0.qualifier#bundle.jar]
INFO:  [end net.refractions.udig.location:osgi.bundle$1.2.0.qualifier#bundle.jar]
INFO:  [start net.refractions.udig.mapgraphic:osgi.bundle$1.2.0.qualifier#bundle.jar]
INFO:  [end net.refractions.udig.mapgraphic:osgi.bundle$1.2.0.qualifier#bundle.jar]
INFO:  [start net.refractions.udig.printing.model:osgi.bundle$1.2.0.qualifier#eclipse.build]
INFO:  [end net.refractions.udig.printing.model:osgi.bundle$1.2.0.qualifier#eclipse.build]
INFO:  [start net.refractions.udig.printing.model:osgi.bundle$1.2.0.qualifier#bundle.jar]
INFO:  [end net.refractions.udig.printing.model:osgi.bundle$1.2.0.qualifier#bundle.jar]
INFO:  [start net.refractions.udig.printing.model.edit:osgi.bundle$1.2.0.qualifier#eclipse.build]
INFO:  [end net.refractions.udig.printing.model.edit:osgi.bundle$1.2.0.qualifier#eclipse.build]
INFO:  [start net.refractions.udig.printing.model.edit:osgi.bundle$1.2.0.qualifier#bundle.jar]
INFO:  [end net.refractions.udig.printing.model.edit:osgi.bundle$1.2.0.qualifier#bundle.jar]
INFO:  [start net.refractions.udig.printing.ui:osgi.bundle$1.2.0.qualifier#eclipse.build]
INFO:  [end net.refractions.udig.printing.ui:osgi.bundle$1.2.0.qualifier#eclipse.build]
INFO:  [start net.refractions.udig.printing.ui:osgi.bundle$1.2.0.qualifier#bundle.jar]
INFO:  [end net.refractions.udig.printing.ui:osgi.bundle$1.2.0.qualifier#bundle.jar]
INFO:  [start net.refractions.udig.project:osgi.bundle$1.2.1.qualifier#bundle.jar]
INFO:  [end net.refractions.udig.project:osgi.bundle$1.2.1.qualifier#bundle.jar]
INFO:  [start net.refractions.udig.project.edit:osgi.bundle$1.2.0.qualifier#bundle.jar]
INFO:  [end net.refractions.udig.project.edit:osgi.bundle$1.2.0.qualifier#bundle.jar]
INFO:  [start net.refractions.udig.project.ui:osgi.bundle$1.2.0.qualifier#bundle.jar]
INFO:  [end net.refractions.udig.project.ui:osgi.bundle$1.2.0.qualifier#bundle.jar]
INFO:  [start net.refractions.udig.project.ui.editor:osgi.bundle$1.2.0.qualifier#eclipse.build]
INFO:  [end net.refractions.udig.project.ui.editor:osgi.bundle$1.2.0.qualifier#eclipse.build]
INFO:  [start net.refractions.udig.project.ui.editor:osgi.bundle$1.2.0.qualifier#bundle.jar]
INFO:  [end net.refractions.udig.project.ui.editor:osgi.bundle$1.2.0.qualifier#bundle.jar]
INFO:  [start net.refractions.udig.render.feature.basic:osgi.bundle$1.2.1.qualifier#eclipse.build]
INFO:  [end net.refractions.udig.render.feature.basic:osgi.bundle$1.2.1.qualifier#eclipse.build]
INFO:  [start net.refractions.udig.render.feature.basic:osgi.bundle$1.2.1.qualifier#bundle.jar]
INFO:  [end net.refractions.udig.render.feature.basic:osgi.bundle$1.2.1.qualifier#bundle.jar]
INFO:  [start net.refractions.udig.render.feature.shapefile:osgi.bundle$1.2.0.qualifier#eclipse.build]
INFO:  [end net.refractions.udig.render.feature.shapefile:osgi.bundle$1.2.0.qualifier#eclipse.build]
INFO:  [start net.refractions.udig.render.feature.shapefile:osgi.bundle$1.2.0.qualifier#bundle.jar]
INFO:  [end net.refractions.udig.render.feature.shapefile:osgi.bundle$1.2.0.qualifier#bundle.jar]
INFO:  [start net.refractions.udig.render.gridcoverage.basic:osgi.bundle$1.2.0.qualifier#eclipse.build]
INFO:  [end net.refractions.udig.render.gridcoverage.basic:osgi.bundle$1.2.0.qualifier#eclipse.build]
INFO:  [start net.refractions.udig.render.gridcoverage.basic:osgi.bundle$1.2.0.qualifier#bundle.jar]
INFO:  [end net.refractions.udig.render.gridcoverage.basic:osgi.bundle$1.2.0.qualifier#bundle.jar]
INFO:  [start net.refractions.udig.style.wms:osgi.bundle$1.2.0.qualifier#eclipse.build]
INFO:  [end net.refractions.udig.style.wms:osgi.bundle$1.2.0.qualifier#eclipse.build]
INFO:  [start net.refractions.udig.render.wms.basic:osgi.bundle$1.2.0.qualifier#eclipse.build]
INFO:  [end net.refractions.udig.render.wms.basic:osgi.bundle$1.2.0.qualifier#eclipse.build]
INFO:  [start net.refractions.udig.render.wms.basic:osgi.bundle$1.2.0.qualifier#bundle.jar]
INFO:  [end net.refractions.udig.render.wms.basic:osgi.bundle$1.2.0.qualifier#bundle.jar]
INFO:  [start net.refractions.udig.socket:osgi.bundle$1.2.0.qualifier#eclipse.build]
INFO:  [end net.refractions.udig.socket:osgi.bundle$1.2.0.qualifier#eclipse.build]
INFO:  [start net.refractions.udig.socket:osgi.bundle$1.2.0.qualifier#bundle.jar]
INFO:  [end net.refractions.udig.socket:osgi.bundle$1.2.0.qualifier#bundle.jar]
INFO:  [start net.refractions.udig.style:osgi.bundle$1.2.0.qualifier#bundle.jar]
INFO:  [end net.refractions.udig.style:osgi.bundle$1.2.0.qualifier#bundle.jar]
INFO:  [start net.refractions.udig.style.sld:osgi.bundle$1.2.0.qualifier#bundle.jar]
INFO:  [end net.refractions.udig.style.sld:osgi.bundle$1.2.0.qualifier#bundle.jar]
INFO:  [start net.refractions.udig.style.wms:osgi.bundle$1.2.0.qualifier#bundle.jar]
INFO:  [end net.refractions.udig.style.wms:osgi.bundle$1.2.0.qualifier#bundle.jar]
INFO:  [start net.refractions.udig.tool.default:osgi.bundle$1.2.0.qualifier#eclipse.build]
INFO:  [end net.refractions.udig.tool.default:osgi.bundle$1.2.0.qualifier#eclipse.build]
INFO:  [start net.refractions.udig.tool.default:osgi.bundle$1.2.0.qualifier#bundle.jar]
