Home » Modeling » GMF (Graphical Modeling Framework) » Refresh RootEditPart
Refresh RootEditPart [message #663821] |
Wed, 06 April 2011 10:30  |
I have a custom layer on my
org.eclipse.gmf.runtime.diagram.ui.editparts.DiagramEditPart ,
I tried everything to refresh and show its figure, but it only refreshes
when i add or move something, and also when I resize the editor area, of
course.
Any hints?
my createFigure() and getContentPane():
* Replaces default figure with layered pane. Lower layer for
decorations, upper is original figure.
protected IFigure createFigure() {
FreeformLayeredPane pane = new FreeformLayeredPane();
FreeformLayer roseLayer = new FreeformLayer() {
public Rectangle getFreeformExtent() {
// Do not count children; they are decorations that
should not interfere with diagram contents.
Insets insets = getInsets();
return new Rectangle(0, 0, insets.getWidth(),
insets.getHeight());
roseLayer.setLayoutManager(new StackLayout());
pane.add(roseLayer);
roseLayer.add(new Figure() {
public void paint(Graphics g) {
g.setLineWidth(1);
g.setForegroundColor(new Color(null, 100, 100, 100));
DiagramImpl d = (DiagramImpl) getModel();
Sketch s = ((Diagram) d.getElement()).getRootSketch();
if (s != null) {
for (int i = 1; i < s.getPointlist().size(); i++) {
Point p = (Point) s.getPointlist().get(i);
Point lastp = p;
lastp = (Point) s.getPointlist().get(i - 1);
if (lastp.x == -1) {
//if the last point is a pen lift, then
consider just the current one
g.drawLine(p.x, p.y, p.x, p.y);
} else if (p.x > 0) {
//if is a normal point, then traces a line
from the last point to the current
g.drawLine(lastp.x, lastp.y, p.x, p.y);
pane.add(contentPane = super.createFigure());
return pane;
public IFigure getContentPane() {
return contentPane;
Re: Refresh RootEditPart [message #664674 is a reply to message #663821] |
Mon, 11 April 2011 10:49   |
Nobody?
> refreshes when i add or move something, and also when I resize the
> editor area, of course.
> Any hints?
> @Override
> @Override
> g.setLineWidth(1);
> if (s != null) {
> Point lastp = p;
> return pane;
> @Override
> return contentPane;
Re: Refresh RootEditPart [message #666062 is a reply to message #663821] |
Mon, 18 April 2011 16:06   |
Hi, did you refresh the diagram (as DiagramEditPart.refresh()) at the
end of after your code, if it doesnt work maybe try to refresh all children
for(Object o : yourDiagramEditPart.getChildren()){
if(o instanceof EditPart){//or ur costumized EditPart
EditPart editPart = (EditPart)o;
editPart.refresh();
maybe u have to go deeper in the childrentree.
I had a problem like this before, that some labels didnt refresh, so i
had to refresh the LabelEditParts children of the Figures in the diagram.
Am 06.04.2011 16:30, schrieb Ugo Sangiorgi:
> course.
> Any hints?
> @Override
> // Do not count children; they are decorations that should not interfere
> @Override
> g.setLineWidth(1);
> if (s != null) {
> Point lastp = p;
> //if the last point is a pen lift, then consider just the current one
> //if is a normal point, then traces a line from the last point to the
> current
> return pane;
> @Override
> return contentPane;
Re: Refresh RootEditPart [message #666600 is a reply to message #666062] |
Thu, 21 April 2011 05:21   |
Hello Robin,
thank you, but actually my editor starts with no editparts at all. I
write some freehand drawn pixels at the RootEditPart and want it to be
displayed.
If I resize the editor, the RootEditPart is refreshed and shows the
drawing.
I just want to activate that =(
> children
> editPart.refresh();
>> course.
>> Any hints?
>> @Override
>> @Override
>> g.setLineWidth(1);
>> if (s != null) {
>> Point lastp = p;
>> current
>> return pane;
>> @Override
>> return contentPane;
Re: Refresh RootEditPart [message #666783 is a reply to message #663821] |
Fri, 22 April 2011 10:28   |
What is even more weird is that:
When I open the diagram it doesnt show anything, only if I resize the
editor area.
Then the next drawings shows up normally, the editor is refreshed and all.
What could be hapening? How can I tell that the editor needs to be
repainted upfront?
> Any hints?
> @Override
> @Override
> g.setLineWidth(1);
> if (s != null) {
> Point lastp = p;
> return pane;
> @Override
> return contentPane;
Re: Refresh RootEditPart [SOLVED] [message #667045 is a reply to message #666783] |
Tue, 26 April 2011 03:57  |
I did solved.
My DiagramEditPart reads the model (which has some x,y points) and draws
them accordingly:
private IFigure contentPane;
FreeformLayer sketchLayer = new FreeformLayer() {
sketchLayer.setLayoutManager(new StackLayout());
pane.add(sketchLayer);
sketchLayer.add(new Figure() {
[here i draw whatever i want]
return pane;
I just neeeded to refresh through a request, with this the editpart is
refreshed upon creation:
performRequest(new Request(RequestConstants.REQ_REFRESH));
return contentPane;
Outside the DiagramEditPart I just performed the refresh request:
editor.getDiagramEditPart().performRequest(new
Thats it =)
> editor area.
> all.
> repainted upfront?
>> Any hints?
>> @Override
>> @Override
>> g.setLineWidth(1);
>> if (s != null) {
>> Point lastp = p;
>> line from the last point to the current
>> return pane;
>> @Override
>> return contentPane;
Current Time: Sun Jul 27 09:13:34 EDT 2025
Powered by FUDForum. Page generated in 0.04123 seconds
