Home » Archived » M2M (model-to-model transformation) » New to this field, how to start(how to start using this plug-in )
New to this field, how to start [message #665676] Fri, 15 April 2011 09:00 Go to next message
Hi guys
I want to write a transformation tool to transform an emf model to an emof model, can any one guide me how to write the required codes? I keep getting these error messages.
thanks
Re: New to this field, how to start [message #665732 is a reply to message #665676] Fri, 15 April 2011 12:06 Go to previous messageGo to next message
Salman,
What does EMF -> EMOF mean? What you tried?
Salman wrote:
> Hi guys
> thanks
Re: New to this field, how to start [message #665746 is a reply to message #665676] Fri, 15 April 2011 12:40 Go to previous messageGo to next message
Hi Salman
EMF already provides EMOF support..
Interactively, in the Sample Ecore Editor do SaveAs... something.emof.
Programmatically, load your Ecore Resource, then set its URI to
something.emof and save; remembering to register the EMOFResourceFactory
for the *.emof extension in the ResourceSet package registry.
If you really want to write a transformation you need to choose a
language: Java, ATL, Epsilon, QVTo, Viatra, Xtend are all possible.
Ed Willink
On 15/04/2011 14:00, Salman wrote:
> Hi guys
> thanks
Re: New to this field, how to start [message #665778 is a reply to message #665746] Fri, 15 April 2011 16:58 Go to previous messageGo to next message
Thanks Edward
actually I want to write a new transformation using QVTo, but I dont know how to use it, I mean Even at the beginning when I want to declare the meta-models I keep getting errors do you know any tutorial or help document for a beginner like me Wink
thanks
Re: New to this field, how to start [message #665785 is a reply to message #665778] Fri, 15 April 2011 17:40 Go to previous message
New->Example will give you a working UML to RDBMS that demonstrates a
variety of concepts. I'm not sure that there is anything else.
Ed Willink
On 15/04/2011 21:58, Salman wrote:
> Thanks Edward
> or help document for a beginner like me ;) thanks
Previous Topic:[ATL] Passing parameters from XML in Query
Next Topic:OclType and oclAsType issues
Current Time: Sat Jul 26 12:51:31 EDT 2025
Powered by FUDForum. Page generated in 0.26189 seconds
