Home » Archived » Buckminster » How to resolve the host-bundle of an osgi fragment?
How to resolve the host-bundle of an osgi fragment? [message #665613] Fri, 15 April 2011 05:20 Go to next message
Hi@all,
First let me say: I am quite new to buckminster, so please apologize if
the answer to my question obvious.
I have an osgi fragment which is contained in a feature. When I am using
Buckminster->Import the fragment is found, but not its host-bundle.
Buckminster does not even complain about something missing. As a result,
when I finish the import the host-bundle does not appear in the target
platform.
I solved this issue by inserting the feature, which contains the
host-bundle, into the buckminster.cspec.
But I actually assumed that buckminster would trigger the installation
of the host-bundle automatically without the declaration in the cspec.
Or is this the correct way to handle fragments?
Thanks in advance.
Martin
Re: How to resolve the host-bundle of an osgi fragment? [message #665856 is a reply to message #665613] Sun, 17 April 2011 04:52 Go to previous messageGo to next message
Hi Martin,
Are you importing the fragment directly or the feature that contains the
fragment? Do you have a feature somewhere that includes the host bundle?
- thomas
On 2011-04-15 11:20, Martin Flügge wrote:
> Hi@all,
> platform.
> Thanks in advance.
> Cheers,
> Martin
Re: How to resolve the host-bundle of an osgi fragment? [message #665874 is a reply to message #665856] Sun, 17 April 2011 14:50 Go to previous message
Hi Thomas,
thanks for your response.
I am not absolutely sure what you mean with „directly“.
The fragment is contained in a feature which itself is contained in a
feature which than is included in the cspec.
The host-bundle comes from another project. To be exact,
org.eclipse.emf.ecoretools. We included a provider into out build.rmap,
which points to the Ecore Tools repository. I thought that this would be
enough, but it was not. Only after adding the Ecore Tools feature to the
cspec it worked.
Martin
Am 17.04.2011 10:52, schrieb Thomas Hallgren:
> Hi Martin,
> - thomas
>> Hi@all,
>> platform.
>> Thanks in advance.
>> Cheers,
>> Martin
Previous Topic:basedir for feature not found
Next Topic:Possible to generate a maven repository using Buckminster?
Current Time: Sat Jul 26 10:43:12 EDT 2025
Powered by FUDForum. Page generated in 0.11735 seconds