INFO:  [end net.refractions.udig.tool.default:osgi.bundle$1.2.0.qualifier#bundle.jar]
INFO:  [start net.refractions.udig.tool.info:osgi.bundle$1.2.0.qualifier#eclipse.build]
INFO:  [end net.refractions.udig.tool.info:osgi.bundle$1.2.0.qualifier#eclipse.build]
INFO:  [start net.refractions.udig.tool.info:osgi.bundle$1.2.0.qualifier#bundle.jar]
INFO:  [end net.refractions.udig.tool.info:osgi.bundle$1.2.0.qualifier#bundle.jar]
INFO:  [start net.refractions.udig.tool.select:osgi.bundle$1.2.0.qualifier#eclipse.build]
INFO:  [end net.refractions.udig.tool.select:osgi.bundle$1.2.0.qualifier#eclipse.build]
INFO:  [start net.refractions.udig.tool.select:osgi.bundle$1.2.0.qualifier#bundle.jar]
INFO:  [end net.refractions.udig.tool.select:osgi.bundle$1.2.0.qualifier#bundle.jar]
INFO:  [start net.refractions.udig.tool.edit:osgi.bundle$1.2.0.qualifier#eclipse.build]
INFO:  [end net.refractions.udig.tool.edit:osgi.bundle$1.2.0.qualifier#eclipse.build]
INFO:  [start net.refractions.udig.tool.edit:osgi.bundle$1.2.0.qualifier#bundle.jar]
INFO:  [end net.refractions.udig.tool.edit:osgi.bundle$1.2.0.qualifier#bundle.jar]
INFO:  [start net.refractions.udig.ui:osgi.bundle$1.2.0.qualifier#bundle.jar]
INFO:  [end net.refractions.udig.ui:osgi.bundle$1.2.0.qualifier#bundle.jar]
INFO:  [start net.refractions.udig_base:osgi.bundle$1.2.0.qualifier#eclipse.build]
INFO:  [end net.refractions.udig_base:osgi.bundle$1.2.0.qualifier#eclipse.build]
INFO:  [start net.refractions.udig_base:osgi.bundle$1.2.0.qualifier#bundle.jar]
INFO:  [end net.refractions.udig_base:osgi.bundle$1.2.0.qualifier#bundle.jar]
INFO:  [start org.apache.log4j:osgi.bundle$1.2.12#bundle.jar]
INFO:  [end org.apache.log4j:osgi.bundle$1.2.12#bundle.jar]
INFO:  [start com.lowagie.itext:osgi.bundle$2.1.7#bundle.jar]
INFO:  [end com.lowagie.itext:osgi.bundle$2.1.7#bundle.jar]
INFO:  [start com.ats.kmlbridge.tests:osgi.bundle$1.0.0.qualifier#eclipse.build]
INFO:  [end com.ats.kmlbridge.tests:osgi.bundle$1.0.0.qualifier#eclipse.build]
INFO:  [start com.ats.kmlbridge.tests:osgi.bundle$1.0.0.qualifier#bundle.jar]
INFO:  [end com.ats.kmlbridge.tests:osgi.bundle$1.0.0.qualifier#bundle.jar]
INFO:  [start com.ipsysi.RDACAPP.tests:osgi.bundle$1.0.0#eclipse.build]
INFO:  [end com.ipsysi.RDACAPP.tests:osgi.bundle$1.0.0#eclipse.build]
INFO:  [start com.ipsysi.RDACAPP.tests:osgi.bundle$1.0.0#bundle.jar]
INFO:  [end com.ipsysi.RDACAPP.tests:osgi.bundle$1.0.0#bundle.jar]
INFO:  [start com.ipsysi.convert.tests:osgi.bundle$1.0.0.qualifier#eclipse.build]
INFO:  [end com.ipsysi.convert.tests:osgi.bundle$1.0.0.qualifier#eclipse.build]
INFO:  [start com.ipsysi.convert.tests:osgi.bundle$1.0.0.qualifier#bundle.jar]
INFO:  [end com.ipsysi.convert.tests:osgi.bundle$1.0.0.qualifier#bundle.jar]
INFO:  [start com.ipsysi.database.creationwizard.tests:osgi.bundle$1.0.0.qualifier#eclipse.build]
INFO:  [end com.ipsysi.database.creationwizard.tests:osgi.bundle$1.0.0.qualifier#eclipse.build]
INFO:  [start com.ipsysi.database.creationwizard.tests:osgi.bundle$1.0.0.qualifier#bundle.jar]
INFO:  [end com.ipsysi.database.creationwizard.tests:osgi.bundle$1.0.0.qualifier#bundle.jar]
INFO:  [start com.ipsysi.database.editor.test:osgi.bundle$1.0.0.qualifier#eclipse.build]
INFO:  [end com.ipsysi.database.editor.test:osgi.bundle$1.0.0.qualifier#eclipse.build]
INFO:  [start com.ipsysi.database.editor.test:osgi.bundle$1.0.0.qualifier#bundle.jar]
INFO:  [end com.ipsysi.database.editor.test:osgi.bundle$1.0.0.qualifier#bundle.jar]
INFO:  [start com.ipsysi.database.importer.test:osgi.bundle$1.0.0.qualifier#eclipse.build]
INFO:  [end com.ipsysi.database.importer.test:osgi.bundle$1.0.0.qualifier#eclipse.build]
INFO:  [start com.ipsysi.database.importer.test:osgi.bundle$1.0.0.qualifier#bundle.jar]
INFO:  [end com.ipsysi.database.importer.test:osgi.bundle$1.0.0.qualifier#bundle.jar]
INFO:  [start com.ipsysi.database.tests:osgi.bundle$1.0.0#eclipse.build]
INFO:  [end com.ipsysi.database.tests:osgi.bundle$1.0.0#eclipse.build]
INFO:  [start com.ipsysi.database.tests:osgi.bundle$1.0.0#bundle.jar]
INFO:  [end com.ipsysi.database.tests:osgi.bundle$1.0.0#bundle.jar]
INFO:  [start com.ipsysi.dis.tests:osgi.bundle$1.0.0.qualifier#eclipse.build]
INFO:  [end com.ipsysi.dis.tests:osgi.bundle$1.0.0.qualifier#eclipse.build]
INFO:  [start com.ipsysi.dis.tests:osgi.bundle$1.0.0.qualifier#bundle.jar]
INFO:  [end com.ipsysi.dis.tests:osgi.bundle$1.0.0.qualifier#bundle.jar]
INFO:  [start com.ipsysi.export.test:osgi.bundle$1.0.0.qualifier#eclipse.build]
INFO:  [end com.ipsysi.export.test:osgi.bundle$1.0.0.qualifier#eclipse.build]
INFO:  [start com.ipsysi.export.test:osgi.bundle$1.0.0.qualifier#bundle.jar]
INFO:  [end com.ipsysi.export.test:osgi.bundle$1.0.0.qualifier#bundle.jar]
INFO:  [start com.ipsysi.geotifftovectorimporttool.tests:osgi.bundle$1.0.0#eclipse.build]
INFO:  [end com.ipsysi.geotifftovectorimporttool.tests:osgi.bundle$1.0.0#eclipse.build]
INFO:  [start com.ipsysi.geotifftovectorimporttool.tests:osgi.bundle$1.0.0#bundle.jar]
