model query [message #663703] |
Wed, 06 April 2011 05:19  |
hello guys!
i'm using model query to do some queries and update on my model...
the steps that i done, are:
-generate from genmodel of my metamodel every model classes ...
-register metamodel and after call a method that has to read a model...
-in this method :
ResourceSet resourceSet = new ResourceSetImpl();
URI modelUri = URI.createFileURI(new File("model/mymodel.ecore").getAbsolutePath());
EcoreResourceFactoryImpl ecoreFactory = new EcoreResourceFactoryImpl();
resourceSet.getResourceFactoryRegistry().getExtensionToFacto ryMap().put( "ecore", ecoreFactory);
// Demand load resource for this file.
Resource resource = resourceSet.getResource(modelUri, true);
System.out.println("Loaded " + modelUri);
OCL ocl = org.eclipse.ocl.ecore.OCL.newInstance();
EObjectCondition condition = new BooleanOCLCondition<EClassifier, EClass, EObject>( ocl.getEnvironment(), "self.elements", MyMMPackage.Literals.MOD);
SELECT statement = new SELECT(SELECT.UNBOUNDED, false, new FROM(resource.getContents()), new WHERE(condition));
IQueryResult results = statement.execute(); // do something with the results
System.out.println("SIZE: " + results.size());
but i receive error like that: java.lang.ClassCastException: org.eclipse.emf.ecore.impl.EFactoryImpl cannot be cast to MyMM.MyMMFactory
the problem is solved if I change query from "self.elements" to for example self.oclIsTypeOf("MyMM::metaclass")
what it's wrong?!?!?
thx
Re: model query [message #663812 is a reply to message #663703] |
Wed, 06 April 2011 10:49   |
Chuck,
This sounds more likely to be an OCL question so I've added the OCL
newsgroup/forum to the to list of my reply.
chuck wrote:
> hello guys!
> -in this method :
> results
> MyMM.MyMMFactory
> thx
Re: model query [message #663849 is a reply to message #663812] |
Wed, 06 April 2011 11:47   |
This isn't actually an OCL problem, but an EMF Query issue.
As Axel observes, you may not be using Boolean. The CCE certainly looks
like a data type construction issue, but since you only provide 25% of
the problem report we can only provide 25% of the answer.
Ed Willink
On 06/04/2011 15:49, Ed Merks wrote:
> Chuck,
> chuck wrote:
>> hello guys!
>> -in this method :
>> results
>> MyMM.MyMMFactory
>> thx
FUDForum. Page generated in 0.25139 seconds
