Block diagram editor [message #664396] |
Fri, 08 April 2011 11:58  |
--------------090502070801020103050609
Hi all,
I would like to make a flow diagram editor using graphiti.
After trying some examples and making some tests, I identify many aspects of the tool that
make the user experience more difficult than existing tools on the market.
Most of the problem come from the connection management between objects.
I create two small videos to illustrate the connection functionnalities using two
different tools : Simulink/Mathworks and Graphiti/Eclipse.
(Note : The second video will be posted in the reply.)
As you can see in this video, the number of clicks required is much larger with graphiti
when trying to interact with connection and trying to make simple operations
So, how could I do similar thing with graphiti? Which features should be added to graphiti?
Here are some questions and remarks that illustrate the difference betweeen tools
1- How could I be sure connections are always horizontal / vertical.
2- Moving a connection will move the entire (horizontal, vertical) segment, not only one
anchor point and should not required to select the "selection tool"
3- Connection could have unknown source or target
4- Connection segment should be always on the grid (all vertical and horizontal segment)
5- Connection anchor (used for branch) should be removed automatically when there is only
one branch connected to it.
6- and so on.
Could anybody provide me more help on these issues?
Thank you very much.
Vincent
Content-Type: video/avi;
name="block_connection.avi"
filename="block_connection.avi"
UklGRnazAwBBVkkgTElTVOx+AABoZHJsYXZpaDgAAACFRQEAlBIAAAEAAAAQ CAAAbQIAAAAA
AAABAAAATRQAABgCAAB4AQAAAAAAAAAAAAAAAAAAAAAAAExJU1SUfQAAc3Ry bHN0cmg4AAAA
dmlkc3RzY2MAAAAAAAAAAAAAAAA1twwAgJaYAAAAAABtAgAATRQAAAAAAAAA AAAAAAAAAAAA
AABzdHJmKAAAACgAAAAYAgAAeAEAAAEAGAB0c2NjgHMSAAAAAAAAAAAAAAAA AAAAAABpbmR4
GH0AAAQAAAABAAAAMDBkYgAAAAAAAAAAAAAAAAx/AAAAAAAAIH0AAG0CAAAA AAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAA
AAAAAAAATElTVAQBAABvZG1sZG1saPgAAABtAgAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAA
