Home » General (non-technical) » Eclipse Foundation » Why the white spce has smaller size before right brace...
Why the white spce has smaller size before right brace... [message #665413] Thu, 14 April 2011 10:53 Go to next message
Hi all~
I've tried many formater setting, but I can't find out the solution. The problem I suffered is that the display of the right brace is not aligned well in eclipse. I use which space to replace tab with tab size = 4. Then one can imagine the format, take below as example.
class test {
    public:
        void test () {
            XXX;
but in elipse, it shows
class test {
    public:
        void test () {
            XXX;
  } <= the alignment is displayed incorrect
How do I change the format to display correctly in eclipse. Thanks...
[Updated on: Thu, 14 April 2011 11:00] by Moderator
Re: Why the white spce has smaller size before right brace... [message #665431 is a reply to message #665413] Thu, 14 April 2011 11:16 Go to previous messageGo to next message
Originally posted by: richkulp.us.NOSPAM.ibm.com
This newsgroup is not for technical questions. It is for announcements
about Eclipse itself.
Please use a technical forum, such as eclipse.tools.jdt.
Rich Kulp
Re: Why the white spce has smaller size before right brace... [message #665437 is a reply to message #665431] Thu, 14 April 2011 11:30 Go to previous message
Ok, I got it. I just thought my problem is how to setup the format for eclipse. I didn't recognize that it's a technical problem. Sorry for the inconvinent. Thanks...
Previous Topic:Linking resources to project's root
Next Topic:Eclipse Community Survey
Current Time: Fri Jul 25 23:08:51 EDT 2025
Powered by FUDForum. Page generated in 0.03744 seconds