INFO:  [end com.ipsysi.geotifftovectorimporttool.tests:osgi.bundle$1.0.0#bundle.jar]
INFO:  [start com.ipsysi.importtodatabasetool.tests:osgi.bundle$1.0.0#eclipse.build]
INFO:  [end com.ipsysi.importtodatabasetool.tests:osgi.bundle$1.0.0#eclipse.build]
INFO:  [start com.ipsysi.importtodatabasetool.tests:osgi.bundle$1.0.0#bundle.jar]
INFO:  [end com.ipsysi.importtodatabasetool.tests:osgi.bundle$1.0.0#bundle.jar]
INFO:  [start com.ipsysi.incidentreportingtool.tests:osgi.bundle$1.0.0.qualifier#eclipse.build]
INFO:  [end com.ipsysi.incidentreportingtool.tests:osgi.bundle$1.0.0.qualifier#eclipse.build]
INFO:  [start com.ipsysi.incidentreportingtool.tests:osgi.bundle$1.0.0.qualifier#bundle.jar]
INFO:  [end com.ipsysi.incidentreportingtool.tests:osgi.bundle$1.0.0.qualifier#bundle.jar]
INFO:  [start com.ipsysi.patcher.tests:osgi.bundle$1.0.0#eclipse.build]
INFO:  [end com.ipsysi.patcher.tests:osgi.bundle$1.0.0#eclipse.build]
INFO:  [start com.ipsysi.patcher.tests:osgi.bundle$1.0.0#bundle.jar]
INFO:  [end com.ipsysi.patcher.tests:osgi.bundle$1.0.0#bundle.jar]
INFO:  [start com.ipsysi.rdacengine.operations.tests:osgi.bundle$1.0.0#eclipse.build]
INFO:  [end com.ipsysi.rdacengine.operations.tests:osgi.bundle$1.0.0#eclipse.build]
INFO:  [start com.ipsysi.rdacengine.operations.tests:osgi.bundle$1.0.0#bundle.jar]
INFO:  [end com.ipsysi.rdacengine.operations.tests:osgi.bundle$1.0.0#bundle.jar]
INFO:  [start com.ipsysi.rdacengine2.tests:osgi.bundle$1.0.0#eclipse.build]
INFO:  [end com.ipsysi.rdacengine2.tests:osgi.bundle$1.0.0#eclipse.build]
INFO:  [start com.ipsysi.rdacengine2.tests:osgi.bundle$1.0.0#bundle.jar]
INFO:  [end com.ipsysi.rdacengine2.tests:osgi.bundle$1.0.0#bundle.jar]
INFO:  [start com.ipsysi.sldeditor.tests:osgi.bundle$1.0.0#eclipse.build]
INFO:  [end com.ipsysi.sldeditor.tests:osgi.bundle$1.0.0#eclipse.build]
INFO:  [start com.ipsysi.sldeditor.tests:osgi.bundle$1.0.0#bundle.jar]
INFO:  [end com.ipsysi.sldeditor.tests:osgi.bundle$1.0.0#bundle.jar]
INFO:  [start com.ats.tests:osgi.bundle$1.0.0#eclipse.build]
INFO:  [end com.ats.tests:osgi.bundle$1.0.0#eclipse.build]
INFO:  [start com.ats.rdac.build.tests:eclipse.feature$1.0.0.qualifier#feature.jar]
INFO:  [end com.ats.rdac.build.tests:eclipse.feature$1.0.0.qualifier#feature.jar]
INFO:  [start com.ipsysi.RDACAPP:osgi.bundle$1.0.0#source.bundle.jar]
INFO:  [end com.ipsysi.RDACAPP:osgi.bundle$1.0.0#source.bundle.jar]
INFO:  [start com.ats.cpof.export:osgi.bundle$1.0.0.qualifier#source.bundle.jar]
INFO:  [end com.ats.cpof.export:osgi.bundle$1.0.0.qualifier#source.bundle.jar]
INFO:  [start com.ats.geoservermanager:osgi.bundle$1.0.0.qualifier#source.bundle.jar]
INFO:  [end com.ats.geoservermanager:osgi.bundle$1.0.0.qualifier#source.bundle.jar]
INFO:  [start com.ats.geoservermanager.utils:osgi.bundle$1.0.0.qualifier#source.bundle.jar]
INFO:  [end com.ats.geoservermanager.utils:osgi.bundle$1.0.0.qualifier#source.bundle.jar]
INFO:  [start com.ats.rifts.client:osgi.bundle$1.0.0.qualifier#source.bundle.jar]
INFO:  [end com.ats.rifts.client:osgi.bundle$1.0.0.qualifier#source.bundle.jar]
INFO:  [start com.ats.rifts.messages:osgi.bundle$1.0.0.qualifier#source.bundle.jar]
INFO:  [end com.ats.rifts.messages:osgi.bundle$1.0.0.qualifier#source.bundle.jar]
INFO:  [start com.ipsysi.activemap:osgi.bundle$1.0.0#source.bundle.jar]
INFO:  [end com.ipsysi.activemap:osgi.bundle$1.0.0#source.bundle.jar]
INFO:  [start com.ipsysi.analysis:osgi.bundle$1.0.0#source.bundle.jar]
INFO:  [end com.ipsysi.analysis:osgi.bundle$1.0.0#source.bundle.jar]
INFO:  [start com.ipsysi.catalog:osgi.bundle$1.0.0#source.bundle.jar]
INFO:  [end com.ipsysi.catalog:osgi.bundle$1.0.0#source.bundle.jar]
INFO:  [start com.ipsysi.catalog.kml:osgi.bundle$1.0.0#source.bundle.jar]
INFO:  [end com.ipsysi.catalog.kml:osgi.bundle$1.0.0#source.bundle.jar]
INFO:  [start com.ipsysi.convert:osgi.bundle$1.0.0.qualifier#source.bundle.jar]
INFO:  [end com.ipsysi.convert:osgi.bundle$1.0.0.qualifier#source.bundle.jar]
INFO:  [start com.ipsysi.database:osgi.bundle$1.0.0#source.bundle.jar]
INFO:  [end com.ipsysi.database:osgi.bundle$1.0.0#source.bundle.jar]
INFO:  [start com.ipsysi.database.creationwizard:osgi.bundle$1.0.0#source.bundle.jar]
INFO:  [end com.ipsysi.database.creationwizard:osgi.bundle$1.0.0#source.bundle.jar]
INFO:  [start com.ipsysi.database.editor:osgi.bundle$1.0.0#source.bundle.jar]
INFO:  [end com.ipsysi.database.editor:osgi.bundle$1.0.0#source.bundle.jar]
INFO:  [start com.ipsysi.database.export:osgi.bundle$1.0.0#source.bundle.jar]
INFO:  [end com.ipsysi.database.export:osgi.bundle$1.0.0#source.bundle.jar]
INFO:  [start com.ipsysi.database.importer:osgi.bundle$1.0.0#source.bundle.jar]
INFO:  [end com.ipsysi.database.importer:osgi.bundle$1.0.0#source.bundle.jar]
INFO:  [start com.ipsysi.datautilities:osgi.bundle$1.0.0#source.bundle.jar]
INFO:  [end com.ipsysi.datautilities:osgi.bundle$1.0.0#source.bundle.jar]
INFO:  [start com.ipsysi.dis:osgi.bundle$1.0.0.qualifier#source.bundle.jar]
INFO:  [end com.ipsysi.dis:osgi.bundle$1.0.0.qualifier#source.bundle.jar]
INFO:  [start com.ipsysi.entityreceiver:osgi.bundle$1.0.0.qualifier#source.bundle.jar]
