Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [EMF] Relative paths in .ecore files
[EMF] Relative paths in .ecore files [message #664127] Thu, 07 April 2011 10:51 Go to next message
if I use a .ecore file via Load Resource in another .ecore file and use/reference classes from the loaded resource, the paths are relative to the location of the referring file.
For example:
I have two ecore projects (project1, project2) and in each project there is one model (model1.ecore, model2.ecore). model1.ecore is a loaded resource in model2.ecore and classes from model1.ecore are referred by classes located in model2.ecore, i.e. Person (in model2.ecore) is a subclass of Entity (model1.ecore).
Modeling Person as subclass of Entity would result in this xml:
<eClassifiers xsi:type="ecore:EClass" name="Person" eSuperTypes="../../ecore.project1/model/model1.ecore#//core/Entity">
This will fail if I decide to move project1 to another directory so that project2 isn't in the same directory and so the relative path is broken.
Is there a possibility to generete the reference in this a format (with platform:/resource)?
<eClassifiers xsi:type="ecore:EClass" name="Person" eSuperTypes="platform:/resource/project1/model/model1.ecore#//core/Entity">
I uploaded an example here: http://tinyurl.com/3hd7o6s
Cheers
Christian
[Updated on: Thu, 07 April 2011 10:51] by Moderator
Re: [EMF] Relative paths in .ecore files [message #664151 is a reply to message #664127] Thu, 07 April 2011 11:41 Go to previous messageGo to next message
Christian,
Comments below.
Christian Huelsmeier wrote:
> Hello,
Indeed.
> For example:
> eSuperTypes="../../ecore.project1/model/model1.ecore#//core/Entity ">
> broken.
Of course you can open it in the editor and do "Save as." And of
course if you move the referenced file the referencing files will be
broken, regardless of whether the reference is relative or absolute.
> eSuperTypes=" platform:/resource/project1/model/model1.ecore#//core/Entity ">
It is possible, but it's not supported via options in the UI. One of
the primary reasons is that these relative references work even when the
resources are packaged up in the binary bundle. I.e., when the
referencing resource is loaded via platform:/plugin/.... the referenced
resource will also be loaded with a URI of that form, and all works
well. More generally, by using purely relative references we avoid
encoding any absolute knowledge about the physical location so we can
access everything via http:, file:, platform:/resource,
platform:/plugin, cvs:, or whatever, as long as we preserve the
relative/logical structure of the workspace.
> Cheers
> Christian
Re: [EMF] Relative paths in .ecore files [message #664202 is a reply to message #664151] Thu, 07 April 2011 15:53 Go to previous messageGo to next message
Ed,
thanks for your answer.
Ed Merks wrote on Thu, 07 April 2011 11:41
Can you tell me how to do this? Is there a tutorial that tells me what to do to get the references in the way I want them to look like?
Maybe there are other (and/or better) solutions.
The requirement I have is that there are two (or more) projects containing .ecore files which are somehow linked together. These projects are in the same workspace, but not necessarily located in the same directory.
Christian
Re: [EMF] Relative paths in .ecore files [message #665070 is a reply to message #664202] Wed, 13 April 2011 04:03 Go to previous messageGo to next message
Does anyone else have any suggestions?
Thanks in advance
Christian
Christian Huelsmeier wrote on Thu, 07 April 2011 15:53
Ed,
Christian
Re: [EMF] Relative paths in .ecore files [message #665195 is a reply to message #665070] Wed, 13 April 2011 11:26 Go to previous message
--------------020105040804030003020604
Christian,
This post isn't appearing in the same thread, so that doesn't help
anyone suggest much of anything...
You'd need to write your own utility to load the Ecore model and then
save it using this option with a specialized handler that produces the
URIs in the form you want.
* A {@link URIHandler} value that will be used to control how
URIs are {@link URI#resolve(URI) resolved} during load
* and {@link URI#deresolve(URI) deresolved} during save.
* @see URI
* @see URIHandler
* @see XMLHelper#resolve(URI, URI)
* @see XMLHelper#deresolve(URI)
* @see URIHandlerImpl
String OPTION_URI_HANDLER = "URI_HANDLER";
I expect that you'd be better off solving real problems instead of
focusing on this issue, which I think isn't really a problem in the
first place.
> Thanks in advance
> Christian
>> Ed,
>> of > the primary reasons is that these relative references work even
>> when the > resources are packaged up in the binary bundle. I.e.,
>> when the > referencing resource is loaded via platform:/plugin/....
>> the referenced > resource will also be loaded with a URI of that
>> form, and all works > well. More generally, by using purely relative
>> references we avoid > encoding any absolute knowledge about the
>> physical location so we can > access everything via http:, file:,
>> platform:/resource, > platform:/plugin, cvs:, or whatever, as long as
>> we preserve the > relative/logical structure of the workspace.
>> the same directory.
>> Christian
Content-Type: text/html; charset=UTF-8
<html>
<head>
<meta content="text/html;charset=UTF-8" http-equiv="Content-Type">
</head>
Christian,<br>
<br>
anyone suggest much of anything...<br>
<br>
URIs in the form you want.<br>
<blockquote><small>  /**<br>
   * A {@link URIHandler} value that will be used to control how URIs
are {@link URI#resolve(URI) resolved} during load <br>
   * and {@link URI#deresolve(URI) deresolved} during save.<br>
   * @see URI<br>
   * @see URIHandler<br>
   * @see XMLHelper#resolve(URI, URI)<br>
   * @see XMLHelper#deresolve(URI)<br>
   * @see URIHandlerImpl<br>
   */<br>
  String OPTION_URI_HANDLER = "URI_HANDLER";</small><br>
</blockquote>
first place.<br>
<br>
<br>
<blockquote cite="mid:io3ku1$qgl$1@news.eclipse.org" type="cite">Does
<br>
<br>
Thanks in advance
<br>
<br>
Christian
<br>
<br>
<br>
<blockquote type="cite">Ed,
<br>
<br>
<br>
<br>
<br>
&gt; It is possible, but it's not supported via options in the UI.
One of &gt; the primary reasons is that these relative references work
even when the &gt; resources are packaged up in the binary bundle.
I.e., when the &gt; referencing resource is loaded via
platform:/plugin/.... the referenced &gt; resource will also be loaded
with a URI of that form, and all works &gt; well.  More generally, by
using purely relative references we avoid &gt; encoding any absolute
knowledge about the physical location so we can &gt; access everything
via http:, file:, platform:/resource, &gt; platform:/plugin, cvs:, or
whatever, as long as we preserve the &gt; relative/logical structure of
the workspace.
<br>
<br>
<br>
<br>
<br>
same directory.
<br>
<br>
Christian
<br>
</blockquote>
<br>
<br>
</blockquote>
</body>
</html>
--------------020105040804030003020604--
Previous Topic:[Teneo] setting Hibernate Interceptor
Next Topic:[EMF Compare] Correctly compare non-identifiable references
Current Time: Wed Jul 23 02:04:22 EDT 2025
Powered by FUDForum. Page generated in 0.10287 seconds
