Home » Modeling » M2T (model-to-text transformation) » [Acceleo] eContainer returns invalid class
[Acceleo] eContainer returns invalid class [message #664905] Tue, 12 April 2011 09:20 Go to next message
I am writing a template with Acceleo 3.1.0M5 for generating a C file from an ecore model and I meet a weird behaviour. In my template, I just call the eContainer on my object like this :
[iConnectedData.eContainer()/]
If I run my template from eclipse as plugin I obtain :
RteLGenModel.impl.RteLGenReceiverPortImpl (shortName: ev_Mode_Change_Realized_rp, longName: null, category: ) (portInterface: ev_Mode_Change_Realized_interface) which is the expected result
but
If I run my template from a standalone java application, the result is :
org.eclipse.emf.ecore.impl.DynamicEObjectImpl (eClass: org.eclipse.emf.ecore.impl.EClassImpl (name: OclInvalid_Class) (instanceClassName: null) (abstract: false, interface: false))
Do you have an explanation? and a solution in order that the eContainer works in standalone mode?
Melanie
Re: [Acceleo] eContainer returns invalid class [message #664970 is a reply to message #664905] Tue, 12 April 2011 12:02 Go to previous messageGo to next message
Melanie,
It sounds like in one case it finds the model (because its nsURI is
registered in the plugin.xml) but in the other case it doesn't, because
you have to register it manually. I.e., calling
XyxPackage.eINSTANCE.eClass() for every package you'll be using. It's
usually easier to run as a headless Eclipse application so that all the
normal registrations are just there...
Melanie Bats wrote:
> Hello,
> expected result
> but
> Melanie
Re: [Acceleo] eContainer returns invalid class [message #664971 is a reply to message #664905] Tue, 12 April 2011 12:05 Go to previous messageGo to next message
Hi Melanie
which means 'invalid'
There have been significant fixes to Standalone operation in M6 and M6a.
I recommend giving them a try.
Ed Willink
Re: [Acceleo] eContainer returns invalid class [message #665060 is a reply to message #664905] Wed, 13 April 2011 03:26 Go to previous messageGo to next message
Hi Melanie,
If you are running in stand alone, you may have to register the metamodel by yourself (see the registerPackages method in the java launcher of your generator for an example). But I agree with Edward Willink, you should give a try to the 3.1M6 Smile
Stephane Begaudeau, Obeo
Twitter: @sbegaudeau
Acceleo wiki: http://wiki.eclipse.org/Acceleo
Blogs: http://stephanebegaudeau.tumblr.com & http://sbegaudeau.tumblr.com
Re: [Acceleo] eContainer returns invalid class [message #665608 is a reply to message #665060] Fri, 15 April 2011 05:17 Go to previous message
In fact the metamodel registration was good and the problem is solved by using the M6a.
Thanks all for your help,
Melanie
Previous Topic:[Acceleo3] Strange template invocation error
Next Topic:[Acceleo] Parameters of one operation
Current Time: Wed Jul 23 06:11:03 EDT 2025
Powered by FUDForum. Page generated in 0.07384 seconds