INFO:  [end com.ipsysi.entityreceiver:osgi.bundle$1.0.0.qualifier#source.bundle.jar]
INFO:  [start com.ipsysi.exceptions:osgi.bundle$1.0.0#source.bundle.jar]
INFO:  [end com.ipsysi.exceptions:osgi.bundle$1.0.0#source.bundle.jar]
INFO:  [start com.ipsysi.export:osgi.bundle$1.0.0#source.bundle.jar]
INFO:  [end com.ipsysi.export:osgi.bundle$1.0.0#source.bundle.jar]
INFO:  [start com.ipsysi.geotifftovectorimporttool:osgi.bundle$1.0.1#source.bundle.jar]
INFO:  [end com.ipsysi.geotifftovectorimporttool:osgi.bundle$1.0.1#source.bundle.jar]
INFO:  [start com.ats.kmlbridge:osgi.bundle$1.0.0.qualifier#source.bundle.jar]
INFO:  [end com.ats.kmlbridge:osgi.bundle$1.0.0.qualifier#source.bundle.jar]
INFO:  [start com.ipsysi.geovideo:osgi.bundle$1.0.0#source.bundle.jar]
INFO:  [end com.ipsysi.geovideo:osgi.bundle$1.0.0#source.bundle.jar]
INFO:  [start com.ipsysi.gps.shared:osgi.bundle$1.0.0.qualifier#source.bundle.jar]
INFO:  [end com.ipsysi.gps.shared:osgi.bundle$1.0.0.qualifier#source.bundle.jar]
INFO:  [start com.ipsysi.gpsmessages:osgi.bundle$1.0.0.qualifier#source.bundle.jar]
INFO:  [end com.ipsysi.gpsmessages:osgi.bundle$1.0.0.qualifier#source.bundle.jar]
INFO:  [start com.ipsysi.hiddenlayernotifier:osgi.bundle$1.0.0#source.bundle.jar]
INFO:  [end com.ipsysi.hiddenlayernotifier:osgi.bundle$1.0.0#source.bundle.jar]
INFO:  [start com.ipsysi.imagegeoreferencing:osgi.bundle$1.0.0#source.bundle.jar]
INFO:  [end com.ipsysi.imagegeoreferencing:osgi.bundle$1.0.0#source.bundle.jar]
INFO:  [start com.ipsysi.importer:osgi.bundle$1.0.0#source.bundle.jar]
INFO:  [end com.ipsysi.importer:osgi.bundle$1.0.0#source.bundle.jar]
INFO:  [start com.ipsysi.importtodatabasetool:osgi.bundle$1.0.0#source.bundle.jar]
INFO:  [end com.ipsysi.importtodatabasetool:osgi.bundle$1.0.0#source.bundle.jar]
INFO:  [start com.ipsysi.incidentreportingtool:osgi.bundle$1.0.0.qualifier#source.bundle.jar]
INFO:  [end com.ipsysi.incidentreportingtool:osgi.bundle$1.0.0.qualifier#source.bundle.jar]
INFO:  [start com.ipsysi.kml:osgi.bundle$1.0.0.qualifier#source.bundle.jar]
INFO:  [end com.ipsysi.kml:osgi.bundle$1.0.0.qualifier#source.bundle.jar]
INFO:  [start com.ipsysi.linkedmaps:osgi.bundle$1.0.0#source.bundle.jar]
INFO:  [end com.ipsysi.linkedmaps:osgi.bundle$1.0.0#source.bundle.jar]
INFO:  [start com.ipsysi.patcher:osgi.bundle$1.0.0#source.bundle.jar]
INFO:  [end com.ipsysi.patcher:osgi.bundle$1.0.0#source.bundle.jar]
INFO:  [start com.ipsysi.patcher.message:osgi.bundle$1.0.0#source.bundle.jar]
INFO:  [end com.ipsysi.patcher.message:osgi.bundle$1.0.0#source.bundle.jar]
INFO:  [start com.ipsysi.patcher.utils:osgi.bundle$1.0.0#source.bundle.jar]
INFO:  [end com.ipsysi.patcher.utils:osgi.bundle$1.0.0#source.bundle.jar]
INFO:  [start com.ipsysi.project:osgi.bundle$1.0.0#source.bundle.jar]
INFO:  [end com.ipsysi.project:osgi.bundle$1.0.0#source.bundle.jar]
INFO:  [start com.ipsysi.rdac.ui:osgi.bundle$1.0.0#source.bundle.jar]
INFO:  [end com.ipsysi.rdac.ui:osgi.bundle$1.0.0#source.bundle.jar]
INFO:  [start com.ipsysi.rdacengine.operations:osgi.bundle$1.0.0#source.bundle.jar]
INFO:  [end com.ipsysi.rdacengine.operations:osgi.bundle$1.0.0#source.bundle.jar]
INFO:  [start com.ipsysi.rdacengine.raster:osgi.bundle$1.0.0.qualifier#source.bundle.jar]
INFO:  [end com.ipsysi.rdacengine.raster:osgi.bundle$1.0.0.qualifier#source.bundle.jar]
INFO:  [start com.ipsysi.rdacengine.tools:osgi.bundle$1.0.0#source.bundle.jar]
INFO:  [end com.ipsysi.rdacengine.tools:osgi.bundle$1.0.0#source.bundle.jar]
INFO:  [start com.ipsysi.rdacengine2:osgi.bundle$1.0.0#source.bundle.jar]
INFO:  [end com.ipsysi.rdacengine2:osgi.bundle$1.0.0#source.bundle.jar]
INFO:  [start com.ipsysi.rdacengine2.interface:osgi.bundle$1.0.0#source.bundle.jar]
INFO:  [end com.ipsysi.rdacengine2.interface:osgi.bundle$1.0.0#source.bundle.jar]
INFO:  [start com.ipsysi.shapefilecontroller:osgi.bundle$1.0.0#source.bundle.jar]
INFO:  [end com.ipsysi.shapefilecontroller:osgi.bundle$1.0.0#source.bundle.jar]
INFO:  [start com.ipsysi.sldeditor:osgi.bundle$1.0.0#source.bundle.jar]
INFO:  [end com.ipsysi.sldeditor:osgi.bundle$1.0.0#source.bundle.jar]
INFO:  [start com.ipsysi.utils:osgi.bundle$1.0.0#source.bundle.jar]
INFO:  [end com.ipsysi.utils:osgi.bundle$1.0.0#source.bundle.jar]
INFO:  [start net.refractions.udig:osgi.bundle$1.2.1.qualifier#source.bundle.jar]
INFO:  [end net.refractions.udig:osgi.bundle$1.2.1.qualifier#source.bundle.jar]
INFO:  [start net.refractions.udig.browser:osgi.bundle$1.2.0.qualifier#source.bundle.jar]
INFO:  [end net.refractions.udig.browser:osgi.bundle$1.2.0.qualifier#source.bundle.jar]
INFO:  [start net.refractions.udig.catalog:osgi.bundle$1.2.0.qualifier#source.bundle.jar]
INFO:  [end net.refractions.udig.catalog:osgi.bundle$1.2.0.qualifier#source.bundle.jar]
INFO:  [start net.refractions.udig.catalog.arcgrid:osgi.bundle$1.2.0.qualifier#source.bundle.jar]
INFO:  [end net.refractions.udig.catalog.arcgrid:osgi.bundle$1.2.0.qualifier#source.bundle.jar]
INFO:  [start net.refractions.udig.catalog.arcsde:osgi.bundle$1.2.0.qualifier#source.bundle.jar]
