[eol] question about usage of native types [message #664913] |
Tue, 12 April 2011 09:29  |
hi
i experimented with using native types in an ewl file. while the example from the book works
var frame = new Native("javax.swing.JFrame");
when i try to instance something else like
var util = new Native("org.eclipse.emf.ecore.util.EcoreUtil");
it fails with a "type not found" error message.
is there a way to make it known to epsilon?
thanks in advance
marco
Re: [eol] question about usage of native types [message #669587 is a reply to message #669572] |
Tue, 10 May 2011 16:17   |
Antonio,
My standalone setup is actually a set of plugins I run in my own RCP. I tried placing the class in the plugin's class path and it is still not found. This is what I have done using the extension point:
In my plugin.xml I have added the epsilon dt tools extension points to call my class:
<!-- Native Types used in Epsilon -->
<extension point="org.eclipse.epsilon.common.dt.tool">
<tool
class="net.sourceforge.riskc.riskcopcode.generator.epsilon.RiskcSimMetrics"
defaultName="SimMetrics">
</tool>
</extension>
In my manifest file I added the dt plugin as a required bundel:
Require-Bundle: org.eclipse.core.runtime,
org.junit,
org.eclipse.epsilon.common.dt,
org.eclipse.epsilon.eol.engine,
org.eclipse.epsilon.egl.engine,
org.eclipse.epsilon.evl.engine,
org.eclipse.epsilon.emc.emf,
Maybe I am missing something else? From my experience using the interactive mode in my other post, can it be that the egl is also not designed to work with native types?
Horacio
[Updated on: Tue, 10 May 2011 17:03] by Moderator
Re: [eol] question about usage of native types [message #670867 is a reply to message #669700] |
Sun, 15 May 2011 21:10  |
Antonio,
Thank you for your answer, it worked flawlessly!
Now I have to figure out what is the best place/moment to add this.. perhaps in the public IEolExecutableModule createModule() method. Create the new specific type module, add the type delegate and return the module.
Horacio
[Updated on: Sun, 15 May 2011 21:12] by Moderator
FUDForum. Page generated in 0.05777 seconds
