Home » Archived » EPP » Can't update "Eclipse for RCP and RAP Developers"
Can't update "Eclipse for RCP and RAP Developers" [message #665001] Tue, 12 April 2011 14:22 Go to next message
When I run "Help" > "Check for Updates" I can see that there is an update available, but it can't be installed:
Cannot complete the install because of a conflicting dependency.
Software being installed: Eclipse for RCP and RAP Developers 1.3.2.20110301-1807 (epp.package.rcp 1.3.2.20110301-1807)
Software currently installed: Shared profile 1.0.0.1298029478619 (SharedProfile_epp.package.rcp 1.0.0.1298029478619)
Only one of the following can be installed at once:
epp.package.rcp.executable.win32.win32.x86_64 1.3.2.20110301-1807
epp.package.rcp.executable.win32.win32.x86_64 1.3.2.20110218-0812
Cannot satisfy dependency:
From: Shared profile 1.0.0.1298029478619 (SharedProfile_epp.package.rcp 1.0.0.1298029478619)
To: epp.package.rcp.executable.win32.win32.x86_64 [1.3.2.20110218-0812]
From: Eclipse for RCP and RAP Developers 1.3.2.20110301-1807 (epp.package.rcp 1.3.2.20110301-1807)
To: toolingepp.package.rcp.application [1.3.2.20110301-1807]
From: toolingepp.package.rcp.application 1.3.2.20110301-1807
To: epp.package.rcp.executable.win32.win32.x86_64 [1.3.2.20110301-1807]
Re: Can't update "Eclipse for RCP and RAP Developers" [message #666567 is a reply to message #665001] Wed, 20 April 2011 23:16 Go to previous messageGo to next message
Not sure if related to your case, but there's been some similar cases
discussed in bug 339659 [1]. I haven't read it close enough to know what
the actual problem is, but seemed what helped some people was to run as
Eclipse (for the update) as "root" (Administrator) so they'd have the
right permissions for a "shared installed".
If that helps you, or doesn't, you might document your experiences in
that bug ... or, open a new one, if doesn't help, and you have some new
case.
HTH
[1] https://bugs.eclipse.org/bugs/show_bug.cgi?id=339659
Re: Can't update "Eclipse for RCP and RAP Developers" [message #666704 is a reply to message #666567] Thu, 21 April 2011 14:03 Go to previous message
David Williams wrote on Wed, 20 April 2011 23:16
I do indeed have a "shared installation" (I like to keep user-installed plugins separate), and the update does work when I run Eclipse as administrator. Thanks!
Previous Topic:Missing UDC data?
Next Topic:what does the command description in the output file mean?
Current Time: Sat Jul 19 09:13:05 EDT 2025
Powered by FUDForum. Page generated in 0.03757 seconds