INFO:  [end net.refractions.udig.catalog.arcsde:osgi.bundle$1.2.0.qualifier#source.bundle.jar]
INFO:  [start net.refractions.udig.catalog.db2:osgi.bundle$1.2.0.qualifier#source.bundle.jar]
INFO:  [end net.refractions.udig.catalog.db2:osgi.bundle$1.2.0.qualifier#source.bundle.jar]
INFO:  [start net.refractions.udig.catalog.geotiff:osgi.bundle$1.2.0.qualifier#source.bundle.jar]
INFO:  [end net.refractions.udig.catalog.geotiff:osgi.bundle$1.2.0.qualifier#source.bundle.jar]
INFO:  [start net.refractions.udig.catalog.geotools:osgi.bundle$1.2.0.qualifier#source.bundle.jar]
INFO:  [end net.refractions.udig.catalog.geotools:osgi.bundle$1.2.0.qualifier#source.bundle.jar]
INFO:  [start net.refractions.udig.catalog.google2:osgi.bundle$1.2.0.qualifier#source.bundle.jar]
INFO:  [end net.refractions.udig.catalog.google2:osgi.bundle$1.2.0.qualifier#source.bundle.jar]
INFO:  [start net.refractions.udig.catalog.imageio:osgi.bundle$1.2.0.qualifier#source.bundle.jar]
INFO:  [end net.refractions.udig.catalog.imageio:osgi.bundle$1.2.0.qualifier#source.bundle.jar]
INFO:  [start net.refractions.udig.catalog.mysql:osgi.bundle$1.2.0.qualifier#source.bundle.jar]
INFO:  [end net.refractions.udig.catalog.mysql:osgi.bundle$1.2.0.qualifier#source.bundle.jar]
INFO:  [start net.refractions.udig.catalog.oracle:osgi.bundle$1.2.0.qualifier#source.bundle.jar]
INFO:  [end net.refractions.udig.catalog.oracle:osgi.bundle$1.2.0.qualifier#source.bundle.jar]
INFO:  [start net.refractions.udig.catalog.rasterings:osgi.bundle$1.2.0.qualifier#source.bundle.jar]
INFO:  [end net.refractions.udig.catalog.rasterings:osgi.bundle$1.2.0.qualifier#source.bundle.jar]
INFO:  [start net.refractions.udig.catalog.shp:osgi.bundle$1.2.0.qualifier#source.bundle.jar]
INFO:  [end net.refractions.udig.catalog.shp:osgi.bundle$1.2.0.qualifier#source.bundle.jar]
INFO:  [start net.refractions.udig.catalog.ui:osgi.bundle$1.2.0.qualifier#source.bundle.jar]
INFO:  [end net.refractions.udig.catalog.ui:osgi.bundle$1.2.0.qualifier#source.bundle.jar]
INFO:  [start net.refractions.udig.catalog.wfs:osgi.bundle$1.2.0.qualifier#source.bundle.jar]
INFO:  [end net.refractions.udig.catalog.wfs:osgi.bundle$1.2.0.qualifier#source.bundle.jar]
INFO:  [start net.refractions.udig.catalog.wms:osgi.bundle$1.2.0.qualifier#source.bundle.jar]
INFO:  [end net.refractions.udig.catalog.wms:osgi.bundle$1.2.0.qualifier#source.bundle.jar]
INFO:  [start net.refractions.udig.catalog.worldimage:osgi.bundle$1.2.0.qualifier#source.bundle.jar]
INFO:  [end net.refractions.udig.catalog.worldimage:osgi.bundle$1.2.0.qualifier#source.bundle.jar]
INFO:  [start net.refractions.udig.context:osgi.bundle$1.2.0.qualifier#source.bundle.jar]
INFO:  [end net.refractions.udig.context:osgi.bundle$1.2.0.qualifier#source.bundle.jar]
INFO:  [start net.refractions.udig.core:osgi.bundle$1.2.0.qualifier#source.bundle.jar]
INFO:  [end net.refractions.udig.core:osgi.bundle$1.2.0.qualifier#source.bundle.jar]
INFO:  [start net.refractions.udig.feature.editor:osgi.bundle$1.2.0.qualifier#source.bundle.jar]
INFO:  [end net.refractions.udig.feature.editor:osgi.bundle$1.2.0.qualifier#source.bundle.jar]
INFO:  [start net.refractions.udig.graph:osgi.bundle$1.2.0.qualifier#source.bundle.jar]
INFO:  [end net.refractions.udig.graph:osgi.bundle$1.2.0.qualifier#source.bundle.jar]
INFO:  [start net.refractions.udig.help:osgi.bundle$1.2.0.qualifier#source.bundle.jar]
INFO:  [end net.refractions.udig.help:osgi.bundle$1.2.0.qualifier#source.bundle.jar]
INFO:  [start net.refractions.udig.jai:osgi.bundle$1.2.0.qualifier#source.bundle.jar]
INFO:  [end net.refractions.udig.jai:osgi.bundle$1.2.0.qualifier#source.bundle.jar]
INFO:  [start net.refractions.udig.legend:osgi.bundle$1.2.0.qualifier#source.bundle.jar]
INFO:  [end net.refractions.udig.legend:osgi.bundle$1.2.0.qualifier#source.bundle.jar]
INFO:  [start net.refractions.udig.libs:osgi.bundle$1.2.1.qualifier#source.bundle.jar]
INFO:  [end net.refractions.udig.libs:osgi.bundle$1.2.1.qualifier#source.bundle.jar]
INFO:  [start net.refractions.udig.libs.db2:osgi.bundle$1.2.0.qualifier#source.bundle.jar]
INFO:  [end net.refractions.udig.libs.db2:osgi.bundle$1.2.0.qualifier#source.bundle.jar]
INFO:  [start net.refractions.udig.libs.oracle:osgi.bundle$1.2.0.qualifier#source.bundle.jar]
INFO:  [end net.refractions.udig.libs.oracle:osgi.bundle$1.2.0.qualifier#source.bundle.jar]
INFO:  [start net.refractions.udig.location:osgi.bundle$1.2.0.qualifier#source.bundle.jar]
INFO:  [end net.refractions.udig.location:osgi.bundle$1.2.0.qualifier#source.bundle.jar]
INFO:  [start net.refractions.udig.mapgraphic:osgi.bundle$1.2.0.qualifier#source.bundle.jar]
INFO:  [end net.refractions.udig.mapgraphic:osgi.bundle$1.2.0.qualifier#source.bundle.jar]
INFO:  [start net.refractions.udig.printing.model:osgi.bundle$1.2.0.qualifier#source.bundle.jar]
INFO:  [end net.refractions.udig.printing.model:osgi.bundle$1.2.0.qualifier#source.bundle.jar]
INFO:  [start net.refractions.udig.printing.model.edit:osgi.bundle$1.2.0.qualifier#source.bundle.jar]