AAAAAExJU1SODQMAbW92aWl4MDAYfQAAAgAAAW0CAAAwMGRiLPwAAAAAAAAA AAAACAAAAB4K
AAAuCgAAAgAAgDgKAAACAACAQgoAAAIAAIBMCgAAAgAAgFYKAAACAACAYAoA AOkBAIBSDAAA
AgAAgFwMAABKAQCArg0AAJ4BAIBUDwAAMQEAgI4QAAACAACAmBAAAFoBAID6 EQAAAgAAgAQS
AAACAACADhIAAAIAAIAYEgAAAgAAgCISAAACAACALBIAAAIAAIA2EgAAAgAA gEASAAACAACA
ShIAAAIAAIBUEgAAAgAAgF4SAAACAACAaBIAAAIAAIByEgAAAgAAgHwSAAAC AACAhhIAAAIA
AICQEgAAAgAAgJoSAABgAACAAhMAAH0AAICIEwAAiwAAgBwUAAC/AACA5BQA ABICAID+FgAA
TgEAgFQYAADtAQCAShoAAMgBAIAaHAAAuQEAgNwdAADMAQCAsB8AAEABAID4 IAAAuwEAgLwi
AAA6AgCA/iQAAAIAAIAIJQAAOAEAgEgmAADiAACAMicAANgAAIASKAAA3AAA gPYoAABdAQCA
XCoAANkBAIA+LAAA5wAAgC4tAAACAACAOC0AAGUBAICmLgAA6gEAgJgwAAA0 AQCA1DEAAAIA
AIDeMQAAAgAAgOgxAAACAACA8jEAAAIAAID8MQAAugAAgL4yAABZAACAIDMA ANUBAID+NAAA
AgAAgAg1AAACAACAEjUAAAIAAIAcNQAAAgAAgCY1AAACAgCAMDcAAGQCAICc OQAADQIAgLI7
AADyAQCArD0AAEIBAID2PgAAyAEAgMZAAADWAQCApEIAAKUBAIBSRAAASQEA gKRFAAACAACA
rkUAAAIAAIC4RQAAQwEAgARHAAACAACADkcAAAIAAIAYRwAAAgAAgCJHAACn CgAA0lEAAE8B
AIAqUwAAQwEAgHZUAABsBQCA6lkAAEQAAIA2WgAAgwAAgMJaAADEAACAjlsA ACICAIC4XQAA
6AEAgKhfAAAFAgCAtmEAAMQBAICCYwAA2QEAgGRlAADOAQCAOmcAANkBAIAc aQAAFwEAgDxq
AACsAQCA8GsAAGYBAIBebQAAvAEAgCJvAADiAACADHAAAAIAAIAWcAAAawEA gIpxAABSAQCA
5HIAALEBAICedAAATAEAgPJ1AABTAQCATncAAJcBAIDueAAARQEAgDx6AACP AQCA1HsAAG4B
AIBKfQAAhAEAgNZ+AAACAACA4H4AAAIAAIDqfgAAAgAAgPR+AAACAACA/n4A AAIAAIAIfwAA
AgAAgBJ/AAACAACAHH8AAAIAAIAmfwAA5gAAgBSAAAACAACAHoAAAAIAAIAo gAAAAgAAgDKA
AAACAACAPIAAAL8AAIAEgQAAwAUAgMyGAAA/AQCAFIgAAAIAAIAeiAAAxwEA gO6JAAB2AgCA
bIwAAEUCAIC6jgAASwEAgA6QAACjAQCAupEAAAIAAIDEkQAA9AAAgMCSAACe AQCAZpQAAHAC
AIDelgAAVgMAgDyaAAANAgCAUpwAALkBAIAUngAAtAEAgNCfAADpAQCAwqEA AH4CAIBIpAAA
TAEAgJylAAACAACApqUAAAIAAICwpQAANwEAgPCmAAACAACA+qYAAAIAAIAE pwAADAIAgBip
AABVAgCAdqsAAEMBAIDCrAAASwEAgBauAADYAQCA9q8AAC4CAIAssgAARgEA gHqzAACxAQCA
NLUAABoCAIBWtwAAsgEAgBC5AABCAQCAWroAAEIBAICkuwAA2AoAAITGAAD+ AQCAisgAAHEC
AIAEywAAngIAgKrNAAAlAgCA2M8AAEcBAIAo0QAASAEAgHjSAAACAACAgtIA AD0BAIDI0wAA
TwEAgCDVAAA4AgCAYNcAAE4BAIC22AAAQAEAgP7ZAABIAQCATtsAAAIAAIBY 2wAAAgAAgGLb
AAACAACAbNsAAAIAAIB22wAAAgAAgIDbAAACAACAitsAAAIAAICU2wAAAgAA gJ7bAAACAACA
qNsAAAIAAICy2wAAAgAAgLzbAAACAACAxtsAAAIAAIDQ2wAAAgAAgNrbAAAC AACA5NsAAAIA
