Home » Modeling » GMF (Graphical Modeling Framework) » GMF delete node problem
GMF delete node problem [message #662920] Fri, 01 April 2011 09:37 Go to next message
Hello everyone,
I´m facing some problems here, this is what i want to do:
When I delete a node in the diagram I would like to save some data about it in a file (ID, Name etc...)
How can I get this data just before it is deleted and save it to the file?
Thanks in advance,
Joao
Re: GMF delete node problem [message #665580 is a reply to message #662920] Fri, 15 April 2011 03:27 Go to previous messageGo to next message
you should receive an event in the edit part of the parent node when you delete the node. Doesn't that event contain the information you need ?
cheers,
emil
Re: GMF delete node problem [message #665744 is a reply to message #665580] Fri, 15 April 2011 13:12 Go to previous messageGo to next message
Hello Emil,
First of all thank you very much for your answer.
I don´t need this feature anymore in my project.
Yes, edit part receives an event but I believe that by that time the eobject instance doesn´t exists anymore.
Am I correct?
Joao
Re: GMF delete node problem [message #665931 is a reply to message #665744] Mon, 18 April 2011 04:28 Go to previous messageGo to next message
I suppose you are, I'm not sure how much information can you find in the event object about the deleted object ... Smile
I actually thought about that when I wrote my message but I hoped that would give you a least a starting point Smile
cheers,
emil.
Re: GMF delete node problem [message #1058955 is a reply to message #665931] Wed, 15 May 2013 19:23 Go to previous messageGo to next message
any solution ?
Re: GMF delete node problem [message #1060449 is a reply to message #1058955] Fri, 24 May 2013 13:05 Go to previous message
Hi Bradai,
the generated DeleteElementAction abstracts from AbstractDeleteFromAction, that shows, how a DestroyElementRequest is used to create the appropriate command from the EditPart.
You could hook into this class to get the appropriate information prior to execution.
Another approach would be to get the latest command from the commandstack and take the information from there.
Thomas
[Updated on: Fri, 24 May 2013 13:06] by Moderator
Previous Topic:Auto Resize
Next Topic:Link Constraints and shared tool element
Current Time: Sat Jul 26 21:56:54 EDT 2025
Powered by FUDForum. Page generated in 0.04559 seconds