INFO:  [end net.refractions.udig.printing.model.edit:osgi.bundle$1.2.0.qualifier#source.bundle.jar]
INFO:  [start net.refractions.udig.printing.ui:osgi.bundle$1.2.0.qualifier#source.bundle.jar]
INFO:  [end net.refractions.udig.printing.ui:osgi.bundle$1.2.0.qualifier#source.bundle.jar]
INFO:  [start net.refractions.udig.project:osgi.bundle$1.2.1.qualifier#source.bundle.jar]
INFO:  [end net.refractions.udig.project:osgi.bundle$1.2.1.qualifier#source.bundle.jar]
INFO:  [start net.refractions.udig.project.edit:osgi.bundle$1.2.0.qualifier#source.bundle.jar]
INFO:  [end net.refractions.udig.project.edit:osgi.bundle$1.2.0.qualifier#source.bundle.jar]
INFO:  [start net.refractions.udig.project.ui:osgi.bundle$1.2.0.qualifier#source.bundle.jar]
INFO:  [end net.refractions.udig.project.ui:osgi.bundle$1.2.0.qualifier#source.bundle.jar]
INFO:  [start net.refractions.udig.project.ui.editor:osgi.bundle$1.2.0.qualifier#source.bundle.jar]
INFO:  [end net.refractions.udig.project.ui.editor:osgi.bundle$1.2.0.qualifier#source.bundle.jar]
INFO:  [start net.refractions.udig.render.feature.basic:osgi.bundle$1.2.1.qualifier#source.bundle.jar]
INFO:  [end net.refractions.udig.render.feature.basic:osgi.bundle$1.2.1.qualifier#source.bundle.jar]
INFO:  [start net.refractions.udig.render.feature.shapefile:osgi.bundle$1.2.0.qualifier#source.bundle.jar]
INFO:  [end net.refractions.udig.render.feature.shapefile:osgi.bundle$1.2.0.qualifier#source.bundle.jar]
INFO:  [start net.refractions.udig.render.gridcoverage.basic:osgi.bundle$1.2.0.qualifier#source.bundle.jar]
INFO:  [end net.refractions.udig.render.gridcoverage.basic:osgi.bundle$1.2.0.qualifier#source.bundle.jar]
INFO:  [start net.refractions.udig.render.wms.basic:osgi.bundle$1.2.0.qualifier#source.bundle.jar]
INFO:  [end net.refractions.udig.render.wms.basic:osgi.bundle$1.2.0.qualifier#source.bundle.jar]
INFO:  [start net.refractions.udig.socket:osgi.bundle$1.2.0.qualifier#source.bundle.jar]
INFO:  [end net.refractions.udig.socket:osgi.bundle$1.2.0.qualifier#source.bundle.jar]
INFO:  [start net.refractions.udig.style:osgi.bundle$1.2.0.qualifier#source.bundle.jar]
INFO:  [end net.refractions.udig.style:osgi.bundle$1.2.0.qualifier#source.bundle.jar]
INFO:  [start net.refractions.udig.style.sld:osgi.bundle$1.2.0.qualifier#source.bundle.jar]
INFO:  [end net.refractions.udig.style.sld:osgi.bundle$1.2.0.qualifier#source.bundle.jar]
INFO:  [start net.refractions.udig.style.wms:osgi.bundle$1.2.0.qualifier#source.bundle.jar]
INFO:  [end net.refractions.udig.style.wms:osgi.bundle$1.2.0.qualifier#source.bundle.jar]
INFO:  [start net.refractions.udig.tool.default:osgi.bundle$1.2.0.qualifier#source.bundle.jar]
INFO:  [end net.refractions.udig.tool.default:osgi.bundle$1.2.0.qualifier#source.bundle.jar]
INFO:  [start net.refractions.udig.tool.info:osgi.bundle$1.2.0.qualifier#source.bundle.jar]
INFO:  [end net.refractions.udig.tool.info:osgi.bundle$1.2.0.qualifier#source.bundle.jar]
INFO:  [start net.refractions.udig.tool.select:osgi.bundle$1.2.0.qualifier#source.bundle.jar]
INFO:  [end net.refractions.udig.tool.select:osgi.bundle$1.2.0.qualifier#source.bundle.jar]
INFO:  [start net.refractions.udig.tool.edit:osgi.bundle$1.2.0.qualifier#source.bundle.jar]
INFO:  [end net.refractions.udig.tool.edit:osgi.bundle$1.2.0.qualifier#source.bundle.jar]
INFO:  [start net.refractions.udig.ui:osgi.bundle$1.2.0.qualifier#source.bundle.jar]
INFO:  [end net.refractions.udig.ui:osgi.bundle$1.2.0.qualifier#source.bundle.jar]
INFO:  [start net.refractions.udig_base:osgi.bundle$1.2.0.qualifier#source.bundle.jar]
INFO:  [end net.refractions.udig_base:osgi.bundle$1.2.0.qualifier#source.bundle.jar]
INFO:  [start org.apache.log4j:osgi.bundle$1.2.12#source.bundle.jar]
INFO:  [end org.apache.log4j:osgi.bundle$1.2.12#source.bundle.jar]
INFO:  [start com.lowagie.itext:osgi.bundle$2.1.7#source.bundle.jar]
INFO:  [end com.lowagie.itext:osgi.bundle$2.1.7#source.bundle.jar]
INFO:  [start com.ats.kmlbridge.tests:osgi.bundle$1.0.0.qualifier#source.bundle.jar]
INFO:  [end com.ats.kmlbridge.tests:osgi.bundle$1.0.0.qualifier#source.bundle.jar]
INFO:  [start com.ipsysi.RDACAPP.tests:osgi.bundle$1.0.0#source.bundle.jar]
INFO:  [end com.ipsysi.RDACAPP.tests:osgi.bundle$1.0.0#source.bundle.jar]
INFO:  [start com.ipsysi.convert.tests:osgi.bundle$1.0.0.qualifier#source.bundle.jar]
INFO:  [end com.ipsysi.convert.tests:osgi.bundle$1.0.0.qualifier#source.bundle.jar]
INFO:  [start com.ipsysi.database.creationwizard.tests:osgi.bundle$1.0.0.qualifier#source.bundle.jar]
INFO:  [end com.ipsysi.database.creationwizard.tests:osgi.bundle$1.0.0.qualifier#source.bundle.jar]
INFO:  [start com.ipsysi.database.editor.test:osgi.bundle$1.0.0.qualifier#source.bundle.jar]
INFO:  [end com.ipsysi.database.editor.test:osgi.bundle$1.0.0.qualifier#source.bundle.jar]
INFO:  [start com.ipsysi.database.importer.test:osgi.bundle$1.0.0.qualifier#source.bundle.jar]
INFO:  [end com.ipsysi.database.importer.test:osgi.bundle$1.0.0.qualifier#source.bundle.jar]
INFO:  [start com.ipsysi.database.tests:osgi.bundle$1.0.0#source.bundle.jar]
