| BIRT Engine cant open report after stop/start app in tomcat [message #660926] |
Tue, 22 March 2011 07:44  |
Hello.
I write simple spring webapp to render BIRT report in html format.
My BIRT runtime (2.6.2) installed in /J2EE/birt-runtime-2_6_2/ReportEngine/ directory
When I run app first time, all is OK, a see report on the page.
But when I redeploy app, or start and then stop it using Tomcat Manager I get this exception when access page:
org.eclipse.birt.report.model.metadata.ExtensionManagerImpl.initialize(ExtensionManagerImpl.java:103)
org.eclipse.birt.report.model.metadata.MetaDataDictionary.intializeExtension(MetaDataDictionary.java:1169)
org.eclipse.birt.report.model.api.impl.DesignEngineImpl.initialize(DesignEngineImpl.java:99)
org.eclipse.birt.report.model.api.impl.DesignEngineImpl.newSessionHandle(DesignEngineImpl.java:147)
org.eclipse.birt.report.model.api.DesignEngine.newSessionHandle(DesignEngine.java:120)
org.eclipse.birt.report.engine.parser.ReportParser.getDesignHandle(ReportParser.java:143)
org.eclipse.birt.report.engine.api.impl.ReportEngineHelper.getReportDesignHandle(ReportEngineHelper.java:255)
org.eclipse.birt.report.engine.api.impl.ReportEngineHelper.openReportDesign(ReportEngineHelper.java:274)
org.eclipse.birt.report.engine.api.impl.ReportEngineHelper.openReportDesign(ReportEngineHelper.java:196)
org.eclipse.birt.report.engine.api.impl.ReportEngineHelper.openReportDesign(ReportEngineHelper.java:130)
org.eclipse.birt.report.engine.api.impl.ReportEngine.openReportDesign(ReportEngine.java:295)
I wrote JUnit test class to check this behaviour:
package birt;
import java.io.*;
import java.util.logging.Level;
import org.eclipse.birt.core.exception.BirtException;
import org.eclipse.birt.core.framework.Platform;
import org.eclipse.birt.report.engine.api.*;
import org.junit.Test;
public class BirtTest {
@Test
public void testReport() throws IOException, BirtException {
String report = "/J2EE/birt-runtime-2_6_2/WebViewerExample/test.rptdesign";
BirtEngine birtEngine = new BirtEngine();
birtEngine.render(report);
birtEngine.shutdown();
// BirtEngine birtEngine2 = new BirtEngine();
// birtEngine2.render(report);
// birtEngine2.shutdown();
public static class BirtEngine {
private IReportEngine reportEngine;
public BirtEngine() throws BirtException {
EngineConfig config = new EngineConfig();
config.setBIRTHome("/home/shumilin/J2EE/birt-runtime-2_6_2/ReportEngine/");
config.setLogConfig("/home/shumilin/J2EE/birt-runtime-2_6_2/logs/", Level.FINEST);
Platform.startup(config);
IReportEngineFactory factory =
(IReportEngineFactory) Platform.createFactoryObject(
IReportEngineFactory.EXTENSION_REPORT_ENGINE_FACTORY);
reportEngine = factory.createReportEngine(config);
public void shutdown() {
if(reportEngine == null)
return;
reportEngine.destroy();
Platform.shutdown();
reportEngine = null;
public String render(String report) throws EngineException, UnsupportedEncodingException {
IReportRunnable runnable = reportEngine.openReportDesign(report);
IRunAndRenderTask runAndRenderTask = reportEngine.createRunAndRenderTask(runnable);
ByteArrayOutputStream bos = new ByteArrayOutputStream();
HTMLRenderOption options = new HTMLRenderOption();
options.setOutputFormat("html");
options.setOutputStream(bos);
options.setEmbeddable(true);
runAndRenderTask.setRenderOption(options);
runAndRenderTask.run();
return new String(bos.toByteArray(), "UTF-8");
and execution fails on commented lines in test birtEngine2.render(report) with the same exception. log file contains only this additional info:
Mar 22, 2011 2:18:47 PM org.eclipse.birt.report.engine.api.impl.ReportEngine openReportDesign
FINE: ReportEngine.openReportDesign: designName=/J2EE/birt-runtime-2_6_2/WebViewerExample/test.rptdesign
Mar 22, 2011 2:18:47 PM org.eclipse.birt.report.model.metadata.ExtensionLoader handleError