AIDu2wAAAgAAgPjbAAACAACAAtwAAAIAAIAM3AAAAgAAgBbcAAACAACAINwA AAIAAIAq3AAA
AgAAgDTcAADNBACACuEAAAIAAIAU4QAAAgAAgB7hAAClAQCAzOIAAPIBAIDG 5AAAdAIAgELn
AAD4AQCAQukAAPYBAIBA6wAAUgIAgJrtAABnAACACu4AAK0AAIDA7gAAyAAA gJDvAACiAACA
OvAAAAIAAIBE8AAA3AEAgCjyAAACAACAMvIAAAIAAIA88gAA0AEAgBT0AAAC AACAHvQAAAIA
AIAo9AAA0wEAgAT2AAACAACADvYAAAIAAIAY9gAAzQEAgO73AAACAACA+PcA AAIAAIAC+AAA
AgAAgAz4AAACAACAFvgAAAIAAIAg+AAAAgAAgCr4AAACAACANPgAAM4BAIAK +gAAAgAAgBT6
AAACAACAHvoAANABAID2+wAAAgAAgAD8AAACAACACvwAAN4BAIDw/QAAAgAA gPr9AAACAACA
BP4AAAIAAIAO/gAAAgAAgBj+AAACAACAIv4AANUJAAAACAEAAgAAgAoIAQAC AACAFAgBAAIA
AIAeCAEAAgAAgCgIAQDNAQCA/gkBAAIAAIAICgEAAgAAgBIKAQACAACAHAoB AAIAAIAmCgEA
AgAAgDAKAQACAACAOgoBAAIAAIBECgEAAgAAgE4KAQACAACAWAoBAAIAAIBi CgEAAgAAgGwK
AQACAACAdgoBAAIAAICACgEATgEAgNYLAQACAACA4AsBAAIAAIDqCwEA4gIA gNQOAQCNAgCA
ahEBAEwBAIC+EgEAjQIAgFQVAQCHAQCA5BYBABcCAIAEGQEAwAIAgMwbAQD0 AQCAyB0BAHoA
AIBKHgEA9wEAgEogAQDYAQCAKiIBAO4CAIAgJQEAAgAAgColAQACAACANCUB AAIAAIA+JQEA
AgAAgEglAQBaAQCAqiYBAJEBAIBEKAEAmQEAgOYpAQDiAQCA0CsBAKIBAIB6 LQEAowEAgCYv
AQCWAQCAxDABALgBAICEMgEAigEAgBY0AQCLAQCAqjUBAFwBAIAONwEAAgAA gBg3AQACAACA
IjcBAAIAAIAsNwEAAgAAgDY3AQACAACAQDcBAFABAICYOAEAAgAAgKI4AQAC AACArDgBAAIA
AIC2OAEAAgAAgMA4AQACAACAyjgBAAIAAIDUOAEAugEAgJY6AQBQAQCA7jsB AJ4BAICUPQEA
jgEAgCo/AQC0AQCA5kABALIBAICgQgEAiwEAgDREAQB1AQCAskUBAKEBAIBc RwEAhQEAgOpI
AQACAACA9EgBAAIAAID+SAEAegEAgIBKAQACAACAikoBAAIAAICUSgEAgQEA gB5MAQACAACA
KEwBAAIAAIAyTAEAaAEAgKJNAQCjCQAATlcBAAIAAIBYVwEAAgAAgGJXAQAC AACAbFcBAAIA
AIB2VwEAAgAAgIBXAQACAACAilcBAJEHAIAkXwEAAgAAgC5fAQACAACAOF8B AAIAAIBCXwEA
AgAAgExfAQACAACAVl8BAAIAAIBgXwEAAgAAgGpfAQACAACAdF8BAAIAAIB+ XwEAAgAAgIhf
AQBqAgCA+mEBAKICAICkZAEAIAIAgMxmAQALAgCA4GgBAPABAIDYagEA7QEA gM5sAQBDAQCA
Gm4BAEMBAIBmbwEARQEAgLRwAQBIAQCABHIBAAIAAIAOcgEA+QEAgBB0AQCH AACAoHQBAC8C
AIDYdgEAugIAgJp5AQByAgCAFHwBACYCAIBCfgEAGQIAgGSAAQACAACAboAB AAwBAICCgQEA
AgAAgIyBAQCTAQCAKIMBAOkBAIAahQEAgwEAgKaGAQCyAQCAYIgBAOYBAIBO igEARwEAgJ6L
AQCtAQCAVI0BAIwBAIDojgEA+AAAgOiPAQD7AACA7JABACoBAIAekgEAfQAA gKSSAQCtAACA
WpMBAHgAAIDakwEAKgIAgAyWAQBBAgCAVpgBAGUBAIDEmQEAPwEAgAybAQAC AACAFpsBAAIA
AIAgmwEA+AAAgCCcAQDxAACAGp0BALIBAIDUngEAJQEAgAKgAQACAACADKAB AAIAAIAWoAEA