INFO:  [end com.ipsysi.database.tests:osgi.bundle$1.0.0#source.bundle.jar]
INFO:  [start com.ipsysi.dis.tests:osgi.bundle$1.0.0.qualifier#source.bundle.jar]
INFO:  [end com.ipsysi.dis.tests:osgi.bundle$1.0.0.qualifier#source.bundle.jar]
INFO:  [start com.ipsysi.export.test:osgi.bundle$1.0.0.qualifier#source.bundle.jar]
INFO:  [end com.ipsysi.export.test:osgi.bundle$1.0.0.qualifier#source.bundle.jar]
INFO:  [start com.ipsysi.geotifftovectorimporttool.tests:osgi.bundle$1.0.0#source.bundle.jar]
INFO:  [end com.ipsysi.geotifftovectorimporttool.tests:osgi.bundle$1.0.0#source.bundle.jar]
INFO:  [start com.ipsysi.importtodatabasetool.tests:osgi.bundle$1.0.0#source.bundle.jar]
INFO:  [end com.ipsysi.importtodatabasetool.tests:osgi.bundle$1.0.0#source.bundle.jar]
INFO:  [start com.ipsysi.incidentreportingtool.tests:osgi.bundle$1.0.0.qualifier#source.bundle.jar]
INFO:  [end com.ipsysi.incidentreportingtool.tests:osgi.bundle$1.0.0.qualifier#source.bundle.jar]
INFO:  [start com.ipsysi.patcher.tests:osgi.bundle$1.0.0#source.bundle.jar]
INFO:  [end com.ipsysi.patcher.tests:osgi.bundle$1.0.0#source.bundle.jar]
INFO:  [start com.ipsysi.rdacengine.operations.tests:osgi.bundle$1.0.0#source.bundle.jar]
INFO:  [end com.ipsysi.rdacengine.operations.tests:osgi.bundle$1.0.0#source.bundle.jar]
INFO:  [start com.ipsysi.rdacengine2.tests:osgi.bundle$1.0.0#source.bundle.jar]
INFO:  [end com.ipsysi.rdacengine2.tests:osgi.bundle$1.0.0#source.bundle.jar]
INFO:  [start com.ipsysi.sldeditor.tests:osgi.bundle$1.0.0#source.bundle.jar]
INFO:  [end com.ipsysi.sldeditor.tests:osgi.bundle$1.0.0#source.bundle.jar]
INFO:  [start com.ats.tests:osgi.bundle$1.0.0#source.bundle.jar]
INFO:  [end com.ats.tests:osgi.bundle$1.0.0#source.bundle.jar]
INFO:  [start com.ats.rdac.build.tests:eclipse.feature$1.0.0.qualifier#source.feature.jar]
INFO:  [end com.ats.rdac.build.tests:eclipse.feature$1.0.0.qualifier#source.feature.jar]
INFO:  [start com.ats.rdac.build.tests.site:eclipse.feature$1.0.0.qualifier#copy.subfeatures]
INFO:  [end com.ats.rdac.build.tests.site:eclipse.feature$1.0.0.qualifier#copy.subfeatures]
INFO:  [start com.ats.rdac.build.tests.site:eclipse.feature$1.0.0.qualifier#manifest]
INFO:  [end com.ats.rdac.build.tests.site:eclipse.feature$1.0.0.qualifier#manifest]
INFO:  [start com.ats.rdac.build.tests.site:eclipse.feature$1.0.0.qualifier#site.p2]
Error - 1 icon(s) not replaced in C:\Documents and Settings\justin.lynch\Local Settings\Temp\p2.brandingIron1020078565068339772\launcher.exe using C:\hudson\jobs\RDACTests\workspace\net.refractions.udig\icons\udig.ico
Error - 4 icon(s) not replaced in C:\Documents and Settings\justin.lynch\Local Settings\Temp\p2.brandingIron1215346713632878708\launcher.exe using C:\hudson\jobs\RDACTests\workspace\com.ipsysi.RDACAPP\icons\links\greenrdacgicon16.bmp
INFO:  [end com.ats.rdac.build.tests.site:eclipse.feature$1.0.0.qualifier#site.p2]
INFO:  [start com.ats.rdac.build.tests.site:eclipse.feature$1.0.0.qualifier#create.product]
[ant] C:\buckTest\buckminster\plugins\org.eclipse.equinox.launcher_1.1.1.R36x_v20101122_1400.jar
[ant] file:/c:/hudson/jobs/RDACTests/workspace/buckminster.output/com.ats.rdac.build.tests.site_1.0.0-eclipse.feature/site.p2/
[ant] c:\hudson\jobs\RDACTests\workspace\buckminster.output\com.ats.rdac.build.tests.site_1.0.0-eclipse.feature\rdac.win32.win32.x86
INFO:  [end com.ats.rdac.build.tests.site:eclipse.feature$1.0.0.qualifier#create.product]
INFO:  [start com.ats.rdac.build.tests.site:eclipse.feature$1.0.0.qualifier#create.product.zip]
INFO:  [end com.ats.rdac.build.tests.site:eclipse.feature$1.0.0.qualifier#create.product.zip]
INFO:  junit '-l' '/com.ats.tests-osgi.bundle/AllTests.launch'
Cannot open launch config from /com.ats.tests-osgi.bundle/AllTests.launch
Finished: FAILURE
Re: "Cannot open launch config from" when trying to run junit [message #665804 is a reply to message #665755] Sat, 16 April 2011 01:58 Go to previous messageGo to next message
On 2011-04-15 20:09, JLynch@appliedtrg.com wrote:
> I have been trying for the last few days to get the junit command to work on my RCP project that is successfully being
> built by buckminster on my Hudson server. The error code I get is "Cannot open launch config from
> /com.ats.tests_1.0.0-osgi.bundle/AllTests.launch" . I know that the command wants the plug-in name that the launch file
> is in.
No, that's false. The command want's the workspace location of the config file, i.e. the name of the project as it is
shown in your package explorer. Assuming that you project name is 'com.ats.tests', you should try:
junit -l com.ats.tests/AllTests.launch
If in doubt, the command junit --help is your friend. Among other things, it prints the full explanation of the -l
parameter as:
-l
--launch
The workspace location of the *.launch file that specifies the tests to run. If, for example,
your workspace contains a project named "com.acme.foobar" and this contains a launch
configuration named "alltests.launch", you would pass "com.acme.foobar/alltests.launch" as an
argument to the "-l" parameter.