SEVERE: Message:Duplicate style names when adding the predefined style [crosstab] to the meta-data dictionary. Error code:DUPLICATE_STYLE_NAME
SEVERE: Message:Duplicate style names when adding the predefined style [crosstab-header] to the meta-data dictionary. Error code:DUPLICATE_STYLE_NAME
SEVERE: Message:Duplicate style names when adding the predefined style [crosstab-detail] to the meta-data dictionary. Error code:DUPLICATE_STYLE_NAME
SEVERE: Message:Duplicate style names when adding the predefined style [crosstab-row-header] to the meta-data dictionary. Error code:DUPLICATE_STYLE_NAME
SEVERE: Message:Duplicate style names when adding the predefined style [crosstab-column-header] to the meta-data dictionary. Error code:DUPLICATE_STYLE_NAME
SEVERE: Message:Duplicate style names when adding the predefined style [crosstab-row-grand-total] to the meta-data dictionary. Error code:DUPLICATE_STYLE_NAME
SEVERE: Message:Duplicate style names when adding the predefined style [crosstab-column-grand-total] to the meta-data dictionary. Error code:DUPLICATE_STYLE_NAME
SEVERE: Message:Duplicate style names when adding the predefined style [crosstab-row-sub-total] to the meta-data dictionary. Error code:DUPLICATE_STYLE_NAME
SEVERE: Message:Duplicate style names when adding the predefined style [crosstab-column-sub-total] to the meta-data dictionary. Error code:DUPLICATE_STYLE_NAME
SEVERE: Message:Duplicate style names when adding the predefined style [crosstab-cell] to the meta-data dictionary. Error code:DUPLICATE_STYLE_NAME
SEVERE: Message:Duplicate style names when adding the predefined style [chart] to the meta-data dictionary. Error code:DUPLICATE_STYLE_NAME
When I comment and run test- all is OK, but it looks like a hack.
What's wrong with my code, or maybe with my BIRT installation?
Can somebody help me with this issue, please.
| Re: BIRT Engine cant open report after stop/start app in tomcat [message #666090 is a reply to message #665792] |
Tue, 19 April 2011 01:32   |
My environment:
BIRT 2.6.2 (Birt runtime without any changes installed in BIRT_HOME)
Tomcat 6.0.26 (installed in TOMCAT_HOME)
JUnit 4.8
IntelliJ IDEA 10
1) Tomcat workaround:
My mistake was, that I'd put all jars from BIRT_HOME/lib into TOMCAT_HOME/lib. It's bad idea.
After several experiments I'd left only this jars in TOMCAT_HOME/lib:
- com.ibm.icu_4.2.1.v20100412.jar
- js.jar
But I had to include these jars into WEB-INF/lib folder of webapp, not in TOMCAT_HOME/lib:
- coreapi.jar
- engineapi.jar
- modelapi.jar
2) IntelliJ workaround (for running JUnit test)
Problem with JUnit test was in wrong configuration of Shared lib, used for running test.
I'd defined Global library with too many jars (all from BIRT_HOME/plugins + BIRT_HOME/libs)
When I'd left only BIRT_HOME/libs test worked.
P.S. I think, set of jars, wich have to be in classpath of webapp, depends on content of report.
For my production report, where I use css, I have to add (in TOMCAT_HOME/lib):
- flute.jar
- org.w3c.css.sac_1.3.0.v200805290154.jar
This deploy configuration works for me, but may be you should tune yours additionally.
Jason, what can you say about such implementation of Enterprise App for WebSphere, wich depends on BIRT:
- I've 10-15 independent webapps in ear.
- All use BIRT for reporting and all need functionality of WebViewer.
- I cant physically add WebViewer (50M) into each webapp
- I cant install WebViewer side by side, because I use my app classes in reports
So I decided to write custom ReportGenerator (see post above)
and generate reports manually with single BIRT installation in BIRT_HOME.
| Re: BIRT Engine cant open report after stop/start app in tomcat [message #666338 is a reply to message #666090] |
Tue, 19 April 2011 22:27   |
Any chance we can get this wrapped up in a bugzilla entry. We are
currently working on a simplified runtime and it would be good to get
this scenario addressed. Also not you could use the BIRT tag libraries
and do cross context.
