Completely lost.... any ideas? (Unable to launch application - errors attached) [message #665497] |
Thu, 14 April 2011 15:52  |
Guys,
I am getting the following errors when I try to run the RCP application that I have. Any ideas? It's completely lost on me!
Many thanks
Matt
!SESSION 2011-04-14 20:49:59.140 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.6.0_24
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_GB
Framework arguments: -product org.myApp.gui.product
Command-line arguments: -product org.myApp.gui.product -data W:\workspaces/../runtime-org.myApp.gui.product -dev file:W:/workspaces/.metadata/.plugins/org.eclipse.pde.core/o rg.myApp.gui.product/dev.properties -os win32 -ws win32 -arch x86 -consoleLog
!ENTRY org.eclipse.osgi 4 0 2011-04-14 20:50:00.812
!MESSAGE Application error
!STACK 1
java.lang.ExceptionInInitializerError
at org.eclipse.osgi.framework.debug.FrameworkDebugOptions.setFi le(FrameworkDebugOptions.java:438)
at org.eclipse.core.internal.runtime.DataArea.createLocation(Da taArea.java:185)
at org.eclipse.core.internal.runtime.DataArea.initializeLocatio n(DataArea.java:147)
at org.eclipse.core.internal.runtime.DataArea.assertLocationIni tialized(DataArea.java:59)
at org.eclipse.core.internal.runtime.DataArea.getStateLocation( DataArea.java:125)
at org.eclipse.core.internal.preferences.InstancePreferences.ge tBaseLocation(InstancePreferences.java:44)
at org.eclipse.core.internal.preferences.InstancePreferences.in itializeChildren(InstancePreferences.java:199)
at org.eclipse.core.internal.preferences.InstancePreferences.<init >(InstancePreferences.java:59)
at org.eclipse.core.internal.preferences.InstancePreferences.in ternalCreate(InstancePreferences.java:209)
at org.eclipse.core.internal.preferences.EclipsePreferences.cre ate(EclipsePreferences.java:289)
at org.eclipse.core.internal.preferences.EclipsePreferences.cre ate(EclipsePreferences.java:277)
at org.eclipse.core.internal.preferences.PreferencesService.cre ateNode(PreferencesService.java:390)
at org.eclipse.core.internal.preferences.RootPreferences.getChi ld(RootPreferences.java:63)
at org.eclipse.core.internal.preferences.RootPreferences.getNod e(RootPreferences.java:96)
at org.eclipse.core.internal.preferences.RootPreferences.node(R ootPreferences.java:85)
at org.eclipse.core.internal.preferences.AbstractScope.getNode( AbstractScope.java:38)
at org.eclipse.core.runtime.preferences.InstanceScope.getNode(I nstanceScope.java:71)
at org.eclipse.ui.preferences.ScopedPreferenceStore.getStorePre ferences(ScopedPreferenceStore.java:241)
at org.eclipse.ui.preferences.ScopedPreferenceStore.<init>(ScopedPreferenceStore.java:133)
at org.eclipse.ui.plugin.AbstractUIPlugin.getPreferenceStore(Ab stractUIPlugin.java:284)
at org.eclipse.ui.internal.UISynchronizer.<init>(UISynchronizer.java:88)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2456)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:24 38)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:671)
at org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:332)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:664)
at org.myApp.Application.start(Application.java:20)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:196)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:369)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 620)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:575)
at org.eclipse.equinox.launcher.Main.run(Main.java:1408)
at org.eclipse.equinox.launcher.Main.main(Main.java:1384)
Caused by: java.lang.ArrayStoreException: declaredAnnotations/7371509
at sun.text.resources.FormatData.getContents(Unknown Source)
at java.util.ListResourceBundle.loadLookup(Unknown Source)
at java.util.ListResourceBundle.handleGetObject(Unknown Source)
at java.util.ResourceBundle.getObject(Unknown Source)
at java.text.DateFormatSymbols.initializeData(Unknown Source)
at java.text.DateFormatSymbols.<init>(Unknown Source)
at java.text.DateFormatSymbols.getInstance(Unknown Source)
at java.text.SimpleDateFormat.<init>(Unknown Source)
at org.eclipse.osgi.framework.debug.EclipseDebugTrace.<clinit>(EclipseDebugTrace.java:51)
... 41 more
An error has occurred. See the log file
W:\runtime-org.myApp.gui.product\.metadata\.log.
[Updated on: Thu, 14 April 2011 16:12] by Moderator
FUDForum. Page generated in 0.06558 seconds