HTH,
Thomas Hallgren
Re: "Cannot open launch config from" when trying to run junit [message #666039 is a reply to message #665804] Mon, 18 April 2011 13:54 Go to previous messageGo to next message
I agree that
should be the correct command. As I wrote that was my first try. Sadly that doesn't work. After figuring the help for the command must simply be wrong I started my search to see what google would provide. It provided other people saying the help was wrong and you needed to use the name it resolved to after building it in buckminister. Now I have tried both ways and it still does not work. I am really at a loss as to what I am doing wrong. I am sure it is something simple but I don't know what it is.
I tried
again just to make sure that didn't work. I get the following:
INFO:  junit '-l' 'com.ats.tests/AllTests.launch'
Cannot open launch config from com.ats.tests/AllTests.launch
I have verified that com.ats.tests has AllTests.launch in it in the workspace. I have verified that the project name is com.ats.tests and that the plug-in name is com.ats.tests.
Justin
Re: "Cannot open launch config from" when trying to run junit [message #666094 is a reply to message #666039] Tue, 19 April 2011 02:16 Go to previous messageGo to next message
On 2011-04-18 19:54, Justin Lynch wrote:
> I agree that junit -l com.ats.tests/AllTests.launch should be the correct command. As I wrote that was my first try.
That's wrong. It's never been that way. The help is correct.
> I tried junit -l com.ats.tests/AllTests.launch again just to make sure that didn't work. I get the following:
> com.ats.tests and that the plug-in name is com.ats.tests. Thanks,
> Justin
That is surprising. The code the prints that message is no rocket science. It does this:
IResource launchFile = ResourcesPlugin.getWorkspace().getRoot().findMember(launchNa me);
if (launchFile == null || launchFile.getType() != IResource.FILE || !launchFile.exists())
throw BuckminsterException.fromMessage(NLS.bind(Messages.Launch_Ca nnot_open_launch_config, launchName));
The 'launchName' in this case is what you pass in. Are you using a -data <workspace> option to appoint your workspace?
If not, how do you ensure that you use the right workspace?
- thomas
Re: "Cannot open launch config from" when trying to run junit [message #666243 is a reply to message #666094] Tue, 19 April 2011 10:48 Go to previous messageGo to next message
Thank You for your response. I am really lost as to what I am doing wrong.
I am not specifying the workspace. I am running buckminster from Hudson, since the workspace isn't specified for the other commands I assumed that the Hudson buckminister plug-in was passing that information on. When I attempted to run
 -data ${WORKSPACE} junit -l com.ats.tests/com.ats.tests.AllTests
I got:
Command '-data' not found
Help text for buckminster:
This is the common launcher for commands.
Followed by the rest of the buckminster help.
From the command line (not in Hudson) I tried:
C:\buckTest\buckminster>buckminster -data c:\hudson\jobs\RDACTests\workspace junit -l com.ats.tests\AllTests.launch
Cannot open launch config from com.ats.tests\AllTests.launch
The file currently sits at 'C:\hudson\jobs\RDACTests\workspace\com.ats.tests\AllTests.l aunch'
Thanks again for all your help!
Re: "Cannot open launch config from" when trying to run junit [message #666260 is a reply to message #666243] Tue, 19 April 2011 11:57 Go to previous messageGo to next message
The physical location of the file doesn't matter. It can be anywhere. The important thing is that your workspace
contains a (logical) project with that name.
Try starting an Eclipse IDE on the workspace. My guess is that you won't find the launch file there either.
- thomas
Re: "Cannot open launch config from" when trying to run junit [message #666264 is a reply to message #666260] Tue, 19 April 2011 12:23 Go to previous messageGo to next message
Ok some progress I have my eclipse workspace at c:\java\udig\workspace and that workspace works with the console command. My workspace built and run by Hudson/buckminister does not work. I am not sure what I need to do differently to make that work.
Your probably right. I am unsure of what I need to do to have hudson/buckminster create the workspace.
Re: "Cannot open launch config from" when trying to run junit [message #666312 is a reply to message #666264] Tue, 19 April 2011 16:37 Go to previous messageGo to next message
I spoke too soon. After some time passes I get 'java.lang.NullPointerException' and it quits.
ran with:
buckminster -data c:\java\udig\workspace junit -l com.ats.tests/AllTests.launch -o c:\buckTest\buckminster\test.xml
Re: "Cannot open launch config from" when trying to run junit [message #780302 is a reply to message #665755] Tue, 17 January 2012 10:08 Go to previous messageGo to next message
I ran into the same problem but I could sort it out, so I thought I shared my case here, maybe someone googling around will find it useful.
In my case the problem was that the .cquery containing the root component (say C_A) did not imported the project that contained the launch configuration (say C_B). (Since C_B was not among C_A's dependencies, that was correct). This means of course that there was no such project in the workspace (though it was present physically due to a former svn co) and the
ResourcesPlugin.getWorkspace().getRoot().findMember(launchName);
call above obviously did not return the launch configuration... As it correctly should not Smile
So what I did is that I imported additional components (with some other .cqueries), too, so that the workspace contains the project with the launch config. After that the junit command found the launch configuration correctly.
Gabor
Re: "Cannot open launch config from" when trying to run junit [message #784486 is a reply to message #780302] Fri, 27 January 2012 10:51 Go to previous messageGo to next message
Hi Gabor,
Many, MANY thanks for sharing. I just hit that same wall and your post helped me around it.
There's a significant annoyance in using the cquery: as all *.test projects are by definition not referenced from any bundle, it will require one cquery for each .test bundle in the project. (At least in my limited understanding of Buckminster)
Is there another way to load all the tests at once? Maybe a hand-crafted BOM would help? Let's try...
kr, Gerard.
Re: "Cannot open launch config from" when trying to run junit [message #784500 is a reply to message #784486] Fri, 27 January 2012 11:16 Go to previous messageGo to next message
Just generated a BOM from a CQUERY and it looks daunting. I'm rolling a CQUERY for each .test bundle we have. Seems #overkill to me. Maybe the Junit task should read the launch file from the filesystem and not from the workspace? This is another of those "<componentX> is not known to Buckminster" issues.
kr, Gerard
Re: "Cannot open launch config from" when trying to run junit [message #784532 is a reply to message #784500] Fri, 27 January 2012 12:05 Go to previous messageGo to next message
See the thread http://www.eclipse.org/forums/index.php/t/262698/ in this forum, partiuclarly the second post, in which I explain how how I use a buckminster.cspex to make sure the test projects are materialized, wihtout adding them as bundle dependencies. Further down that thread is a another interesting solution.
Matthew Webber
Re: "Cannot open launch config from" when trying to run junit [message #784538 is a reply to message #784532] Fri, 27 January 2012 12:13 Go to previous message
Hi Matthew,
Thanks for that one. How a buckminster.cspex would compare/contrast to a .cquery to resolve the tests? I just rolled a 'test.cquery' on each test fragment. The consequence is that the buckminster.script now has additional import statements. One for each test fragment.
The test feature mentioned in the thread you provided is a neat way. I might try that one if I've some time left (after the build works again)
-kr, Gerard.
Previous Topic:[buckminster headless] Is there an out-of-the-box way to build a product?
Next Topic:Buckminster headless Subclipse download site is old version
Current Time: Fri Jul 25 21:28:57 EDT 2025
Powered by FUDForum. Page generated in 0.05248 seconds