AgAAgCCgAQACAACAKqABAHoAAICsoAEAAgAAgLagAQACAACAwKABAAIAAIDK oAEAAgAAgNSg
AQACAACA3qABAAIAAIDooAEAAgAAgPKgAQACAACA/KABAAIAAIAGoQEAAgAA gBChAQACAACA
GqEBAAIAAIAkoQEAAAwAACytAQACAACANq0BAAIAAIBArQEAAgAAgEqtAQAC AACAVK0BAAIA
AIBerQEAAgAAgGitAQACAACAcq0BAAIAAIB8rQEAAgAAgIatAQACAACAkK0B AAIAAICarQEA
AgAAgKStAQACAgCArq8BAN0BAICUsQEAaAIAgAS0AQA3AgCARLYBANwBAIAo uAEARAEAgHS5
AQB0EACA8MkBAEABAIA4ywEAAgAAgELLAQACAACATMsBAAIAAIBWywEAxQAA gCTMAQBMAQCA
eM0BAIsBAIAMzwEAGwIAgDDRAQB6AQCAstIBAHMBAIAu1AEAVQEAgIzVAQDP AACAZNYBAMwA
AIA41wEAAgAAgELXAQBQAACAmtcBAAIAAICk1wEAAgAAgK7XAQACAACAuNcB AAIAAIDC1wEA
AgAAgMzXAQBVAACAKtgBAJwAAIDO2AEAygAAgKDZAQB6AgCAItwBAJ4BAIDI 3QEAcgEAgELf
AQACAACATN8BACAAAIB03wEA2gEAgFbhAQA3AQCAluIBAAIAAICg4gEAAgAA gKriAQDQAACA
guMBAOEAAIBs5AEAAgAAgHbkAQBlAACA5OQBAAIAAIDu5AEAAgAAgPjkAQDi AACA4uUBAAIA
AIDs5QEAAgAAgPblAQCwAQCArucBAGABAIAW6QEA9QEAgBTrAQBqAQCAhuwB AHcBAIAG7gEA
DwEAgB7vAQD4AACAHvABAN8AAIAG8QEAVgAAgGTxAQDpAACAVvIBAAIAAIBg 8gEAAgAAgGry
AQACAACAdPIBAFMAAIDQ8gEA6QEAgML0AQBmAgCAMPcBANwCAIAU+gEAngEA gLr7AQALAQCA
zvwBAEUUAAAcEQIAAgAAgCYRAgBpAACAmBECAAIAAICiEQIAAgAAgKwRAgAC AACAthECAFQA
AIASEgIAiQAAgKQSAgB6AQCAJhQCAOUBAIAUFgIAYAEAgHwXAgDgAACAZBgC AB8BAICMGQIA
nAEAgDAbAgACAACAOhsCAAIAAIBEGwIAAgAAgE4bAgACAACAWBsCAFIBAICy HAIAOQEAgPQd
AgACAACA/h0CAAIAAIAIHgIA3QAAgO4eAgACAACA+B4CAAIAAIACHwIAUAEA gFogAgDYAQCA
OiICAAIAAIBEIgIAAgAAgE4iAgACAACAWCICAAIAAIBiIgIAAgAAgGwiAgAC AACAdiICAAIA
AICAIgIAAgAAgIoiAgACAACAlCICAAIAAICeIgIAAgAAgKgiAgACAACAsiIC AAIAAIC8IgIA
AgAAgMYiAgACAACA0CICAAIAAIDaIgIAAgAAgOQiAgACAACA7iICAAIAAID4 IgIAAgAAgAIj
AgCrAQCAtiQCANoBAICYJgIASAIAgOgoAgAOAgCA/ioCAEIBAIBILAIAWgEA gKotAgA8AQCA
7i4CAAIAAID4LgIAAgAAgAIvAgACAACADC8CAL8BAIDUMAIA+QEAgNYyAgAp AgCACDUCAAQC
AIAUNwIA6gEAgAY5AgCtAQCAvDoCAD8KAIAERQIAcQEAgH5GAgA8AQCAwkcC AAIAAIDMRwIA
QAEAgBRJAgDeAQCA+koCAEECAIBETQIAAgAAgE5NAgA7AQCAkk4CABYBAICw TwIAZQEAgB5R
AgACAACAKFECAJwBAIDMUgIAZgEAgDpUAgCvAACA8lQCAI8AAICKVQIAewAA gA5WAgDFDQAA
3GMCADMCAIAYZgIA7AAAgAxnAgAiAQCANmgCAAIAAIBAaAIAQQAAgIpoAgAC AACAlGgCAAIA
AICeaAIAAgAAgKhoAgAnAgCA2GoCACwCAIAMbQIAAgAAgBZtAgACAACAIG0C AAIAAIAqbQIA
AgAAgDRtAgACAACAPm0CAAIAAIBIbQIAAgAAgFJtAgACAACAXG0CAAIAAIBm bQIAAgAAgHBt