Jason
On 4/19/2011 1:32 AM, S.Shumilin wrote:
> My environment:
> JUnit 4.8
> IntelliJ IDEA 10
> - js.jar
> in TOMCAT_HOME/lib:
> - coreapi.jar
> - engineapi.jar
> - modelapi.jar
> for running test.
> TOMCAT_HOME/lib):
> - flute.jar
> additionally.
> reports
| Re: BIRT Engine cant open report after stop/start app in tomcat [message #686395 is a reply to message #666354] |
Wed, 22 June 2011 03:09   |
Hi Guys
I have the same problem , with a scripted data source report.I have 2 runs in my test. In the first run the report runs successfully with no errors, but in the second it returns with the following exception:
at org.eclipse.birt.report.model.metadata.ExtensionManagerImpl.initialize(ExtensionManagerIm
pl.java:103)
at org.eclipse.birt.report.model.metadata.MetaDataDictionary.intializeExtension(MetaDataDict
ionary.java:1169)
at org.eclipse.birt.report.model.api.impl.DesignEngineImpl.initialize(DesignEngineImpl.java:
99)
at org.eclipse.birt.report.model.api.impl.DesignEngineImpl.newSessionHandle(DesignEngineImpl
.java:147)
at org.eclipse.birt.report.model.api.DesignEngine.newSessionHandle(DesignEngine.java:120)
at org.eclipse.birt.report.engine.parser.ReportParser.getDesignHandle(ReportParser.java:143)
at org.eclipse.birt.report.engine.api.impl.ReportEngineHelper.getReportDesignHandle(ReportEn
at org.eclipse.birt.report.engine.api.impl.ReportEngineHelper.openReportDesign(ReportEngineH
elper.java:274)
elper.java:184)
elper.java:161)
at org.eclipse.birt.report.engine.api.impl.ReportEngine.openReportDesign(ReportEngine.java:3
34)
I get the following in my Report logs:
22 Jun, 2011 10:39:38 AM org.eclipse.birt.report.engine.api.impl.ReportEngine openReportDesign
FINE: ReportEngine.openReportDesign: designStream=java.io.FileInputStream@59aa86
22 Jun, 2011 10:39:38 AM org.eclipse.birt.report.model.metadata.ExtensionLoader handleError
SEVERE: Message:Duplicate extension name when adding the extension [Chart] to the meta-data dictionary. Error code:DUPLICATE_EXTENSION_NAME
SEVERE: Message:Duplicate extension name when adding the extension [Crosstab] to the meta-data dictionary. Error code:DUPLICATE_EXTENSION_NAME
SEVERE: Message:Duplicate extension name when adding the extension [CrosstabView] to the meta-data dictionary. Error code:DUPLICATE_EXTENSION_NAME
SEVERE: Message:Duplicate extension name when adding the extension [DimensionView] to the meta-data dictionary. Error code:DUPLICATE_EXTENSION_NAME
SEVERE: Message:Duplicate extension name when adding the extension [LevelView] to the meta-data dictionary. Error code:DUPLICATE_EXTENSION_NAME
SEVERE: Message:Duplicate extension name when adding the extension [MeasureView] to the meta-data dictionary. Error code:DUPLICATE_EXTENSION_NAME
SEVERE: Message:Duplicate extension name when adding the extension [ComputedMeasureView] to the meta-data dictionary. Error code:DUPLICATE_EXTENSION_NAME
SEVERE: Message:Duplicate extension name when adding the extension [CrosstabCell] to the meta-data dictionary. Error code:DUPLICATE_EXTENSION_NAME
SEVERE: Message:Duplicate extension name when adding the extension [AggregationCell] to the meta-data dictionary. Error code:DUPLICATE_EXTENSION_NAME
Kindly advise what needs to be done.
My environment details are:
birt 2.6.2
tomcat 6.0.20
[Updated on: Wed, 22 June 2011 03:13] by Moderator
FUDForum. Page generated in 0.49635 seconds
