Home » Modeling » Epsilon » [ETL] Exception met in applying stereotype(How is IllegalArgumentException in applying stereotype can be handled?)
[ETL] Exception met in applying stereotype [message #663653] Wed, 06 April 2011 01:10 Go to next message
Hi? I'm newcomer to Epsilon to implement MDD.
I just started using ETL for a model transformation with UML model. For this, I specified a profile already. And I tried to apply the stereotypes I specified to the UML model element but to fail.
To apply stereotypes, I found a topic in this forum and followed the sample code but it didn't work for me.
My code snippet is as follows;
rule BCInterface2Component
	transform a_bc_if : UML_A!Interface
	to d_bc_comp : UML_D!Component {
		guard : a_bc_if.getAppliedStereotypes()->exists(s|s.name='BC')
		var a_st = a_bc_if.getAppliedStereotypes().selectOne(s|s.name='BC');
		var prop = a_st.ownedAttribute.selectOne(s|s.name='subType');
		-- BC Component mapping
		var st = MyProfile!Stereotype.all.selectOne(s|s.name='BC');
		d_bc_comp.applyStereotype(st);
		d_bc_comp.name = a_bc_if.name;
When running with this rule a model transformation, I go the following error messages.
Internal error: java.lang.IllegalArgumentException: org.eclipse.uml2.uml.internal.impl.StereotypeImpl@139e05a [name: Focus, visibility: <unset>] [isLeaf: false, isAbstract: false] [isActive: false]
	at org.eclipse.uml2.uml.internal.operations.ElementOperations.applyStereotype[ElementOperations.java:1411]
	at org.eclipse.uml2.uml.internal.impl.ElementImpl.applyStereotype[ElementImpl.java:510]
	at sun.reflect.NativeMethodAccessorImpl.invoke0[Native Method]
	at sun.reflect.NativeMethodAccessorImpl.invoke[NativeMethodAccessorImpl.java:39]
	at sun.reflect.DelegatingMethodAccessorImpl.invoke[DelegatingMethodAccessorImpl.java:25]
	at java.lang.reflect.Method.invoke[Method.java:597]
I didn't know what the problem is. Please help me.
Another thing I want to know is how to get and set values of stereotype properties. As I know in UML2 Java API there are methods for that purpose named "getValue" and "setValue" in Stereotype interface.
Thank you in advance.
Re: [ETL] Exception met in applying stereotype [message #663686 is a reply to message #663653] Wed, 06 April 2011 04:15 Go to previous messageGo to next message
Could you please put together a minimal configuration (transformation, profile, input model etc) we can use to reproduce this and send it to us at epsilon.devs gmail com?
Dimitris
Re: [ETL] Exception met in applying stereotype [message #665040 is a reply to message #663686] Tue, 12 April 2011 22:43 Go to previous messageGo to next message
Hi, Dimitris
I finally found how to apply stereotypes to UML elements.
The mistake I made is that I tried to apply stereotype an element before it
was added to its owner. So, I got an empty applicable stereotypes before
added to an owner.
I solved using in post block.
But I still wonder how can I apply stereotype along with transformation for
every equivalent element from source to target in transformation rules.
Sungwook.
Re: [ETL] Exception met in applying stereotype [message #665622 is a reply to message #663653] Fri, 15 April 2011 05:59 Go to previous message
Hi Sungwook,
Would it make sense to use a "pre" block instead to do any necessary preparations so that you can then apply stereotypes within the transformation rules?
Dimitris
Previous Topic:Epsilon Extensibility and Eugenia Extensibility
Next Topic:[Epsilon] Standalone
Current Time: Sun Jul 27 02:10:48 EDT 2025
Powered by FUDForum. Page generated in 0.04086 seconds