AgACAACAem0CAAIAAICEbQIAAgAAgI5tAgACAACAmG0CAAIAAICibQIAAgAA gKxtAgACAACA
tm0CAAIAAIDAbQIAAgAAgMptAgACAACA1G0CAAIAAIDebQIAAgAAgOhtAgAC AACA8m0CAAIA
AID8bQIASwEAgFBvAgBUAQCArHACAIUBAIA6cgIAQgEAgIRzAgBLAQCA2HQC AEABAIAgdgIA
3QEAgAZ4AgB/AQCAjnkCALQBAIBKewIAzAEAgB59AgBQAQCAdn4CAAIAAICA fgIAAgAAgIp+
AgBEAQCA1n8CAEYCAIAkggIA6AAAgBSDAgBwCACAjIsCAMgAAIBcjAIAlwAA gPyMAgACAACA
Bo0CAAIAAIAQjQIAAgAAgBqNAgBoAACAio0CAD4BAIDQjgIAkAEAgGiQAgAC AACAAAAAAAAA
Re: Block diagram editor [message #664570 is a reply to message #664396] |
Mon, 11 April 2011 04:28   |
Vincent,
I was only able to see the first video, the second appears completely
scambled (also from the download link).
Nevertheless some answers to the questions:
1) You can use ManhattanConnections
2) Selection tool is mandatory, the rest see 1) or/and you need to write
some layout-correcting code inside your move features
3) In Graphiti it is mandatory to have any kind of shape at each connection
end. You could introduce some dummy shape for that purpose
4) Not available now, if you would like to see that please raise this al
enhancement bugzilla
5) Needs to be coded in your feature for deleting the connection or
reconnecting the connection
BTW: Starting a connection from another connection is possible with the
upcoming Graphiti 0.8.0 (Eclipse Indigo).
HTH,
Michael
"Vincent L." wrote in message news:innat1$f69$4@news.eclipse.org...
Hi all,
the tool that
using two
with graphiti
added to graphiti?
tools
not only one
horizontal segment)
there is only
6- and so on.
Vincent
Re: Block diagram editor [message #670280 is a reply to message #664396] |
Fri, 13 May 2011 07:01  |
Hi Vincent,
if your are interested in the development of a block diagram editor, you may want to have a look at Damos, which is an Eclipse-based data flow-oriented modeling tool that includes a block diagram editor, a simulator and a C code generator. It is based on GMF runtime (no generated diagram code). The project is hosted on EclipseLabs within the Yakindu project (I cannot send links here directly). If you need more information, feel free to contact me directly.
Andreas
FUDForum. Page generated in 0.06212 seconds
