Home » Modeling » TMF (Xtext) » [Xtend2] Problems with method modifiers
[Xtend2] Problems with method modifiers [message #665590] Fri, 15 April 2011 04:02 Go to next message
2 questions, one about method visibility and the other about generating
static methods
1)I have problems when adding visibility modifiers in xtend2 files.
public generate(){''''''} reports:
Couldn't resolve reference to JvmType 'public'.
Incompatible implicit return type. Expected void but was
org.eclipse.xtext.xtend2.lib.StringConcatenation
public StringConcatenation generate(){''''''} reports:
extraneous input 'generate' expecting '('
Also tried with the '^' character but without success
According to online help, I could declare a method as protected or
private, but neither works (same errors)
2)In the specifications it is not mentioned the possibility to generate
in xtend2 static method (although you can import static). The reason I'm
asking is that I have a really big xtend file (little more than 1000
rows) and template validation/compilation/linking is awfully slow.
I noticed that things really speed up if I work by splitting the big
template in "modules" and import them statically in a sort of 'master
template'. the only thing making this impossible is that 'static'
keyword is not recognized. Is there a reason for this?
many thanks
Alex
Re: [Xtend2] Problems with method modifiers [message #665624 is a reply to message #665590] Fri, 15 April 2011 06:00 Go to previous messageGo to next message
Hi Alex,
visibility modifiers are not yet implemented. They are likely to appear
before the next milestone.
Please file a ticket with the template file that is awefully slow.
No, we do not plan to support the definition of static methods. You
could use different files and reuse them by means of dynamic dependencies.
Instead of
import static org.mypack.MyXtendClass
you can use
@Inject org.mypack.MyXtendClass as fieldName
in the class body where the part 'as fieldName' is optional. The name
'myXtendClass' will be used as the default if you do not specify
something explicitly.
A ticket with your slow file attached would be helpful.
Sebastian
Am 15.04.11 10:02, schrieb carraro.alessandro@gmail.com:
> static methods
> many thanks
> Alex
Re: [Xtend2] Problems with method modifiers [message #727607 is a reply to message #665624] Wed, 21 September 2011 11:57 Go to previous messageGo to next message
Hi Sebastian,
Sebastian Zarnekow wrote on Fri, 15 April 2011 12:00
Instead of
you can use
First: "as" gives a syntax error Smile
If dynamic dependencies are the recommended way for imports among xtend files, doesn't that mean that methods defined in one xtend file cannot be used as extension methods in another xtend file?
It would be useful to say
import static extension MyOtherXtendClass.*
If instead I have to use
@Inject MyOtherXtendClass delegate
I have to invoke those functions as
delegate.m(a1, a2)
instead of
a1.a2
right?
something seems to be missing.
Stephan
Re: [Xtend2] Problems with method modifiers [message #727721 is a reply to message #727607] Wed, 21 September 2011 17:16 Go to previous messageGo to next message
> It would be useful to say import static extension MyOtherXtendClass.*
> delegate.m(a1, a2)
> instead of
> a1.a2
> right?
You can combine @Inject with extension and get the effect you want:
@Inject extension SomeClass
Since you don't need the field name in the call, you can omit it in the
declaration.
Hallvard
Re: [Xtend2] Problems with method modifiers [message #728043 is a reply to message #665624] Thu, 22 September 2011 08:55 Go to previous messageGo to next message
Sebastian Zarnekow wrote on Fri, 15 April 2011 06:00
Instead of
you can use
Sometimes it's not possible to impact the creation of an instance of an Xtend class. As the class is not instantiated by Guice MyXtendClass is not injected. Defining static methods in Xtend would bypass this problem, I think.
Re: [Xtend2] Problems with method modifiers [message #728052 is a reply to message #727721] Thu, 22 September 2011 09:09 Go to previous message
Hallvard Traetteberg wrote on Wed, 21 September 2011 23:16
declaration.
Hallvard
Thanks, I didn't see this option. BTW, there seem to be different versions of Xtend2 syntax, neither the "as" syntax mentioned before, nor omitting the field name worked for me, but that's a minor issue.
Oliver L wrote on Thu, 22 September 2011 14:55
I agree. So far my experience with Guice in Xtext isn't all sunshine and roses so I'd prefer using less injection rather then more.
thanks for your replies,
Stephan
[Updated on: Thu, 22 September 2011 09:11] by Moderator
Previous Topic:Declaring predicates
Next Topic:DSL > XMI > DSL
Current Time: Sat Jul 19 01:31:42 EDT 2025
Powered by FUDForum. Page generated in 0.22597 seconds
