Home » Archived » Buckminster » Problems using HelloXML example from BuckyBook
Problems using HelloXML example from BuckyBook [message #665269] Wed, 13 April 2011 20:33
I'm trying to work through the examples in the Bucky Book to get comfortable with Buckminster so that I can see whether or not it will be a worthwhile tool for our organization. I'm having problems right at the start of the process, though. I think it likely has to do with internet proxies. But I'm not 100% certain on that.
Anyway, I've copied the demo.cquery locally, and have attempted to "Resolve and Materialize". After doing this, I don't get anything in my "Workspace Components" section of the "Component Explorer" view, while I do get a bunch of things in the "Target Platform Components" section of the same. The Buckminster log shows the following:
ERROR [0002] : org.eclipse.team.svn.core.connector.SVNConnectorException: svn: REPORT of '/svnroot/tools/org.eclipse.buckminster/!svn/vcc/default': 501 Not Implemented (http://dev.eclipse.org)
ERROR [0011] : org.eclipse.team.svn.core.connector.SVNConnectorException: svn: REPORT of '/svnroot/tools/org.eclipse.buckminster/!svn/vcc/default': 501 Not Implemented (http://dev.eclipse.org)
ERROR [0001] : org.eclipse.team.svn.core.connector.SVNConnectorException: svn: REPORT of '/svnroot/tools/org.eclipse.buckminster/!svn/vcc/default': 501 Not Implemented (http://dev.eclipse.org)
What may be of interest is that I'm attempting to do this from behind a proxy server. I have the proxy server set up to be used in my subversion client (I have downloaded source using the subversion client) and in eclipse (I have installed plugins using this set-up)
Does anyone have any thoughts as to what's causing my problems?
-Tim
Previous Topic:The application will not start after update...
Next Topic:basedir for feature not found
Current Time: Fri Jul 18 17:19:48 EDT 2025
Powered by FUDForum. Page generated in 0.03860 seconds
